Question about Dryers
No heat Kenmore #96281100 - exhaust is good. replaced element & thermostat. bypassed thermal cutoff and still no heat.. any suggestions other than - buy a new dryer?
    Scholar:
  • 86 Answers
Hi, well it looks like you have covered all angles! But have you as a last resort tried to live test the power getting to the heater? I would suggest that you do this with CAUTION as it can be DANGEROUS and only experts should carry out this task as a last resort. If no power then work backwards from the heater to the next item in the heater loop and so on till you have tested everything untill you get to the timer and then you will probably have your answer.
Good luck....
Posted on Jan 02, 2009
Kenmore series 90 electric dryer will not heat. Have replaced thermostat-thermal cutoff and thermal fuse. tried bypassing all by connecting wires with electric tape to test with no results - There are no...
Okay Element should read around 38 OHMS if okay providing the voltage is at the element then it should heat, if no volts then check stat , cut outs and timer, in that order
Feb 22, 2011 | Dryers
I am not getting any heat from my dryer. I checked the two thermostats and the heating element with an ohm meter and they show continuity, but the thermal cutoff does not. Is it suppose to or is there...
easiest way to eliminate the thermal fuse is to bypass it and see if the dryer heats up for testing purposes only as this is a safety feature and left bypassed will cause a fire. unplug dryer,disconnect the two wires and tape them together, plug dryer back in and start, if it is the fuse you will have heat. Good Luck Tim
Jan 14, 2011 | Kenmore Dryers
Have replaced heat element, thermostat, thermal cutoff, thermal fuse and cycle thermostat on whirlpool dryer. keeps blowing thermal cutoff! Exhaust is clear inside dryer and outside! What is causing all...
I'd like you to try something easy. Set the dryer to Air Fluff and see if the dryer still puts
out Heat let it run for about 2 full minutes If you dryer is still putting out Heat get back to me
Nov 06, 2010 | Whirlpool LER4634J Electric Dryer
No heat but already replaced heating elimate
Check the thermal cuttoff. It is located on the element. If it does not have continuity, replace it. Also replace the Hi-limit thermostat, also located on the element, and the operating thermostat, located on the exhaust. These two should cut off the heat before the thermal cutoff blows.
Nov 25, 2009 | Dryers
I have a Kenmore Dryer mod. 96281100 which runs but no heat. I tested power input at 240v, thernal fuse closed, thermal hi temp closed, element closed and not grounding, thermostat cut-off closed, and...
If you have 240 VAC across the element, but the element is not heating, then you have a bad element. If you don't have 240 VAC at the element, then work your way back with the voltmeter to find where the voltage is dropping
Nov 11, 2009 | Kenmore Dryers
Replaced elements but does not heat in bowl
Check the thermal cutoff located on the element.  It is designed to blow if the element gets too hot.  If the thermal cutoff is blown, the hi limit thermostat (also located on the element) will also need to be replaced.  It will have two terminals on it and if it is good it will have continuity.  Trace the wires back from the element.  The first one it comes to will be the thermal cutoff, next will be the high limit thermostat.
Nov 07, 2009 | Fisher and Paykel Dryers
Runs, doesn't get hot
Either your element is out our your thermal cutoff.  Check your element for continuity if it is open, replace the element.  If not check the thermal cutoff which is on top of the element.  If the thermal cutoff is open you will also need to replace the operating thermostat and Hi limit thermostat.  The high limit is on the element below the thermal cutoff, and the opperating thermostat is on the exhaust duct.
Oct 25, 2009 | Kenmore Dryers
No heat.
If the drum turns then either the element itself is broken or the thermal cutoff is blown.  The thermal cutoff is located on the element and is designed to keep the element from getting to hot.  If that is blown you will also need to replace your operating thermostat which turns the element on and off. is should be located on the exhaust.  If the drum is not spinning at all it is most likely the thermal fuse which is also located on the exhaust.
Oct 25, 2009 | Maytag Dryers
Clothes dryer not heating
I eventually changed the thermal cutoff switch and the high limit thermostat as suggested in one of your replies to another consumer and now the dryer is working fine. Thanks.
Nov 13, 2008 | Zanussi TC7114W Electric Dryer
Kenmore 80 Series Dryer - No Heat - Thermal Cutoff Kit 279769
that therm. will actually come off the heating element part, it is always good to change both, I use a small screwdriver to get it off
Nov 07, 2008 | Kenmore 63942 Dryer
Dryers Logo
74 people viewed this question
Top Dryers Experts
