Question about Kenmore Refrigerators
Kenmore elite refrig model 596.73503201
Wont run
SOURCE: door handle is loose
If my memory serves me correctly, you should see two posts attached to the refrigerator door right now. The handle slips over these posts and if you look closely there is a little hole in the handle where you would insert a allen key wrench to tighten the little screw against the post protruding from the door itself. With the door handle in your hand, properly match up the correct allen wrench to fit the allen screw very snug. Realign the door handle on the protrucing posts and tighten. Once finished, you should have a tight fitting door handle again. Let us know if we can help further.....Eric
Posted on Feb 13, 2009
  • 103 Answers
SOURCE: my kenmore elite bottom freezer OK but upper
Hi: That's sears for you;They promise prompt service on emergency refrigeration. I'ts one of three things. Your defrost heater is out, your defrost timer is out, your freezer is so full of food you blocked the vents to the fresh food. I mentioned these in the most likely order. If you are not handy just empty the freezer and take a hair dryer to the back (being careful to avoid the plastic components) to melt the frost behind the wall that is blocking the air vents to the fresh food compartment. If you are handy look at your parts list or the breakdown at sears.com and find the heater. It will be behind the freezer wall at the bottom. See how it is removed and check it. It will be a glass tube with a metal coil in it. If it is broken it is bad and replace it. If it is ok look for the defrost heater and see where it is located. then replace it. Of course check to see if your food has blocked the vents first. I hope this helps, Jeff
Posted on Jun 21, 2009
SOURCE: Code on door says er dH on Kenmore elite refrig
This error code has something to do with a defrost sensor and happened after an extended power outage. I unplugged the refrig and it reset itself!
Posted on Jul 18, 2009
blueextc3221
  • 15935 Answers
SOURCE: kenmore elite 3 door refrig freezer with ice and
It appears your damper door or solenoid has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 30, 2010
  • 11 Answers
SOURCE: My Kenmore Elite refrigerator model 59673502200 not running.
the moter might have blown out
Posted on Feb 18, 2012
Kenmore elite model 52603100 freezer defrost water freezes in drain tube/plan then over flows to bottom of unit. freezes then water eventally runs on kitchen floor
You need to clean out the drain tube it's clogged that's why the water is freezing.Try using hot water and maybe something like pipe cleaners to get what's in there out.Hope this helps. On some models it may be easier to pull out the refrig from the wall and get to the drain from the back.
Jun 15, 2011 | Kenmore Refrigerators
No water coming from water dispenser.
It is possible the water control valve for that dispenser has failed and will not open. This happens a lot for those and the ice maker valves. All you need is the model number for your refrigerator and that will look like this for Kenmore. 213.564897 for example. and I will help you find the correct part number. Sea Breeze
Nov 24, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Jul 17, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
I CHANGED THE FILTER AND SET THE SETTINGS AND IT BEGAN TO WORK A FEW HOURS LATER THE DISPLAY WAS SHOWING ER NOW THE REFRIG. IS NOT COLD AND THE FREEZER IS NOT WORKING AND THE ICEMAKER IS NOT WORKING ALL IN...
If this is the Kenmore french door model with bottom freezer and ice and water in the door made by LG it could be that the mother board has failed.  Call for service and hope that warranty is still in effect.
May 19, 2009 | Refrigerators
Kenmore elite dryer model #110.63952102 start button wont stay on everything else works
I have the same problem with my Kenmore Elite dryer (model#110.74992300), and I replaced both the motor and heater relay and the problem solved. You can get the relay from www.mouser.com for $3 each. The model for the relay is T9AP1D52-48. You may want to open up the dryer to verify the relay model, it is printed on the relay.
Sep 20, 2008 | Kenmore Elite 20972
Refrigerators Logo
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
