Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Whirlpool washer I saw that you gave a solution to the problem with the whirlpool washer where it wasn't spinning. Would you happen to know of documentation that I can look at to repair that coupler? My email address is stevechrist@ymail.com and my phone number is 586-246-4841, any help would be appreciated.
  • 90 Answers
No problem. I emailed you some helpful sites. Good luck.
Posted on Jan 19, 2009
We installed a stacked set of WFW9250WW and WGD9270XW Whirlpool washer and dryer. When we turned on the washer, everything worked fine until the spin cycle. The machine started vibrating violently and...
Hello, welcome to FixYa.
I understand you have a problem with your stacked washer & dryer, thank you for providing the model number (of both) that is a good start... however I need to follow that up with a couple of questions.
Are these "new to you" machines or have you had them prior to this and just never stacked ?
Also had you run the washer before they where stacked and not noticed an vibrations violently/noise like a hammer spinning inside?
Finally, what method did you use to fasten the dryer to the top of the washer and did you remove the cabinet top of the washer before stacking...for the record it should not be removed as was the case with some other manufactured machines.
Let me know if you can add anything further along with the make & model. I will wait for your reply to move forward.
Thank you for choosing FixYa.
Regards,
Macmarkus :)
Jul 13, 2011 | Whirlpool Washing Machines
I was washing beach towels and during the rinse/spin cycle the door popped open on my whirlpool duet ht (model GHW9400PL4). I haven't been able to close the door since it opened before the cycle was...
those have a 2 latch system, sounds like the second latch that engages during the spin cycle never quite completed the safety lock , you could try and jumper the latch to see if that would release it, But it seems the secondary latch wasn't working properly in the first place, even the heaviest loads shouldn't pop the door open,
Jul 05, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have never been so unhappy with a washer as my Duet front loader. It SMELLS horrible at times, spins and shakes violently. My clothes are always in knots, especially the sheets. My first Whirlpool and...
We had problems with ours shaking but it wasn't completely level.. But I use the clean washer cycle that uses bleach only and it works pretty good. Other than that, I don't have a clue..
Apr 22, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Front load whirlpool washer wont drain. (ghw9150pw0) I cleaned the trap, ran the spin and drain cycle. It gave me the suds message, but then the load drained fine. I then ran an empty cycle hoping to...
I don't know if this will help you, but we have a Haier HNS1460TVE and this is apparently made by Whirlpool ... we have a similar problem in that if the load is not full it will not spin, it stops at 9 minutes and just gets stuck !!!
We have found that emptying the machine & turning it off and on, with the door shut, resets the machine ... hope that helps you !!
May 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a Whirlpool lsb6300pw2 top-loader. Spinning is not always complete if at all. The tub usually drains fine it is just the spin cycle that for some reason is not happening. If the washer is reset...
Hello. I also have a Whirlpool LSB6300PW2. Do you happen to know what the Part # is for the WATER INLET VALVE? I googled my washer model and all that comes up is: LSB6300PW1, or LSB6300PW3, or LSB6300PW4 . But I can't find LSB6300PW2.). I am certain my model is LSB6300PW2 because that is what is imprinted under the top lid of the washer. I am looking for the Genuine OEM Whirlpool Water Inlet Valve, not a generic. THANKS !
Jan 04, 2010 | Whirlpool Washing Machines
Washer will not spin clothes "dry".
Lgm0923, we're sorry to learn of the experience that you've encountered with your Washer. Have you tried the troubleshooting suggestions on page 5 of your User Guide? The link is below. https://www.whirlpool.com/content/dam/global/documents/200311/owners-manual-3955869-RevB.pdf
If further assistance is needed, please email us your name, address, contact number, model and serial number at Whirlpool_Reviews@Whirlpool.com.
Oct 24, 2017 | Whirlpool CAP2761K Top Load Washer
Whirlpool washer ultimate care II sometimes does not spin.
HI It sounds like the spin basket drive is going bad. If it was the lid switch, you would get no sound. Let me know if I can assist you further.
Thanks
Vic
May 16, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer won't agitate
I saw this happen once and you know what it was? A loose connection!. I pushed in the timer's molex block and it worked! It musta vibrated out the socket somehow. You must flip up the console to access the controls.
Feb 17, 2009 | Whirlpool WTW5800SW
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
42 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
