Question about Maytag Freezer MQU2057
Technition called it freon noise
One year old Maytag bottom freezer refrigerator works fine but has a clicking and poping noise for a few seconds each time the compressor starts up. A technition put an epoxy type patch in the unit that he said might help. It did not.
model mbf1956keq
serial no. 11429896ne
  • K1971 Jan 31, 2009
    I have a maytag performa top freezer refrigerator. It makes this buzzing noise, then a pop noise; like it is resetting. The noise sounds like is coming from around the compressor at the back bottom of the refrigerator. It does is every couple hours or so. The freezer and refrigerator are staying cold. I'm not sure how old the refrigerator is, it came with the house and I've been here for almost two years and I can't find exactly what model it is.
  • Kris Seymour May 11, 2010
    hi, Hmmmmmmmmm! seems very strange? can you tell me where abouts the noise comes from? Inside? outside? only when the compressor starts up and is running?
    I might be able to tell you what could be the cause?
    Problem Solver:
  • 16 Answers
Sounds really strange to me. Not sure what kind of patch he could have used. I've never heard of "freon noise". Clicking and popping could be the thermal overload tripping and resetting. The unit should still be under warranty. I would contact them to get another tech and another opinion. It would be best to get this resolved before the warranty wears out.
Posted on Jan 04, 2009
Freezer light bottom not working,bulb good
Warranty time, call maytag, most fridge come with 1 year warranty.
Oct 27, 2013 | Maytag Ice2O MFX2571XE 25 cu. ft. French...
Water on freezer bottom. I have a Maytag refrigerator, side by side, Model MZD2768GEW, seven years old. Recently I have found about 1/3 cup of frozen water on the freezer bottom. It is not comming from...
Here is a tip that will tell you where the water is coming from and how to fix it. The drain hole has froze shut and the water from the defrost will not drain out.
Water Running in Refrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Aug 18, 2010 | Maytag Freezers
Top shelf not freezing
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r4588788-refrigerator_or_freezer_not_cooling_or
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Apr 27, 2010 | Freezers
"High wind" sound following defrost.
Freon running through the feon lines can make some odd noises, usually a gurgling or higher pitched noise. If your freezer works fine with no more strange noises, then don't worry about it. If you have temperature problems or continue to have abnormal noises, then see if your freezer has the 5 year sealed system warrantee that most freezers have. If it does, and it is under 5 years, then call Frigidaire to come out to check it out for free. If it is out of warrantee you will need to live with it or replace the freezer, since a freon sealed system repair is very high. Good Luck, Appliance Specialists
Feb 04, 2010 | Frigidaire 14.1 cu. ft. Upright Freezer...
Freezer will not freeze
replacing leaking evaporator on GE side by side. Watch this video to understand why its so expensive to fix freon leak issues.
Sep 25, 2009 | GE 20.3 cu. ft. / 575 liter Upright...
Problem with Maytag Chest Freezer model MQC1557aew.
First make sure than the condensing coil in the freezer is clean of dust and dirt(it is behind the grill vent in the bottom side of the freezer where the compresor is) If it is clough brush the dirt off after you unplugit.When is clean wait a few minutes ,5, and plugg it back at the GFI outlet and see if work If still tripped the outlet you may have to replace it.
Apr 04, 2009 | Maytag 14.8 cu. ft. / 419 liter Chest...
Freezer/Refrigerator tempurature swinging wildly
The compressor is overheating and not starting. Could be just the start relay. If this happens again try unplugging it for about an hour then it should work for a while. Heat between doors is normal this is an electric heater designed to keep the doors from sweating. You just noticed it because the refrigerator wasn't cold.
Jun 26, 2008 | Freezers
Maytag freezer
sure its on ly 3 years old. you rseled system should be covered for 5 years (compreessor, freon, evap, condesor). was it making a buzzing noise?? trying to start and clicking right off??? thaose are sounds a bad compressor makes,
Mar 19, 2008 | Maytag Freezer MQU2057
Maytag Freezer MQU2057 Logo
256 people viewed this question
Top Maytag Freezers Experts
John Tripp
John Tripp
christian nielsen
Ismael Rodriguez...
Are you a Maytag Freezer Expert? Answer questions, earn points and help others
