Question about Sunbeam 5891 Bread Maker
Kneading Blade chattering
When in kneading cycle, the kneading blade makes a sound like the gear is slipping, checked all parts and they're in place what do i do?
  • 1 more comment
  • Anonymous Jan 02, 2009
    Same deal here. 1st time out of the box too. The grinding was loud and the mixer acted as if it were under a load.
  • shortcake27 Jan 04, 2009
    Same thing. First time it worked fine. Tried to make a loaf of French bread today and it sound like the gears were slipping. My husband took a look at it and could make it stop by putting pressure on one side of the pan.
  • spadawah Jan 15, 2009
    When I look through the top, it seems that the stirrer is slowing down when the bread dough gets really thick. So whatever bit is making the stirrer go round and round is grinding because it keeps going and the stirrer is stopping against the thick dough....I don't know what to do to fix that, though. Just out of the box, mine is grinding really loud after about 1 hour (3.5 hour process for my loaf) and I'm not sure if I want to listen to it for much longer!
  • 3 Answers
I had the same problems with another manufactures model. I found that the bread pan needs to slot in the machine only one way. The pan will fit in the machine with the handle both vertical and parallel to the front. However to stop the clacking noise I found that one way in the machine..it makes noise, the other way it doesn't. You'll have to try. If it makes noise, open the lid and turn the bread pan 45 degrees in either direction and secure it back in the breadmaker then close the lid. I hope this helps. If it does, remember how the pan is in the machine for next time to avoid the noise.
Posted on Jan 18, 2009
Is there a spring that fits on the shaft/kneading blade?
I doubt if there was a spring on the kneading blade. It does sit a little bit loosely, this is normal
Jun 01, 2015 | Kitchen Appliances - Others
My AFK breadmaker suddenly stopped kneading. The blade makes a sound as if something is holding it from turning. I mistakenly put the wrong amount of water which was less than I should have put into my...
Sounds like something is stuck under the blade, are you lifting it out and cleaning it every time after use? Cooked bread gets stuck under the blade if not and will stop it moving freely.
Jan 29, 2015 | Kitchen Appliances - Others
How do you keep the kneading blade from being baked into the bread?
Hi, You can take the kneading blade out of the machine after the last kneading cycle and before the final rise. Take the pan out of the machine to do this just to be on the safe side, Hank
Dec 06, 2010 | Sunbeam 5891 Bread Maker
I have an old toastmaster bread machine model 1154, and I realized that the kneading blade does not rotate when the ingredients are in the bread pan. Either the kneading blade mounting shaft and the...
If the spindle is turning and the paddle is not then your paddle is worn out and probable slipping on the spindle. If the spindle isn't turning then your problem is underneath the pan or inside the drive and your paddle may be fine.
Dec 01, 2010 | Toastmaster Kitchen Appliances - Others
Only 1 Kneading Blade is working. The other stops
Hi, Could be the belt is slipping or is worn for that paddle. Belts and motor are located in the base of the machine. Hank
Mar 21, 2010 | Zojirushi BBCC-V20 Home Bakery Traditional...
We lost the kneading blade for the Breadman Model N TR520
HI
Go here for spares
https://secure.prodregister.com/prodprotect/applica/bm.shtml
Feb 11, 2009 | Breadman TR500 Bread Maker
Kneading blade stays in bread after cooking.
This sometimes happens. I have a Panasonic.
When you place contents in pan with some machines it is important to place contents
in a particular order. I should try to keep contents away from the kneading blade as you place them.
Another thing that might possibly help is to put a litter olive oil around the blade before adding ingredients.
Hope that this helps
Alleillia
Dec 02, 2008 | Breadman Kitchen Appliances - Others
Sunbeam 5891 Bread Maker Logo
730 people viewed this question
Top Sunbeam Kitchen Appliances - Others Experts
Are you a Sunbeam Kitchen Appliances - Other Expert? Answer questions, earn points and help others
