Question about Vacuums
HOW TO TAKE APART A DIRT DEVIL PLUS 6.5 AMPS - Vacuums
SOURCE: Dirt Devil Easy Steamer Deluxe
Follow the plastic extension that runs from the trigger through the length of the handle. This requires more disassembly that at just the trigger. At the end of the plastic extension you will find a triangular-shaped "ramp" that pushes against a "button" plunger that opens the valve that releases solution. When you release the trigger, the triangular ramp retreats and the plunger is supposed to be pushed back out by an internal spring in the valve. This plunger sticks because of accumulated soap from evaporated solution. Try cleaning that valve and plunger by running clean, hot water through the system OR replace the valve. In the future ALWAYS thoroughly flush the system with hot, clean water after using the machine.
Posted on Jan 24, 2008
SOURCE: dirt devil easy steamer need directions to use
Thank you for responding to my question. I should have spent some time really looking at my little machine. It wasn't hard to figure out -once I found and read the back of the cleaning solution bottle and tried my luck following the water to cleaner ratio.. Opening, adding the cleaning solution and water and re-closing the reservoir was pretty easy. Everything worked out fine...and my carpet is...spotless. Thank you, Cmarie
Posted on Mar 28, 2008
Agent Don
  • 310 Answers
SOURCE: Instruction Manual needed for Dirt Devil upright model 088305
http://geeksquad.fixya.com/ThreadView.aspx?prdid=89362&thid=642772
Instruction Manual needed for Dirt Devil upright...
Posted by Innahouse on Jun 03, 2008
Describe your problem I need an instruction manual for a Dirt Devil upright model 088305.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Dirt Devil Model #M088300 Upright Vacuum. The best idea is to contact the Royal Customer Service Dept and give them the model 3 and serial 3 of the unit you are requesting the owner’s manual for, I will give you the website address and phone # listed below:
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://royalvacuums.com/ Customer Service 1-800-321-1134
Hours are: 8:00 AM to 7:00 PM (EST)
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jun 11, 2008
SOURCE: dirt devil vibe 088915v
Are you talking about the beater bar? If so, you probably have a broken belt
Posted on Jan 16, 2009
  • 18 Answers
SOURCE: Dirt Devil Repair
You can use eReplacementParts.com for the detailed diagram or exploded view of that vacuum. You will also find a full parts list, and possibly repair videos to help you out. - Dirt Devil Parts and Diagrams
Posted on Jun 02, 2010
Won't turn on
change the switch with a brand new one and that will fix the problem the switch has gone out on another dirt devil vacuum and that is so common it is hard to explain it is a defect in the way the switches are made
Mar 17, 2014 | Dirt Devil SD30035 Express Bagged Canister...
My dirt devil keeps shutting off randomly
It's overheating. Empty the cup and replace the filters. There's a breaker that opens up and turns it off when it gets too hot. When it cools down it closes back up and it will run again. It'll argue with you til the end of time or until you fix the problem.
Good Luck
Jan 13, 2013 | Dirt Devil M085805 Upright Vacuum
Dirt Devil- Brush not rotating on its own. No suction.
drive belt. take housing apart (draw a diagram so you can put it back together) take the broken belt to a vacuum repair shop to get the same one. mine cost 7$.
15 minutes work.
Jun 14, 2009 | Dirt Devil Featherlite Bagless Vacuum...
How do i open my dirt devil kone to empty it?
remove vac from charging base. twist the two section apart. it will turn about 1 inch and then pull apart. this will expose the filter to remove to empty the dirt. reassemble in reverse.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Jan 21, 2009 | Dirt Devil KONE Hand Vacuum MO213BLU...
Belt keeps breaking on dirt devil 85335
check and see if the brushroll still turns easy. if it doesnt, u may need a new brushroll which can be found on ebay, or dirt devil's website
Nov 23, 2008 | Dirt Devil M085580 Featherlite Plus...
Replacement FIlter for Dirt Devil CE6000
My filter fell apart on my dirt devil featherlite CE6000. I have only used this 4 times.Where can I find one? I have looked at several stores.
Sincerly,
Pennie Silverman
Oct 19, 2008 | Dirt Devil CE6000 Featherlite Wet/Dry...
Vacuums Logo
56 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
