Question about Samsung HP-S5053 Television
Plasma TV picture problem
My samsung HP-S5053 tv picture is cropping off the top and bottom of the picture like it is in zoom mode but it is not is there some kind of adjustment that needs to be made to correct this problem . Hope you can help Thanks
  • Anonymous Sep 28, 2008
    After the tv in on for several hours I loose the picture not the sound. Turn off the tv let it sit for then turn it back on tv is ok for about 1/2 hour then I loose the picture again.
    Novelist:
  • 192 Answers
Normallly, if the format button on the remote for the television does not achieve the desired affect, then, a cable box or a satelite box is where the change needs to be made. For example: A Motorola Cable box needs to be set up to go to a wide screen when an analog signal is detected. It's difficult to determine the repair without knowing the hook up of the peripherals. Hope this helps.
Posted on May 13, 2007
SOURCE:
Hi, My Samsung hp s5053 plasma is broke anyone can help me please!
A TV repair shop is your best bet - the problem is likely the power supply - check the fuse.
Dec 04, 2010 | Samsung HP-S5053 Television
I have a 550 series plasma Samsung Tv 54''.. I cannot get the picture to pick up for example the football score at the top of the screen, nor the NASCAR readout at the top. I get a piece of it but can't...
The problem may be not in your TV but in your receiver, if you use a cable or satellite receiver. Sometimes those also have similar settings for picture mode - it's rare, but I've seen it.
If not, then it must be tv's zoom mode is just set to something other than "standard".
Nov 17, 2009 | Samsung HP-R5072 50 in. Plasma HDTV
Hp-s5053 samsung plasma with snow on hd content
It appears that the Main bd is bad. Try using Component cables instead of the HDMI cables and see if there is a change. If there is a change to normal picture then try another HDMI cable. If the problem returns then replace the Main bd. There three Main bds for this basic model number. You will need the version# found on the right side of the set to order the correct bd.
Jul 16, 2009 | Samsung HP-S5053 Television
Picture too big
It seems as if your tv is in "crop", "Zoom", or "full" mode. Select letterbox, normal, or full-screen mode. Look in the manual for exact instructions.
Jul 15, 2009 | Panasonic VIERA TH-65PV500 65 in. Plasma...
50" Samsung Plasma with black screen
I had the same problem and had the TV serviced and found that the y board was blown $350 total. The repair guy explained that the board has a hot transister underneath that slowly leaked onto the board, but says that they can not get Samsung to admit to the problem. Works fine now but only have a 90 day warrenty on the parts.
Dec 01, 2008 | Samsung HP-S5053 Television
Philips 42PF7320A cropping issue
Pete,
When using a hd connection on a philips tv and (I am assuming this is the case) the tv disables the format features on the tv and only lets you select widescreen and automatic, if you are using hd adjust the picture size from the cable/satellite box, look for it in the box's menu system or on the remote, it is usually labeled, aspect ratio, zoom, format or something to that nature, hope I helped you
Aug 20, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Samsung Plasma TV Model:HP-S5053
I had the same issues and the tech came out and replaced the main board... one way to tedt if it is the PDP is in the service menu.. run the plasam ttests and verify you don't see any dots. After replacement the tech checked all voltages and all is well.
Jul 25, 2008 | Samsung HP-S5053 Television
Picture crops at top and bottom of screen
I assume you have used the "wide function" on your remote to verify you are not in "zoom" mode? Other than that I can't be much help.. Sorry Roger
May 05, 2007 | Sony KDS-R60XBR1 60" Projection HDTV
Hp-s5053
you most have a bad conection problem, but thats a job to a tech ,dont do it your self or try to , this is a very delicate tv..good luck
Aug 06, 2006 | Samsung HP-S5053 Television
Televison & Video Logo
183 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
