Question about Philips Health & Beauty
Phillips shaver RQ 1250 won't turn on
RQ 1250 rechargeable
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: Phillips Senso Touch shaver Used it fine
Check the contacts in the shaver and the stand for any that may be bent or dirt in them....
If everything else is ok, then the battery went bad and shorted out...
heatman101
Posted on Jul 25, 2011
Why is there no red light when it is plugged in?
You probably need to replace the rechargeable batteries. The batteries work in series with the shaver... if just one is completely no good in the battery pack, the shaver won't work. NimH batteries only last 2 to 3 years at best; older NiCd batteries far less. All rechargable batteries are made by either Matshushita (Panasonic) or Energizer (old Sanyo brand and before that the GE brand). Some mfrs build their own battery packs using rechargable batteries with TABS from these battery mfrs and wire them together end to end + to -, etc, like a flashlight (torch UK) to make the proper voltage. A Norelco brand is the same as a Phillips shaver.
Apr 23, 2015 | Health & Beauty
My Qt4050 seems to be charging ok, but I can no turn it on with the on-off button. Any fix for this problem?
Might be a silly question but are trying to turn it on whilst the charger is connected? Most (if not all) of the Phillips rechargeable shavers will only operate without the charger connected so as to avoid connection to the mains whilst in a bathroom etc.
Dec 19, 2013 | Philips Norelco Qt4050 Vacuum Beard...
On off switch not working
Might be a silly question but are you trying to turn it on whilst the charger is connected to the shaver? Most (if not all) of the Phillips rechargeable shavers will only operate without the charger connected so as to avoid connection to the mains whilst in a bathroom etc.
R9370 won't work
Any corrosion on the rechargeable batteries usually means that they've gone bad.
For an relatively easy to fix test, disconnect one end of one of the cells wherever it's easiest to solder back together. Then plug in the shaver and see if it works. The LCD may not work, but the shaver itself might.
Looking it up further, I see that it uses a 12VDC cord/charger. So if you try my suggestion, the LCD and shaver should work when plugged in, if the batteries are the problem.
Sep 25, 2012 | Remington Health & Beauty
LOST DIRECTIIONS FOR RECHARGING PANASONIC WET/DRY WOMEN'S ELECTRIC RAZOR ES2207. Thanks!
You will find the instruction manual at shaveroutlet.com. See link below. When page opens, click the 'user manual' link near the 'add to cart' button
http://shaveroutlet.com/women-s/panasonic-es2207-close-curves-rechargeable-wet-and-dry-ladies-shaver.html
Aug 04, 2011 | Panasonic Health & Beauty
I HAVE A PHILLIPS SHAVER MODEL 5890 AND HAVE PURCHASED NEW RECHARGEABLE BATTERIES. HOW DOES ONE REMOVE THE OLD BATTERIES AND FIT THE NEW ? I HAVE OPENED UP THE SHAVER BUT THE EXISTING BATTERIES SEEM WELL...
The batteries are soldered into place. You will need a soldering iron and electrical solder to replace them. Unsolder the old batteries from the circuit board and solder in the new batteries
If you are not able to do this repair yourself, shaveroutlet.com can do it for you. See information at the link below
http://shaveroutlet.com/shaver-replacement-parts/professional-battery-replacement-for-most-models-p-374.html
Jan 20, 2011 | Philips 7140XL Electric Shaver
After soldering new batteries my shaver´s on-off switch won´t wor
it sounds like you may have some sloppy solder which is causing a continuous connection here there shouldnt be
Dec 24, 2009 | Norelco Rechargeable Cordless Men's Razor...
Health & Beauty Logo
62 people viewed this question
Top Philips Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Philips Health and Beauty Expert? Answer questions, earn points and help others
