When the phone is powered off press the Up Navigation key and the Power key at the same time
Storage and setting are wiped clean, eject the microSD memory card before doing a hard reset.
or
You can reset your phone’s settings and
clear all added data from memory.
Resetting
the Phone
1. On the Home screen, press the Start
soft key 2. Select Settings > More... > Security
> More... > Reset. 3. Enter the reset
password and press the Done soft key. The default password is
0000. 4. Press the Yes soft key to confirm. The phone resets
and reboots itself.
I had an ETC Unison DR rack with house lights and spot lights, wall controls and a DMX input dimmer...
(More)
I had an ETC Unison DR rack with house lights and spot lights, wall controls and a DMX input dimmer system but it broek down. So now I'm looking for a new dimmer system. What I', looking for is:
- 2 or 4 chan
- dmx in and out or through (I can work with whatever connectors, 3/5 pin etc)
- each chan able to handle a S4 with 575W lamp
- Pack able to handle all lights all the way on.
Any recommendations on approach or specific packs or brands (or packs/brands to avoid)?
when my dimmer switch is turned on, the light comes on at full strenght then about 5 seconds later...
(More)
when my dimmer switch is turned on, the light comes on at full strenght then about 5 seconds later it dims to half strength on its own. how do i fix this? i have replaced the switch and it is still doing the same thing.
Need to replace a prescolite ht10u-3p 3way touch slide dimmer 8.3 amp 120 volt 60 hz 1000 watt max....
(More)
Need to replace a prescolite ht10u-3p 3way touch slide dimmer 8.3 amp 120 volt 60 hz 1000 watt max. Is this product still made and if not what should I replace it with ?
Maestro MA-600 the actuator assembly that operates on/off and brightness settings micro switches on...
(More)
Maestro MA-600 the actuator assembly that operates on/off and brightness settings micro switches on the circuit board has broken, electonically the device still operates from the remote switch, ? can I order or request a replacement part?
Yes I have disassembled the dimmer. An electronic-electrical engineering degree with a background in Instrumentation calibration and repair, including analog and digital controllers. I have dissasembled micro-switches and repaired them. I have also relaced and repaired the hair-springs in 50-micro-amp movments.
I have a headboard with 2 westek 6043 touch dimmer lights. When I use the touch pad for one light,...
(More)
I have a headboard with 2 westek 6043 touch dimmer lights. When I use the touch pad for one light, it also turn on/off the second light. I have separated the 2 touch pads and I have each transformer plugged into a separate outlet. Any suggestions?
