Question about Ruud UAKA037 Air Conditioner
Need trouble codes for rudd urka a048jk10e unit?
2 Suggested Answers
  • 288 Answers
SOURCE: Gas furnance would only operate for about 3-5
the rollout switches will be located at the ends of the burner assembly and will have a manual reset. they must be manually reset to ensure that the problem has been corrected. Most units will go into a soft lockout for a time and eventually a hard lockout if the problem persists. Go to tempstar.com and go to their troubleshooting section for a gas furnace. the codes they give are pretty common for alot of furnaces and see if they help
Posted on Dec 15, 2009
How do I locate the aux limit switch on a rudd urka gas furnace?
Been awhile since I worked on one, but here goes. Should be 2 rollout switches on burner assembly and another in blower housing. Most are resettableand have a red button to reset.
Nov 19, 2014 | Heating & Cooling
Where is the auxillary limit on a rudd urka gas furnace
Should be 2 by burners and another in blower housing. Also purge motor/inducer fan has to pull slight vacuum to complete circuit.
I have a Rheem a/c - heating unit. Model # RKKA A048JK10E. When I turn the heater on the blower does not come on. But it comes on when the A/C is on.
Check your T-stat is programmed correctly. If you have a heat pump your stat should control the blower if you have a gas fired heating system your unit should control the blower.
May 16, 2011 | Heating & Cooling
The gas sometimes ignites and the goes out and
Check out my tip. I think it will fix your problem.
Jan 04, 2010 | Heating & Cooling
Meaning of rudd furnace trouble codes
Error Codes
A green LED indicates system faults
Steady On: System OK
Steady OFF: Board control fault or no power applied
1 Flash: Ignition failure (control in one-hour lockout)
2 Flashes: Pressure switch fault, fails open (switch is
stuck open)
3 Flashes: Limit switch open (main or auxiliary)
4 Flashes: Pressure switch fault, fails closed (switch is
stuck closed)
A yellow LED indicates flame status
Steady on: Normal flame is sensed
Flashes: As flame weakens, frequency of LED flashes
increases
Dec 12, 2009 | Heating & Cooling
The flame rollout switch keeps kicking out. Theirs no flame rollout,i put new burners in it, everything looks good. unit may stay on and run for 3 or 4 cycles,and sometimes it wont stay on 30 seconds.Ive...
Try adjusting gas pressure. There might be an inline rollout switch that looks like an inline fuse. If that is the case several techs might over look it. The best thing to check is the schematics for the furnace in the owners manual. If you follow the low voltage, you will definately see if there is a rollout switch. If it is a new unit it has one somewhere. If you paid a company to change the burners, call them to get your money back. I have only changed burners on old janitrols where there was a factory problem with the design. They are a stationary device that has no moving parts and therefore very rare if they break. The tech probably did not know and got nervous. Call the comapny and talk to the manager about the problem. You should not have to pay for parts that were not broken.
Gas furnance would only operate for about 3-5 minutes then turn off. Replaced gas valve on furance for a Rudd comerical A/C 4 ton unit model UKKA-A048JK10E. Now the blower fan turns on but the igniator and...
Dec 10, 2009 | Ruud UAKA042 Air Conditioner
Weatherking WRKA heat not working control board
U need to supply more info.There will be a sticker on the furnace likely in the lower Fan Compartment which will have a legend that explains each error code...ie: 3 blinks = Pressure switch etc....and u will need to provide more info on how the furnace is operating (whats it doing ) when it stops working or just prior to that
Oct 16, 2009 | Heating & Cooling
Ruud UAKA037 Air Conditioner Logo
122 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
