Question about Sony Playstation 3 (PS3) Console
Ps3 internet connection
I had a single internet connection and either ps3 or pc went online ok. i bought a netgear 5 port switch so i can have them both online at same time but only pc is working. ps3 says DNS error (80710102). have tried swapping ports but still only pc works online! please help
  • 643 Answers
Here is the code to enter at DNS 4.2.2.2 and 4.2.2.1
Posted on Jun 02, 2009
Tip
Port Forwarding for PLAY STATION on NETGEAR routers
The following steps will help you forward ports on the NETGEAR router for Play station network (PS2, PS3, PSP). At time you can not access or play online games through your PS and in such cases you need to make sure that you have the required ports forwarded on your router as mentioned below. The below steps are applicable for NETGEAR router model WGR614, WGT624, WPN824, WNR2000, WNDR3300, WNR854T, WNR834B etc
1. Open a browser (Internet Explorer, Mozilla Firefox or Safari) on your computer connected to the router.
2. Access the router, usually by typing 'http://192.168.1.1' or 'http://www.routerlogin.com' in the address bar.
3. Login to the router (Username = admin and Password = Password unless you have changed it).
4. Click on Port Forwarding under Advanced.
5. Click on 'Add Custom Service' button.
6. Specify any name for the service (PSN1). Select Service Type as TCP/UDP
7. Specify the Start and the End Port as 80.
8. In the server IP Address specify the ip address of the PS3.
9. Click on 'Add' button.
10. Follow the same steps to open the below ports
Start = 443 End = 443 use name as PSN2
Start = 5223 End = 5223 use name as PSN3
Start = 3478 End = 3479 use name as PSN4.
Start = 3658 End = 3658 use name as PSN5.
Start = 10070 End = 10080 use name as PSN6.
Click Apply.
These steps would allow you to access online games on your PS connected through the NETGEAR router.
on Mar 18, 2010 | NetGear WGR614 Router
Problem connecting to internet while pc and ps3 are hooked simultaneously
I think the broadband connection you are using is not enabled for NAT ( Network Address Translation).
This is required to give internet access to more than one system through a single internet connection.
If NAT is not enabled or supported by your broadband router then you cant access internet through more than one system simultaneously.
Jan 07, 2011 | NetGear FS605 (FS605SE) Networking Switch
Internet doesn't stay consistently connected
belkin is famous for dropping its signal for no apparent reason, in my findings and dealings with several routers i have found "netgear" to be the best company not just for their products but for their customer service and tech support as well
Dec 31, 2009 | Belkin F5D7234-4 Router
PS3 online game (NFS Undercover) not working on new router.
I might advised you to call the PS3 manufacturer to gather the ports of the PS3 then you'll needing the help of netgear provider to open the ports of the PS3 to the router, so that the PS3 will allow to the firewall of your router.
Mar 11, 2009 | NetGear WGR614 Router
My Netgear WPN824 v2 router won't work with my ps3?
hi, try setting a predefined setting
Ip adress : 192.168.1.200 ( or any number not used by pc )
Dns : 192.168.1.1
Gateway : same as DNS
Feb 28, 2009 | NetGear RangeMax WPN824 Wireless Router...
I bought a netgear FS605 swtich and it doesn't work on the ps3.
Yes you must by a router my friend.
The problem is your ISP will not give out extra Ip addresses for additional clients. The router will have a dhcp server built in and that will fix the problems at hand.
Feb 20, 2009 | NetGear FS605 - 5-Port 10/100 Network...
Router failed numerous times so i bought a netgear fs605 5 port switch to hard wire in a ps3 and my dell lap top. can only run one or the other. not both at the same time. what is wrong?
The FS605 is a switch, not a router. You can only run one device at at time because you only have one ip address. You need a router between the internet and your switch if you want to use more than one device at a time.
Dec 08, 2008 | NetGear GS605 5x1000 Mbps Networking...
Ps3 wired connection
Hi There.
If your PS3 is Networked upto Your PC to use the internet connection, You have to allow the PC to share its Internet connection with yout PC, Do this By going into Network settings, Checking the properties of your LAN card in your PC. and clicking on, "share my internet". This should alleviate that problem..
Or.
If your PS3's Wired connection isnt working. but your PC one is, Try moving your PS3 Lan cable into one of the other Free LAN Ports (if available) or Try Switching the PC cable over to the PS3's Port in the Router, and Visa-Versa !
Oct 27, 2008 | Sony Playstation 3 (PS3) Console
Just hooked up ps3 wirless , gaming is slow
if your PS3 is closer than 20 feet from your router, then its unlikely to be your signal strength.  However, Wireless connections tend to "poll" their connected hardware. What I mean by taht is.... The router sends out a signal, just to check and make sure all the peripherals are still there.  I dunno about PS3 yet, cos I havent tried to game online, but I am an avid PC online gamer, my pc is within 5 feet of my router and Ive switched back to LAN cable to play.  I was experiencing periodic "lag"... due to that polling effect.  Try using the LAN cable and see if that makes a difference ( I dont know how many Ethernet RJ45 connections a Netgear has, ... if it only has one, you may need to connect a "switch" )
Oct 28, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
83 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
