Question about Hotpoint  16.6 Cu. Ft. Top-Freezer Refrigerator
Freezer warms and then cools
The freezer will warm up to about 30 deg and then will go back to 0 deg. This happens every 2 to 3 days.
  • 232 Answers
Check doors close easy good seal, is condencer coil under frige cleanit front and back make sure to put cover back on very inportant on most models set controls at factory rec setings
Posted on Jul 01, 2009
  • bill williams
    bill williams Jul 01, 2009
    when its 30 check freezer fan is it running as good as when its 0
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 531 Answers
Check condenser fan
Posted on Apr 06, 2009
GARF19XXYK00, doesn't cool properly, 36 - 40 deg. F on coldest setting. A & E just replaced the bi-metal , defrost part, thinking the defrost keeps it too warm, but guess what, still the sam
There is a TSB on this (TSB) = Technical Service bulletin. You need a service company to order part number W10599551 and put it on. This will fix the problem.
Feb 01, 2013 | Whirlpool GARF19XXYK 19.0 cu. ft....
GE Profile Side-by-Side Refrigerator - Freezer Warms Up - Motor Gets Loud - Eventually Cools Back Down
Sounds like your thermostat is faulty this should be covered by a warranty This problem eats electricity so will need attention asap
Oct 29, 2012 | GE Profile PSHS6MGZSS Side by Side...
I have a frigidaire side by side refridgerator / freezer. Currently my freezer is about 34 to 40 degrees. The dividing wall between the ref. and freezer is warm to hot depending on when you check it. ...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 03, 2011 | Frigidaire FRS26H5AS Side by Side...
Hi, I just received a Zanussi Mini Chest Freezer from a friend. I plugged it in to start the cooling process as it had been unplugged for a few days. The outside is very hot. Is this just an initial set up...
Hi there
These chest freezers have their condenser just under the skin of the case, so if its been off for a while it may feel very warm for a couple of days.
After this the temperature of the skin depends on the temperature of the surroundings, normally 20 deg f to 30 deg f above air temperature
Regards
Gordon
Apr 22, 2011 | Refrigerators
My ice maker does not make ice anymore.
if freezer is too warm it would cause this ck tempt it must be 15 deg or colder . 0 to 5 is best . if too warm / clean the coils an make sure fan is going . . also ice build up in back of freezer may be problem ..mm
Oct 24, 2010 | Roper RS22AQXKQ Side by Side Refrigerator
Refrigerator (Samsung RS2555SL) quit cooling on both sides. Front panel was blinking at set temperatures (34 fridge side/0 freezer side) but inside was warm. I unplugged for 5 min and ran self-diagnostic...
hello dont know if you have the same model
but this may be worht a look
samsung fridge freezer problems
http://www.youtube.com/v/RP9XLji-gdw?fs=1&hl=en_GB&color1=0xe1600f&color2=0xfebd01"> name="allowFullScreen" value="true">http://www.youtube.com/v/RP9XLji-gdw?fs=1&hl=en_GB&color1=0xe1600f&color2=0xfebd01" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344">
Sep 28, 2010 | Samsung RS2578BB Side by Side Refrigerator
Freeaer and refrigerator warm
Check and clean the condenser coil in the back behind a removable panel. after cleaning make sure you replace the panel. Check the back inside wall of the freezer compartment for frost build-up. If there is frost on the back wall you have a defrost system problem.
May 23, 2008 | Maytag Refrigerators
GE PFS22MISBBB freezer not cold enough. Temp won't reset.
replace the fan as quickly as possible it may be shorting and causing damage to your control board,
Mar 30, 2008 | GE PFS22SBSSS Stainless Steel French Door...
Frost in freezer compartment
It is possible to get this build up in the return vents.  Check seals for any possiblilty of warm air getting into the fridge.  Warm air getting in will cause this.  For now use a hair dryer or some hot water to clear the vents.  Let me know what you find.  Would appreciate a solved rating for expert advice.
Oct 17, 2007 | Refrigerators
Hotpoint  16.6 Cu. Ft. Top-Freezer Refrigerator Logo
149 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
