Question about GE GSS23SGSSS Stainless Steel Side by Side Refrigerator
Freezer is running but not cooling, food is thawing
  • 40 Answers
SOURCE: Top Freezer Not Cooling...Fan Running...everything thawed :(
Check the thermostat in the refrigerator and make sure it's not accidently turned to the defrost mode
Posted on Jan 08, 2009
SOURCE: GE refrig Model # GSS25WGMD WW freezer is cool,
I pulled the refrig out from the wall, turned it off, took off the back panel (that covers the compressor fan and motor) and used the attachment on my vacuum to remove the dust from the area. Then I closed the flapper that allows the ice to release from the ice maker compartment to the dispenser, so no warm air would get into the freezer area. I plugged the refrigerator back in and within an hour it was freezing again! So far this week, I have had to repair the garbage disposal and the refrigerator.....I saved some nice $$$ by figuring this out by myself!
Posted on Jun 26, 2009
woodchuck789
  • 4059 Answers
SOURCE: The refrigerator and the freezer is not working
Possible defrost problem. If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air.Since you've already replaced the motherboard Checkdefrost heater, defrost thermostat
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Posted on Aug 15, 2009
Sea Breeze
  • 4654 Answers
SOURCE: My refrigerator is not cooling. The freezer is
With the PSS26MRSS model the mother control board is suspect in that happening. Unplug and pull away from the wall and remove the cover over a panel that has the board inside. Look at both sides of the board for burn marks. Let me know what you find and if you find the board looks OK then we need to look at the compressor relay and start relay. Thanks, Sea Breeze
Posted on Aug 17, 2009
Sea Breeze
  • 4654 Answers
SOURCE: ge 25tfx25pp refrigerator not cooling properly
Need to have a look at the compressor and main mother board part number WR55X10942. If you would like to do it yourself I will assist you. Will need to spend a little time on this to make sure a fan is not the root cause. If a fan fails it takes the motherboard out with it. So if you change the fan you must change the board. The only thing I think is a good idea now until repaired is to feel the compressor to make sure it is not trying to start and getting too hot to keep your hand on. I will return in a moment with a link to a manual and help you all the way if you choose, Thanks Sea Breeze
Posted on Dec 17, 2009
Freezer temperature keeps climbing thawing out the food.
Check the thermostat, and the cooling fluid.
Tao the thermostat en see if it will start the compressor. When you hear the compressor running and still no cooling, you must have lost the cooling fluid. (used to be freon)
Mar 07, 2015 | Samsung Freezers
Auto-defrost refrigerator freezer ice build-up
Check vents/grills to make sure they are dust free. May need to be replaced. In meantime, leave freezer door open to thaw away ice (remove food not wanting to get thawed)
Mar 06, 2014 | Kenmore Refrigerators
Today morning food in the freezer was thawed & things were melting & food in the refrigerator was frozen
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 12, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer isn't cool enough; my food is beginning to thaw. I can't find the manual to find out what I can do to trouble shoot.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 14, 2011 | Whirlpool Refrigerators
Hotpoint HSS25GFP freezer side keeps thawing completely and refreezing causing freezer burnt food. what would cause this
Defrost timer/control is sticking...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Oct 15, 2010 | Hotpoint HSS25GFP Side by Side...
The cooling unit stops running periodically.....long enough to allow food in the freezer to thaw. The fridge light is on, so electricity is getting to the fridge. The previous tenant had dogs, and when we...
Could be defrost sticking or the compressor not starting...
heatman101
Sep 26, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
My freezer is a frost free upright, there is a pool of frozen water on bottom shelf. The 2 glass shelves and back have a layer of frost. Some food is unthawed. I thought maybe door was left partially open,...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Aug 31, 2010 | Refrigerators
The refridgerator is cool, but not cold.....of course the same for the freezer. the freezer is running, just nor getting cold enough. food is thawing and thermostat is reading almost 40 degress in both...
Je your defrost thermostat, heaters or timer is not working correctly or at all. The freezer has the coils that freeze the freezer and cools your fresh food area. When your defrost does not work these coils become blocked with ice and will not let air from fans pass through!!! Leaving a moderate temp in fresh food area.
Aug 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator/freezer is warm, fan is running.
The problem is the compressor isnt starting. The relay is probably ok. It should have 5yr warranty on the compressor. However if you purchase a Supco RC0810 start assist relay available at all appliance parts stores, it will start the compressor, however this is only a temp fix. But it should last till sears can put a new compressor in.
Sep 29, 2007 | Refrigerators
Open Questions:
GE GSS23SGSSS Stainless Steel Side by Side Refrigerator Logo
21 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
