Question about Canon Rebel XT / EOS 350D Digital Camera
On a canon rebel xt what is an Err 01? - Canon Rebel XT / EOS 350D Digital Camera
  • rniemi235 Jan 05, 2009
    I tried wiping the contacts and got the same result.
    thanks
  • smaidac Feb 27, 2009
    I took a picture, flash and all but on the screen displayed "Err 01" What do I need to do?
  • 21 Answers
Usually its dirty ontacts on the lens
Posted on Jan 03, 2009
5 Suggested Answers
  • 153 Answers
SOURCE: Getting MESSAGE Err CF nd
Was your last picture no 9999?
if so reset the counter in the file numbering menu.
try a different card
use a torch to look down into the memory card slot to make sure there are no bent pins, beyond that its back to a canon service center I am sorry to say
Best of luck
Posted on Jun 15, 2008
  • 57 Answers
SOURCE: ERR 01
Try remove the lens, it may be faulty.
Posted on Apr 04, 2009
SOURCE: CANON REBEL XT -CF card error
MY DID THE SAME AND I LOOK INSIDE THE SLOT WHERE YOU PUT IN THE CF MEMORY AND ONE OF THE LITTLE PIN IS MISSING...SO CHECK YOUR PIN...
Posted on Jul 04, 2009
camerawes
  • 36 Answers
SOURCE: my canon xt rebel says
One of more of the CF pins inside your camera are bent over. This is very common. The solution is to remove the main circuit and replace the bent/broken pins. Most repair shops will charge between $150-$200 to fix this.
Wes
Posted on Sep 10, 2010
Canon Rebel XT Err 05
Hi. Take a look at the below link, it may be your solution.
Canon Rebel xsi Err 05
Feb 21, 2014 | Canon EOS Digital Rebel XS / 1000D IS...
I keep getting Err 01 and no photo is taken what do I do?
ERR 01 is a lens to body communication error. Clean the lens and body contacts (put a small amount of alcohol on a Q-tip - do not use rubbing alcohol!!!). Try again. If that doesn't work, problem may be in lens or body. Using the flat of your fingernail, push in the contacts on the body inside the mirror box to clean any tarnishing between the contacts the the circuit (they are spring loaded). Try another lens - if the other lens works, then your problem is in the first lens. If it still gives the ERR 01 code then the problem is in the body.
Has the camera been impacted or had water/liquid spillage?
Sep 16, 2013 | Canon Rebel XT / EOS 350D Digital Camera
Hi sometimes it takes a picture with no problem but sometimes I get err 99 or err 01. Any ideas?
Hi! Welcome to Fixya
Err 99 could mean several different things, such as... Memory Card, Lens or Lens contacts....
Here's what you can try:
Remove the memory card an enable "shooting with out memory card" and see if you still get the error. If it works your memory card is bad. Try another lens if you can. Clean the lens contacts with a pencil eraser (be careful not to get eraser dust in the camera body or in the lens). Worst case scenario is, Err 99 could be related to the shutter failing which would mean a trip to Canon.
Thank you for choosing Fixya!
Feb 08, 2011 | Canon Rebel XT / EOS 350D Digital Camera
Canon EOS Xt displays Err 99 how do I fix it.
change the lens or try cleaning the connector tabs with a eraser.
Jun 26, 2009 | Canon Rebel XT / EOS 350D Digital Camera
ERR 01
Apr 01, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Err 99 on canon rebel xt 350 d
The Err 99 problem occurs due to dirty contacts between the body and the lens. I recommend cleaning the contacts. You can then turn Off the camera and then remove and reinstall the batteries to reset the camera to get the problem fixed.
Jan 15, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Canon Rebel Xt EOS Err 99
Error 99 is a "catch all" error that has several causes. It could be that your battery is not fully charged, especially if it is a generic, non-Canon battery. Charge for at least over night even if the charger says it's full. If that's not the cause, switches inside the camera will have to be cleaned by a repair shop.
Nov 24, 2008 | Canon Rebel XT / EOS 350D Digital Camera
I am getting a ERR CF with my Rebel XT
You've probably gotten bent pins in the camera. Has to go to the shop.
Oct 17, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Err 05
In my case, I borrowed a camera and when I got it back, err 05 appears. I've located a bit of old orange juice which sticked one of the sensors - you can see the sensors when flash is popped out.
Feb 19, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Canon Rebel XT / EOS 350D Digital Camera Logo
120 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
