Amplifier is humming
My amplifier humms
    Problem Solver:
  • 6 Answers
Amplifier is voltage given throuh any high voltage
Posted on Oct 24, 2012
The hums are probably the fan kicking in to keep it cool.
Jan 25, 2013 | Audio Players & Recorders
My Amplifier is humming
My amplifier hums.
If it is really the amplifier that makes a humming noise check on the
power transformer.
But if your referring to humming produced on your speaker then
check on it, not good to turn On for long.
First check for DC offset, use a multimeter.
If there are more than 0.7V on the output, have a tech to repair
your main amplifier.
If it is about 0.7V, then check the preamp circuits and power supply
filtering circuits and regulators.
Oct 24, 2012 | Audio Players & Recorders
I get a humming sound when the ipod is attached,
the hum comes from three possible sources, the power unit can cause it before failure, the amplifier which can effect one or more speakers or the interface board between the other two, the interface board and the power board are known problems to b and w, so if you have not already contacted service at b and w, then do so.
May 15, 2010 | B&W Bowers and Wilkins Zeppelin iPod Music...
Loud humm when the drive channel is on
I suspect the power supply has an issue. Most likely bad filter capacitors. This could cause "motorboating" where power is drawn and supply voltage collapses and then recovers repeatedly.
Time for the repair shop. The parts cost should be nominal... labor... well...
Mar 15, 2010 | Fender Hot Rod Deluxe Guitar Combo...
Bad Humm out
First disconnect all inputs. If hum is still there, PROBABLY the filter capacitors have gone bad. Replacement is the cure.
IF there is no hum without any inpout cable connected, there is a ground loop and either the ground at the inout connector is broken, or your cables and guitar may have a problem.
Nov 15, 2009 | Marshall Amplification Marshall MG250DFX...
Sub has started humming with amp turned off. just turned on at wall switch.nothing running
If the hum is from the back of the unit around the amplifier, it may be the transformer. It could be that the mounting is loose.
It could also be that the transformer is going out.
Disconnect all the inputs to the unit, Still hum?
If the hum stops you have something causing noise to the input.
If you have it on a switched circuit, try moving the power plug to a different outlet that is not on a switch. If hum stops, then you have something on that circuit causing the problem
if all inputs are disconnected and it still humms good chance it is the transformer.
Nov 12, 2009 | Velodyne CHT-8 Subwoofer
Subwoofer hum -MTX12" connected to a Aiwa Surround sound. No problems first 10 months, then suddenly all the subwoofer will do is humm loudly and not play music. Changed cables, no change, changed where it...
I assume this is an active sub. The amplifier has most likely failed. You have proved the signal source is not the problem, well almost if you can sucessfully connect the aiwa sub to another amp then we will know for sure. Usually amplifiers fail with an output device short circuit. The hum you here is the power supply direct on the speaker, I would not leave it on for long or speaker damage may ensue.
Sep 21, 2009 | MTX 12" 2-Way Professional Loudspeaker...
I have a loud humm in my bose lifestyle 28 system
Turn on your bose so you can hear it hum. Go to the back of your cable box and remove the co ax cable connected to "cable in". If the humming stops, the sheilding on your cable is no longer grounded. Purchase MPAV800 or similar surge protector to run cable line through it and get it grounded.
Feb 02, 2009 | Bose Lifestyle 28 System
Humm
where is the ground wire from the turntable connected to ? Ensure that is is connected to the phono pre-amp's ground.
Is the turntable sitting on top/near any other equipment ? Try changing the position and see if the hum reduces. If yes, then it is likely that it is picking up hum from a mains transformer.
Aug 21, 2008 | Aiwa PX-E860 Turntable
Fan
The hum is power line hum ( 60 cycle ) . It may be that when the amp gets warm that something in the case wants to vibrate to the 60 cycle hum.
I have amps that hum like that and theyre fine.
Depending on the design of the amp, the cooling fan may not go on till it gets really warm in the amp. Some run all the time like the Ashly I just fixed
Dec 03, 2007 | Crown CE2000 2-Channel Amplifier
29 people viewed this question
 Grubhead
Grubhead
