Question about Eureka Altima Upright Vacuum Model 2996AVS Vacuum
No Suction I have the Eureka Upright Vacuum. I have no suction when doing regular vacuuming but it seems to have function with just the hose. Also, the height adjustment doesn't seem to work at all. The vacuum has only be usede 3 times. Thanks
  • 8 more comments
  • Anonymous Jan 18, 2009
    I have the exact same problem...I took it in to be fixed and it worked about 3 times and then stopped again. Ive cleaned out the vaccum as well so its not clogged...
  • Anonymous Jan 22, 2009
    We have had our vacuum less than a year and have lost the suction. The suction is working with the hose but we can't seem to get it to work on the carpet. We've even taken it apart, cleaned it out and still no luck...help!
  • Anonymous Jan 24, 2009
    My vaccum is doin the same thing the hose sucks things up but the bottom part wont **** anything up n I cleaned the whole thing too...its not the belt or the filters!!! Somebody figure out what the problem is!!!??
  • Anonymous Jan 25, 2009
    i have perfect suction from the hose but none from the rest of the vacume.
  • stevebutler1 Jan 26, 2009
    I have the same exact problem "No Suction"!!! This Vacuum cleaner really sucks.Can anyone answer our problems!!?
  • twynn Jan 31, 2009
    I have the same problem. No suction from the vacuum, only the hose. It has always worked this way. Please give us a solution to this problem!
  • ginagina24 Feb 10, 2009
    mine worked until the belt broke, now I have the same problem, just moves dirt around...
  • directorrae Feb 15, 2009
    This seems to be a common problem. Same issue as others. Hose suction is great, but as soon as i engage the floor vacum all suction seems to stop and it just moves the dirt around. Any help would be great.
  • Anonymous Mar 02, 2009
    No suction. I have the same problem as all the rest. It worked great the first time I used it. After that. NADA. It's BRAND NEW. What should I do?
  • ejgibson Mar 22, 2009
    Yikes. I was hoping for some answers, but I guess we're all in the same boat. Maybe I've just been lucky in that our model is now about 6 years old and only recently lost suction?
  • 281 Answers
Is your brush roller turning? unplug the vacuum and see if you can turn the brushroller by hand.if it turns real freely the the belt is broke ,if its real hard to turn then something is caught up around the bearings on the ends of the roller.my suggestion is if your having that much trouble withit take it back and tell them you want a new one.if they want to keep your buisness they will give you a new one
Posted on Apr 23, 2009
Eureka pet expert vacuum lost suction
I had the same problem with exact same vacuum, was working great and the one day just lost almost all suction in the hose and in very very poor suction on base when vacuuming carpet, also when vacuuming the carpet everything I vacuum shoots out the bottom and hits my feet, never happened b4, checked all hoses and tor apart every thing to see if their war dust in motor, clogging anywere but nothing everthing looked great, NEED HELP CANT AFFORD TO BUY ANOTHER VACUUM OR TO TAKE TO REPAIR MAN TO B CHRGED AN ARM AND LEG, SOMEONE PLEASE HELPPPP!!!!!!!!!!
Jun 05, 2012 | Eureka 3276AZ Pet Lover Bagless Upright...
I have a Eureka Contour model 2900 type A upright vacuum, the roller works fine nothing clogged, took it apart motor blade is free of debris, no suction from tube and blasts OUT air from the front HEPA...
Even with your explanation,it seems the hose is clogged.Try taking the hose off,then blow through it or pour water through it.If this doesn't do it,make sure the suction canals are going to the proper areas.
Apr 04, 2012 | Eureka 2900A / 2901A Contour Bagged...
How do I get the suction over to the hand held hose?
Once you detach the hose from the power head, the suction is at the end of the hose.
User's manual:
http://www.eureka.com/service/manuals/80238.pdf
Dec 24, 2010 | Eureka Capture Upright Vacuum Vacuum
The brush does not spin when making contact with carpeting
I tried the electrical-tape-around-the-wooden-spindle technique. After a minute or so, it's back to functioning normally.
Mar 14, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
Suction always seems very poor
you have to have something clog somewhere
Feb 09, 2009 | Eureka 5892AVZ Bagless Upright Cyclonic...
Eureka Bravo II poor suction at hose
check if the hose is clogged or the fan is broken
Jan 04, 2009 | Eureka 7606 Bagged Upright Vacuum
Hose has no suction
Most uprights need to be in the up-right locked position to enable the hose pickup.
Jul 25, 2008 | Eureka 4874 Bagged Upright Vacuum
Hose suction Eureka theboss smartvac
There has to be a clog in the hose, Unhook the hose and drop like a big marble in it to see if it comes out the other end.
May 10, 2008 | Eureka 5892AVZ Bagless Upright Cyclonic...
Main vacuum suction won't turn off
try cleaning out hoses,if that dont work turn it on its side if the roller doesnt spin u need to change belt if it does take the bottom cover and try cleaning out the hole under roller
Nov 22, 2007 | Eureka Altima Upright Vacuum Model 2996AVS...
Eureka Altima Upright Vacuum Model 2996AVS Vacuum Logo
311 people viewed this question
Top Eureka Vacuums Experts
charlesjo336
Level 1 Expert
JoeVacs
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
