Question about Ingersoll Rand Air Tools & Compressors
SSR-EP150 AIR COMPRESSOR MANUAL
MANUAL FOR SSR-EP150
5 Suggested Answers
rockitman187
  • 2559 Answers
SOURCE: After removing and replacing a completely shredded
It sounds like you have a valve floating.
Posted on Feb 22, 2009
braintrust
  • 62 Answers
SOURCE: I have a compressor # SSR-EP75 I would lioke to
ingersoll has a web site to down load manuals and parts list, i coulnot get in you probably have to be a dealer to access, but here is the web site www.irtechpubs.com do a search and find your nearest dealer then have him go to the website and down load the manual for you and have him e-mail it to you, also check your serial number i could not get anything to match that number in my search hope this helps
Posted on Oct 27, 2009
  • 17 Answers
SOURCE: our company has ingersoll rand
make sure the cooler is clean..change the oil filter if hasn't been changed in a while..could be bad thermo valve..oil level?How many hours on machine?
Posted on Dec 19, 2010
  • 205 Answers
SOURCE: Have a SSR-EP100 air compressor that shows
Try to reset the main motor and fan motor over loads by pushing the reset on the overload it self, Then reset the controller. If the error resets, before starting. put a clamp on amp meter on to L1 or L3 motor lead which is located in the compressor electrical box . Then start and observe amps when unit is making air fully loaded. Once you know how many amps at full load the unit is pulling ,look at the overload setting on main motor overload and see if it is approxmately 10 amps above the max amps being pulled.If not set it about 10 amps above your max load amps.
Posted on Dec 01, 2011
How to change from BAR to PSI on INGERSOLL RAND INTELLISYS CONTROL for INGERSOLL RAND SSR-6-20-125 AIR COMPRESSOR
Ingersolll Rand website support section should be able to provide a manual.
Failing that contact customer services.
Aug 03, 2016 | Ingersoll Rand Air Tools & Compressors
I have a Model# SSR-EP10 IR compressor that wants to start loaded, if I release the load it fills up and then cuts off with out going to unload and then when it calls for air it try to start loaded.
How are you unloading it? There is an unloader valve that is usually a manual lever connected to the regulator. 0531-051 - DIAPHRAGM,UNLOADER for Ingersoll Rand compressors
May 24, 2015 | Air Tools & Compressors
Ssr up series 30e-40 Ssr 50 - pe low sump
compressor idling to long or inlet valve not opening
Oct 07, 2014 | Air Tools & Compressors
How to reset air compressor?
How to rest air compressor ssr ep. 50 se
May 30, 2014 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Our company has ingersoll rand air compressor model SSR MM 150 is giving high temperature of air ultimately facing moisture problem at downstream of dryers.Need your assistance.Kindly send the manual if...
Nov 06, 2010 | Air Tools & Compressors
Oct 21, 2009 | Ingersoll Air Tools & Compressors
Air Tools & Compressors Logo
926 people viewed this question
Top Ingersoll Rand Air Tools & Compressors Experts
elunsford
Joe Garcia
Joe Garcia
Eddie Tucker
Level 1 Expert
Are you an Ingersoll Rand Air Tool and Compressor Expert? Answer questions, earn points and help others
