Question about Sharp Half Pint Microwave Oven
What is the required input watts on a Sharp R4055 microwave?
Model R4055
MicrowaveSvc
  • 9098 Answers
SOURCE: Sharp microwave oven model r-1440 runs, but doesn't heat food
Assuming your inside light and turntable come on when you try to microwave, with the symptoms you have, I would most strongly suspect a bad magnetron or a loose and possibly corroded connection on the magnetron's terminal.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html
(if it's not shorted or burned, it'sprobably okay)
http://www.gallawa.com/microtech/mag_test.html
The best place to order parts for this brand is Encompass (formerly Tritronics).
Or you can call them toll-free at 866-779-5835.
Posted on Feb 08, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: The number display on my Sharp R-515EK 1200 watts microwave oven
We regularly repair these control / display units for customers nationwide by mail for $39.95 postpaid in about a week or so with a one-year guarantee.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Posted on Aug 31, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: i require the drive motor shaft for sharp
Parts distributors for this Australian model can be found here.
Posted on Nov 29, 2009
  • 8404 Answers
SOURCE: i have a sharp microwave-convection model
800 or 1000 are standard wattages. It should say on the plate on the inside 'doorway' of your oven - that is where I find that info on my sharp microwave. It could be on the back but, like I say, normally inside the 'doorway' to the oven
Posted on Dec 27, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: I need a new transformer
The part number has been changed to RTRN-B098MRE0. You can find it new on the Sears parts site and at Encompass parts. There's a used one available on eBay for quite a bit less. Given its cost, when the high-voltage transformer fails, most people find it's cheaper to replace the oven.
Posted on Jul 14, 2011
My microwave stopped working you can input time but when you push start nothing happens it has power and everything just will not start its like the start button does not work
Possibly a bad door switch behind the holes where the latch hooks go into. Usually with the bad switch the timer counts down but nothing runs. It all depends on which switch is bad. Usually 3 switches inside.
Apr 13, 2015 | Sharp R530EWT Countertop Microwave Oven...
Get a replacement bulb for sharp carousel microwave table top oven .
A quick look at the manual doesn't specify the part #. It just says replace with the same type and not more than 30 watts. http://www.sharpusa.com/downloads/archives/product_manuals/mic_man_r1500_1501.pdf
Here is a link to an online parts place that you can enter with your model #:
Replacement Sharp parts Select from 266 models Microwaves
Dec 08, 2014 | Sharp Microwave Ovens
What is the wattage of model R-9H84B
That model had 900 watts of microwave power output, and the convection outpout was 1450 watts.
Jun 18, 2011 | Sharp R-9H84B Microwave Oven
Please send ma operating Manual for Sharo R248H 800 watt Micro Oven.
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers for spare part supplies as required.
The information is normally free of charge.
I hope this helps.
Jan 04, 2011 | Sharp R-1870 Convection/Microwave Oven
What is Sharp R-254 800 Watts Microwave Oven??!?!?!?!?!?!?!?
Sharp represents the Manufactures.. R-254 is the Model no. and 800 Watts represents the output power of the microwave.
Jun 09, 2010 | Sharp R-254 Microwave Oven
Using iphone ipod with compact audio system.
If your audio unit has an audio input plug and an auxillary function, you should be able to run the 3.5mm jack from the headphones socket on your iphone to the audio input of your audio system, then select aux on the audio system and you should be able to hear any music played on your iphone through your audio unit. Good luck.
Jun 07, 2010 | Sharp KB6024MK 1000 Watts Microwave Oven
Model 26961 rated 13 amps. about how many watts would that equal?
the unit has a rating usually on the inside label ior the door somewhere...
you know the voltage allready... 120... multiply the 13 amps x the voltage... and presto 1560...
you can multiply that by .707 and get the RMS value... 1102
so I consider the microwave to be a 1000Watt unit... pretty easy... bu8t you wonder where did I get the numbers... like .707...
It's to compensate the peak to thr RMS... root mean square... lets just call it "Average"
May 06, 2010 | Sharp Model: KB6025MK Microwave Oven
I have a Sharp model R-3A52,old but still cooks well. How do I know how many watts it is? I need to know how many watts my oven is?
The power of the magnatron should be on the door it will be about 750 watts. You could check sharp website to get it spot on...
Apr 06, 2010 | Sharp R-1470 Microwave Oven
Sharp Half Pint Microwave Oven Logo
32 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
