Question about Stihl Ts 510 760 Cut Off Saw Repair Manual
Why does the stihl ts 510 have two fuel tanks?
2 Suggested Answers
SOURCE: hi there; my stihl ts 420 does not start easily
replace the decompression valve. also check for carbon buildup on top of piston. usually when a saw stops on its own after 5 min or so.... the piston and jug are scored and need to be replaced.
Posted on Aug 03, 2010
Stihl ts 510 rope kick back really hard ?
Does it start and run.? Is this just a recoil issue.? Do you use the decompression button on start up.?
May 28, 2016 | Stihl Saws
I have a stihl ts 410 that runs but after use it floods with fuel and then won't start till I have vented it
Sounds like a faulty fuel tank vent, creating a vacuum lock. Replace the vent
Feb 16, 2016 | Stihl Saws
Bt 360 stihl
possibly a fueling issue, check fuel filter, tank vent and possibly replace carb diaphrams.
Feb 25, 2014 | Stihl 08s Ts 08 350 360 Bt 360 Clutch Hub...
Wont start-is getting fire&carb is rebuilt flywheel pinis ok
Check you fuel line configuration. More than one time they've come in with the fuel lines exactly backwards.
Jan 16, 2014 | Stihl Ignition Module Coil 050, 051, 076,...
I can't find a Stihl TS08 Cut off saw manual anywhere online so I can get the parts I need to use it.
Hello. STIHL Canada doesn't list either the 510 or the 760, it seems to be a STIHL USA item (??)Here is the link for the manual. It is about 1/3 of the way down the page listed under the heading " Construction Tools ", on the right hand side.
Let me know if this helped out.
http://www.stihlusa.com/information/info_product2.html
Jun 01, 2011 | Stihl Ts 510 760 Cut Off Saw Repair...
STIHL TS760 cut off saw repair manual needed
Hello. Found the link for downloads, they also have contact info should your model not be online. http://www.stihlusa.com/information/info_product2.html
Hope this helped.
Mar 18, 2011 | Stihl Ts 510 760 Cut Off Saw Repair...
I need to replace the gas hose that goes to the crankcase on a stihl ts760 . Whats involved in doing this repair
This is not difficult. The impulse hose as it is called presses on to a brass fitting under the intake manifold. remover the filter housing, filter, carburetor, and tank as needed to make room to get in and replace it. Parts can be ordered from you local dealer like www.arcolawn.com
Hope it helps
Joe
please vote me up if it did help.
Jan 11, 2011 | Stihl Ts 510 760 Cut Off Saw Repair...
STIHL TS 400 won't start
I just repaired one with a similar problem--not getting enough gas. Two things corrected it and both were carb related. First I replaced a rather stiff diaphragm with a new one and second I reset the intake valve to allow more fuel into the carb. That solved it. Good luck.
The gas filter is weighted and should remain at the low point in the tank so it is an issue only when you are about to run out of gas--unless gas has been sitting in the tank for a long time. That can leave a film on the filter that can restrict fuel flow. Pull the fuel filter from the tank and scrap lightly on the filter. You will immediately note if there is a film on it. If so, replace the fuel filter.
Mar 15, 2009 | Hand Tools
Stihl Ts 510 760  Cut Off Saw Repair Manual Logo
Top Stihl Saws Experts
Joseph Mueller
Joseph Mueller
rlev_7
Level 1 Expert
Spud Howell
Are you a Stihl Saw Expert? Answer questions, earn points and help others
