Question about Whirlpool 3.2 cu. ft. Plus Washer
Fsp 3948297 will not spin and water won't drain .
TheMobilian
  • 8220 Answers
SOURCE: The spinning thing won't spin
The motor has a double pole on it. The pump is driven on one side of the motor. The basket is driven on the other end of the motor. So if the water is pumped out then the lid switch is fine. What you have is a broken drive coupler. Usually breaks on a heavy load like rugs or quilts. Low water on a heavy load can break it too. Or simply old age.
Video:
Repair manual and more photos HERE
Posted on May 07, 2011
TheMobilian
  • 8220 Answers
SOURCE: my washer is stuck in the spin position.... it
Lidswitch:
Video:
Bonus goodys
More here
Posted on Jun 15, 2011
Jahn27
  • 1554 Answers
SOURCE: Whirlpool Cabrio he washer stopped
You may perform an automatic diagnostic test to check the machine functions and view any saved fault codes. Fault codes may also appear during the test when a problem is detected. Be sure the washer is in standby mode (plugged in with all indicators off, or with only the Clothes Clean or Done indicator on). Select any one button (except POWER, START, and STOP) and follow the steps below, using the same button (remember the button):
If this test mode has been entered successfully, all indicators on the console are illuminated for 5 seconds with 88 showing in the Estimated Time Remaining two-digit display.
The program then automatically checks for saved fault codes. Record the fault codes and post it back.
Press the same button used above in activating the test to advance through the automatic test steps. The basket must be floating in order to agitate. Allow step C1 to complete before advancing to the other steps. Record any fault code shown during the tests and post it back including which step the code is displayed.
You don't have to accept or reject this post in order to add comment or information. But accepting the solution should you find it helpful and/or informative will not stop you from posting comments or additional information. You can still communicate with the expert should you need further advice regarding the issue stated herein.
Posted on Jul 20, 2011
SOURCE: WASHER FILLS WITH WATER, THEN WON'T AGITATE.
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Posted on Jul 23, 2011
caroldon
  • 17130 Answers
SOURCE: The washer fills agitate but won't spin & drain
Possible fault with the program controller unit. You need to check the program cycle outputs using a multimeter connected to measure the output voltage. On start the inlet should open and then close as the water level sensors works and then proceed to wash. So this much seems OK. Now in the next step the drain valve must open to drain off, then fill once again with the inlet working and water level being sensed. If there is no output in this section cycle then the prrogram controller has errors within the memory . You can remove the panel and reset all connectors and connections.
Posted on Oct 30, 2011
Figidaire FTF630as0 won't agitate. The door locks and water drains but won't agitate or spin
Hello Tina Kaha - Often when a unit does not spin, it is because the unit cannot properly drain and dispose of the water and detergent solution. Does the unit make a humming noise? If so, the drainage hose/pump may be clogged and needs to be cleaned. If not, the washer may possibly be experiencing an issue with the door lock assembly, faulty pump, timer or control board not communicating correctly. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair the unit.
Apr 19, 2013 | Frigidaire ATF6000ES Front Load Washer
My washer won't drain the water when it spins to rinse cycle and it won't drain when it's on the spin cycle
there is a screen that needs to be cleaned out on the bottom under the wash drum
Jan 15, 2013 | Washing Machines
My Frigidaire Affinity front loading washing machine model #ATF6000FS1 won't spin when loaded.What's the problem?
sounds like you have something in your pump stopping the water draining it will not spin with water try unblocking the punp
Sep 27, 2012 | Frigidaire Affinity Washing Machines
GE WSXH208V1WW
Usually when you have a washer that will not drain, first check if the drain hose is kinked or too high above the washer (8 ft is the limit of the washer pump). Next check if there is a blockage in your drain (often a stand pipe) or if the air can't get into the stand pipe. The final thing to check is for foreign objects in the pump to drain hose area that block the drain. (This requires getting into the pump and disconnecting the hose. Keep a bucket ready to catch the water that will pour out of the washer.)
GE has the manuals for many of their appliances on their support site: http://www.geappliances.com/service_and_support/literature/ . Enter the model number and click submit. The direct link to the manual for the WSXH208V1WW is http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-90256.pdf .
I hope this helps.
(at least my washer won't spin if the water can't pump out. On a few washers (non-high efficiency) the solenoid has failed to open for the pump to drain the water.)
Nov 22, 2011 | Washing Machines
Washing machine won't rinse and the water won't drain out.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 04, 2011 | Washing Machines
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
Front loader won't spin and is filled up with water. Won't drain.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
May 15, 2011 | Kenmore Energy Star 44092 Front Load...
Won't spin out the water
If your problem is that it won't go into an accelerated spin cycle at the end, check the settings. Most washers just let water drain out the bottom when they have finished cleaning.
May 15, 2011 | Washing Machines
Wm2455hw will not spin
Make sure door mechanism is working at fine. So next is to check whether the motor tumbles both directions.
The spin bearing might be a problem, but normally you'd hear a problem here first. Have you heard any freight trains passing through the house in the spin cycle?
One thing to check for this problem is the spin speed switch. If the spin speed switch is bad then the control won't know how fast to spin, and so it will just not spin at all.
The drain pump must be draining all the water out. If the water doesn't drain out then the pressure switch won't read empty and that might prevent a spin cycle.
I hope this helps.
Please reply with additional details for further assistance.
Shane
Apr 22, 2011 | Washing Machines
Whirlpool 3.2 cu. ft. Plus Washer Logo
Dan Webster
Dan Webster
Sal DeAngelo
