Question about Philips 42PFL7422D 42 in. LCD TV
I have a Phillips TA2800 LCD TV (42 inches). It is out of warranty. Today it has suddenly stopped working. There are multi coloured vertical lines on the entire screen and not function works. There is no response to the remote control either. I have tried switching the power off for a while and restarting however it is still the same. I need to decide whether this is worth repair or should just purchase a new TV? (The technician will charge $120 to just have a look plus parts and labour). Any suggestions please?
zjut
  • 106 Answers
SOURCE: phillips 42" LCD Mod#42PF722OA/37
This problem is related to two failures, one is the Power Supply Board, another one is the Y-Main Board. Troubleshoot procedures:
1. Disconnect the Vs Power Supply cable from the Power Supply Board,
2. Turn on the tv and check the Vs voltage on Power Supply Board,
3. If the Vs voltage is there, then the Y-Main board failed.
4. If the Vs is not there, then the Power Supply Board failed.
Posted on Jan 19, 2008
  • 4234 Answers
SOURCE: phillips 42 inch tv
The stand base part number is 310430814621 and is available for $71.58 from tritronicsinc.com
Dan
Posted on Jul 30, 2008
  • 90 Answers
SOURCE: Our 52 inch Phillips Plasma tv is not working
open the back of the set and inspect the power supply board -- there should be two fuses on the board- they cost around 2 dollars at radio shack -- check all connections for wear or damage -- there are two boards in most televisions -- a power supply board and a audio / digital board -- one is probably board
Posted on Mar 03, 2009
SOURCE: Phillips 42FD9954 plasma will not turn ON
I have a Phillips 42FD9954/17S and every time I try to turn it on I also get the power red light blinking and sometimes it will try to turn on with a bunch of clicking noises and it will be green for a while then turn red. What I do and its very weird but works, put a blow dryer on hot and blow it under the tv on the side of the power button for about 10 minutes and it will turn on. I took it apart and there is a heat sink that if i put the blow dryer directly onto it on heat it turns on in less than a minute. Can someone tell me how I can fix this heat sink? I cant take it off. I want to put some thermal compound to see if that works. Give it a try I promise it will work. The Red Light has to be on put the heat on it and then press the power button, if you hear it clicking and green then back to red you are almost there. Keep putting heat on it and it will turn on.
Posted on Mar 31, 2009
SOURCE: Phillips 50 inch Plasma
Philips 50 inch plasma tv no video but has sound
Posted on Sep 21, 2009
My 42 in phillips LCD flat seen has a black horizontal line toward the bottom how can I fix this.
Samsung LN46B650 Thin Black Horizontal Lines - Forums - CNET
www.cnet.com > Forums > Samsung
CNETI'm experiencing thin black lines from the top of the screen to the bottom. ... by babes808gpa / January 15, 2010 1:42 AM PST ... lines are about 1/4 inch apart from top to bottom of screen. starts on the right and about a 1/3 of the way toward the ...have the exact same problem, my lcd tv has multiple lines are horizontal it ...
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the ...
? 3:05
https://www.youtube.com/watch?v=KiqJuMiEiak
Jun 8, 2013 - Uploaded by Sameh Moustafa
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the picture SOLVED .... I just have one black line ...
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Dec 20, 2015 | Televison & Video
Problems with the picture
If set is new one and w/guarantee, apply this returning for new one
May 19, 2010 | LG 42LC2D 42 in. LCD HDTV
Vertical Line on Phillips 42PF7320A/37
Hold down the cursor button towards the green line, it's really that easy...
Mar 07, 2010 | Philips 42PF7220A 42 in. Plasma Television
On my tv screen I have a vertical white line with some colours
the x or y driver board is failing.best to have a servicer checked out
Jul 10, 2009 | LG M4201C-BA 42 in. HD-Ready LCD
Westinghouse LCD TV - broad vertical green and blue lines
try to go to the factory reset and see if that helps. If not, you can then check your connection. if you use component (red, green and blue for video and red and white for audio), make sure all the color matches when you plug it in. if everything have been checked then you need to replace the main board and it should correct the problem.
Jun 22, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Single Blue vertical line appeared on the sanyo 42'' LCD screen
vertical ic fult or vertical section supplys missing
Jun 12, 2009 | Sanyo Televison & Video
Daughter sprayed water on samsung lcd 32 inch on the front panel
electric and water are a bad mix as you know my advice to you unplug tv put it in very warm room for about 3/4 days do not plug in hopefully it can be saved.adrian
Feb 15, 2009 | Samsung LTN468W 46 in. LCD Television
Vertical line on LCD TV Panel
Had this same issue on right side of 52" about 1 inch from side but had 3 vertical lines that disappeared after 40 minutes. Have Samsung LNT5265FX/XXA and about 16 months old. LCD Panel itself had to be replaced to fix it, fortunately had extended service plan
Oct 17, 2008 | LG 42LC2D 42 in. LCD HDTV
Multi color vertical lines on sony wega LCD tv/42 inch
sir do a power reseet ,turn off the tv then unplug it from the electrical source then wait for 1 minute then plug it in and turn it on if it doesn't work call sony customer serveice at 1800 222 7669
Aug 11, 2008 | Hitachi 51SWX20B 51" Rear Projection...
Philips 42PFL7422D 42 in. LCD TV Logo
35 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
