Question about Bell Sports Bell F12 Bike Computer
Bell f12 speedometer keeps resetting mid trip
I installed it. It works great when it doesnt reset itself. Ill be riding and all of a sudden it just starts blinking like I just took it out of the box and put the battery in it and need to enter the bike info. How to fix this?
3 Suggested Answers
  • 5 Answers
SOURCE: I am looking for the
2124
Posted on Oct 16, 2011
  • 5 Answers
SOURCE: need installation manual for Bell F12
http://www.manualsonline.com/mimages/fc2d8bf1-2502-462a-8078-2b384f8b575c.jpeg
Trip Meter not working.
Odometer and Trip Meter Stopped Working - AcuraZine Community
acurazine.com/forums/.../odometer-trip-meter-stopped-working-757772/
Dec 29, 2009 - The tech said he has seen the odometer & trip meter not workingbeing ... I have a 1997 TL and the same exact thing happened to me today. speedometer,trip and odometer not working
Aug 5, 2012
Cannot reset Trip A or Trip B on New 2012 MDX
Aug 1, 2012
Trip meter resets itself
Jul 25, 2012
Trip Computer Reset feature (with refuel) question..
Dec 19, 2009
More results from acurazine.com
Acura TL odometer trip meter not working Questions ... - Fixya
www.fixya.com/tags/odometer_trip_meter_not_working/cars/acura/tl
Dec 15, 2015 | 1997 Acura TL Series
Speedometer quit working,possible causes?
Many possible causes
THEORY OF OPERATION
The 2001 electronic speedometer consists of a speed sensor, an odometer reset switch and the speedometer itself. The speed sensor is located on the right side of transmission case below the starter. It is a Hall Effect sensor that is triggered by the gear teeth of 4th gear on the transmission mainshaft. The output from the sensor is a series of pulses that are interpreted by speedometer circuitry to control the position of the speedometer needle and the liquid crystal (LCD) odometer display. The odometer mileage is permanently stored and will not be lost when electrical power is turned off or disconnected. The odometer reset switch allows switching between the odometer and the trip odometer displays. To zero the trip odometer, while having the odometer display visible, press and keep the function switch depressed. The trip odometer mileage will be displayed for 2-3 seconds and then the trip mileage will return to zero miles. The odometer can display six numbers to indicate a maximum of 999999 miles. The trip odometer can display six numbers with a tenth of a mile accuracy for a maximum of 99999.9 miles. Circuitry in the speedometer also uses the sensor input to provide an input to the turn signal canceller. This turn signal canceller input was previously supplied by the reed switch in mechanical speedometers.
DIAGNOSTICS
To enable diagnostic mode depress the odometer reset switch and turn ignition/key switch to ON, to clear codes turn the ignition switch from OFF to ON while holding the reset switch in. Press and release the reset switch to cycle through the codes. Set codes will display as Code d0xSet. Holding the reset switch in will result in Code d0xClr being displayed indicating that the code has been cleared. To return the speedometer to the normal operating state cycle the ignition/key switch.
Remove the seat for testing. Remove the speed sensor and check for accumulation of debris on it and if there is any debris present, clean it away and if there is not debris replace the sensor.
Disconnecting the speed sensor will cause code d02 to set.
ODOMETER, TRIP ODOMETER AND RESET SWITCH TESTING
Turn the ignition ON. Does odometer display consist of the correct numbers?
If YES Press trip reset switch. Does the LCD display toggle between trip and odometer modes? BUT if the odometer display does not consist of the correct numbers replace the speedometer.
If the speedometer does display the correct numbers press the trip reset switch. Does the LCD display toggle between the trip and odometer modes? If No Loosen the trip reset switch boot and then tighten it again until it is snug and toggle the switch again and verify if it toggles between trip and odometer modes? If YES does the trip display consist of correct numbers? If it does STOP here and go to test 2A If No replace the speedometer.
If loosening and retightening the reset switch boot results in okay toggling between the trip and odometer modes the Speedometer is OKAY. If it does not, then remove the rubber boot from the reset switch and toggle it without the rubber cover and if it now toggles between the trip and the odometer modes replace the reset switch boot/cover. If it does not now toggle between the trip and odometer modes place a jumper wire across the leads to the reset switch on speedometer connector. Does the LCD display now toggle between the trip and the odometer modes? If yes replace the reset switch and if No replace the speedometer.
Speedometer Test 2A
SPEEDOMETER INOPERATIVE, READS HIGH/LOW, NEEDLE STICKS, INTERMITTENT/ERRATIC, OUTPUT SPEED SIGNAL INOPERATIVE
Turn ignition ON. Is speedometer backlighting on? If NO then If speedometer backlighting is not on, check for 9-12 VDC on the O/W wire at connector
[39B]. If the proper voltage is present check for continuity to ground on the BK wire at connector [39B]. If there was not appropriate voltage on the )/W wire at connector [39B] locate and repair an open in the O/W wire.
If there is continuity at the BK wire at connector [39B] replace the speedometer. If there is not locate and repair an open in the BK wire.
If there is backlighting enable diagnostic mode and clear codes. Then recheck for codes. If there are any codes present go to the applicable
code in Speedometer Test 2B (d0x).
If there are no codes set return the speedometer to its normal state, raise the rear wheel from the ground, put the transmission in 5th gear, turn the ignition ON, spin the back tire, enable diagnostic mode and check for codes and if there are any codes set now make repairs to the harness/connections.
May 01, 2014 | 2000 Harley Davidson FLHR-FLHRI Road king
My speedometer doesnt work
Without key in ignition, depress and hold down the trip reset button by the speedometer until a code appears. Release button and the gauge cluster will go through a self diagnosis ( needles will move around and dash lights will blink). When needle returns to zero and lights go off, diagnosis will be completed and speedometer will be reset. Very easy fix.
Feb 24, 2014 | 2002 Dodge Neon
Htachi ec89 Thermal Protection trips
Its your reset button on the compressor that's bad! I have the exact same compressor (EC89) and it did the same thing! Compressor would run great for 15-20 seconds, then trip the reset button. I ordered a new reset button off e-bay, replaced it, and it works fine now. Good overall compressor! but has cheep china electronics installed. just replace the reset button and you will be good to go....cheep fix!!!
Sep 01, 2012 | Hitachi EC89 4 Gallon Twin Stack Air...
Speedometer not working 2000 harley davison and engine light is on
Here is some 2001 information that may be helpful
The 2001 DYNA electronic speedometer consists of a speed sensor, an odometer reset switch and the speedometer itself. The speed sensor is located on the right side of transmission case below the starter. It is a Hall Effect sensor that is triggered by the gear teeth of 4th gear on the transmission mainshaft. The output from the sensor is a series of pulses that are interpreted by speedometer circuitry to control the position of the speedometer needle and the liquid crystal (LCD) odometer display. The odometer mileage is permanently stored and will not be lost when electrical power is turned off or disconnected. The odometer reset switch allows switching between the odometer and the trip odometer displays. To zero the trip odometer, while having the odometer display visible, press and keep the function switch depressed. The trip odometer mileage will be displayed for 2-3 seconds and then the trip mileage will return to zero miles. The odometer can display six numbers to indicate a maximum of 999999 miles. The trip odometer can display six numbers with a tenth of a mile accuracy for a maximum of 99999.9 miles. Circuitry in the speedometer also uses the sensor input to provide an input to the turn signal canceller. This turn signal canceller input was previously supplied by the reed switch in mechanical speedometers.
DIAGNOSTICS
Speedometer Test 2A
Jun 26, 2011 | 2000 Harley Davidson FXD Dyna Super Glide
Engine shuts down while riding turn inginatioon off and then back on motor starts ride a ways and the proccess repeates itself
hello sounds like a breaker tripping then resetting. I have gotten great help on harleytalking.com good luck..
Apr 22, 2011 | Harley Davidson FLHR - FLHRCI Road king...
My digital speedometer keeps "rebooting"
I would check the connectors that supply power to the speedo.
Also check the fuses and earth points.
The fact you are loosing time is a sign power is going off.
Please dont forget to vote this answer was helpful
Many thanks
Feb 14, 2011 | Suzuki GSF 1200 Bandit S Motorcycles
Seat belt light stays on and trip computer resets when turning engine off then on trouble clears itself
k this means that your dash doesnt have constant power like it should and have to take out the speedometer assembly and check the red and yellow power wires make sure they are connected sounds like one is not probably the yellow belive it is the constant and this should stop seat belt problem to it prbly touching the seatbelt wire or grounding it out hope this helps also check and make sure your trip reset button is not stuck just for s/g
Sep 14, 2010 | 2003 Lincoln Town Car
Bell Sports Bell F12 Bike Computer Logo
49 people viewed this question
Top Bell Sports Cycling Experts
Eric Hidle
Level 1 Expert
Tom Chichester
Donald Ayers-Marsh
Are you a Bell Sports Cycling Expert? Answer questions, earn points and help others
