Question about Miller Welding Tools
Millermatic 185 welder circuit breaker number 1 keeps tripping
  • 3 Answers
SOURCE: mig welder tripping power supply
the breaker could be bad. try to change the breaker
Posted on Jan 16, 2009
  • 48 Answers
SOURCE: humms and trps breaker clarke welder135sg
Most likely one or more rectifer diodes shorted and now need to be replaced. A $5 volt/ohm meter could do it if you take the welder somewhat apart enough to test each diode and find the bad one. Since the diodes are swaged into the aluminum heat sink plate and one can not normally re-swage the new diode into place, I would just replace the diode with a stud type case of the same voltage and current rating. The stud case will allow you to drill a hole into the aluminum heat sink and mount the diode to it with a nut. $25 or so should buy the diode. Digikey.com will have the diode if a voltage and current rating can be found for it.
I read on this website that Clarke has filed for bankruptcy and there is more than one query as to where their website is so getting genuine Clarke parts might not be even possible. Getting the required part information for a diode swap is also up in the air?
Posted on Jun 19, 2009
SOURCE: I have a Hobart 135 Handler wire feed welder that
Get a volt meter, go to ohms setting , check transformer to ground for low to zero ohms reading. also look closely at transformer windings for foreign objects in between them, never know what you my find. If transformer is shorted to ground probably time to say some nice words over it before burial. Also just for kicks try a new gun on it, (there is a reason i'm asking you to do(this) see if you can find someone that has spare. A good honest repair shop would probably be reasonable if all else fails. to a least let you know if the transformers a problem. good luck
Signed
Former Miller Certified Tech.
Posted on Aug 20, 2009
ampman
  • 98 Answers
SOURCE: Hobart Handler 175 230 Volt Mig trigger
also do you hear any clicking when you depress the trigger?
You should. If nottry to jump the trigger wires inside themachine right where it goes out to the "gun"wires? worksnow? problemis in the gun cord somewhere.
Still not working? CHeck the contactor. SOmetimes a boxelder bug will get inthem and prevent them from working, or the contacts fry themselves.
Posted on Oct 01, 2009
witmoz
  • 389 Answers
SOURCE: I have a miller 251 millermatic welder that has no
check the wireing from the gun to the servo,it may have got damaged.then test the servo
Posted on Sep 02, 2010
Wire schematic
If the welder is single phase 110v use a dedicated 20A standard household circuit. If 220v single phase use a 50A RV or weld receptacle connected to a 50A dual breaker with common trip. Make sure the breaker is the same brand as your panel. If the welder is 3-phase connect the wires B-O-Y (Brown Orange Yellow) at the breaker (3 phase 50A) and see if a color code match can be applied at the welder, although the only issue is whether the wire feed will run forward or reversed. If the wire feed is reversed then move any two wires of the B-O-Y set to change the rotation.
Aug 25, 2014 | Welding Tools
My SIP ideal 240v mig welder keeps tripping garage and/or house power, what's wrong?
welder drawing high current.sounds like a earth problem with the house or the unit.
Aug 14, 2014 | Welding Tools
Bicycle serial number location
The serial number is usually printed on the sides of the Millermatic 200 MIG Welder. You may also want to check at the back on the sticker for the serial number. If you cannot locate it, try the owner's manual or contact any of the local dealers for more inquires.
Apr 21, 2014 | Miller Welding Tools
Welder when turn on trips the breaker
Would you write back and clarify what steps you have taken to narrow down your search? I'd like to know if the breaker is weak and needs to be replaced. Have you plugged your welder into another receptacle to see if it trips that breaker? I don't think the trigger has to do with this problem. The symptom is that as soon as you turn the welder on, it then trips the breaker. So this tells me that the electrical cord is not shorted. When the breaker trips, is there any delay or is it instant? If there is a delay, does it sound like it does while you are welding? Do you hear that "Transformer, buzzing noise"? The trigger activates the feed motor, that alone isn't enough to trip this breaker. Which make and size welder do you have? I really am dependent on detailed information, you are my eyes and ears. Please write back with any questions or new details and I'll do my best to help, good luck.
Mar 15, 2014 | Welding Tools
Model 4001-ov trips the circuit breaker.
Assuming you have Paragon 4001 40 amp 120Volt timer
By-pass the timer so only pool pump is connected to breaker.
To do this, move wire from terminal 2 and connect to terminal 1.
If breaker no longer trips, then replace timer with Intermatic T101
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T101
Crossover wiring: Paragon terminal 1 goes to Intermatic terminal 1.
Paragon terminal 2 to Intermatic terminal 2.
Paragon terminal 3 to Intermatic terminal A
If breaker keeps tripping after bypassing timer, then tighten wires on circuit breaker and test again.
If breaker keeps tripping, then move wires to another same-size breaker.
http://waterheatertimer.org/How-to-replace-circuit-breaker.html
Breakers trip when they sense overheating.
If motor is causing problem, you might need electrician to track down source of overheating.
Jun 19, 2012 | Paragon 4001-0G Defrost Timer
On my millermatic 185 i pull the trigger and the wire comes out it does not arc against the ground, i tried it against the actual ground clamp, but it still doesnt arc
Is the ground clamp connected to the work piece?
if so, go through the trouble shooting section of the manual. If you don't have the manual, you can find info at millerwelds.com.
Mar 29, 2010 | Welding Tools
Mig welder tripping power supply
Dec 09, 2008 | Troy MIG100 90-Amp. Wire Feed Welder
Millermatic 200 will not weld
1 - Check the ground connection to the work, including the actual cable to clamp connection.
2 - Make sure that the wire feed rollers are nice and clean. The wire needs to be clean too.
3 - Check that the polarity changing wire connections are nice and tight, clean, etc.
4 - change and or service the contact tip at the end of the gun.
as always, gently clean out the loose junk inside the case. A clean welder is a happy welder. :-)
Nov 16, 2008 | Welding Tools
Welding Tools Logo
77 people viewed this question
Top Miller Welding Tools Experts
Kory Ronning
hubiam
hubiam
Level 1 Expert
John Trevino
Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
