Question about Acer Aspire 5100 Notebook
THE INTERNET IS NOT WORKING BUT IT SAYS THE CONNECTION WAS MADE BUT THEN WHEN YOU TYPE IN THE HTTP ADDRESS NOTHING COMES UP. PLEASE HELP
  • Michael Ward May 11, 2010
    you will need to tell thee oprating system what conection you are using
How to connect?
Hello Friend,
Connect you computer directly to the cable coming with the internet.
Type cmd in the start menu and when you reach the command box
Type config in the box
This will display the ipV4 address which should be the internet gateway.
if this is 192.168.1.1 then we have to change the router ip ti 192.168.1.2
please follow this link how to change rotuter ip adress
http://ui.linksys.com/files/WRT160N/v3/3.0.00/index.htm
In the mid of this page router ip should be done to 192.168.1.2
please contact me if this still does not work.
amitawasthi104@gmail.com
May 02, 2013 | Linksys WRT120N Router
My gateway laptop keeps typing ........... periods or dots.
moved you out of HP. it's not a hp
the does means the key board is bad.
unplug the keyboard, see, it bad.
gateway is defunct maker now, long gone.
hard to find parts but ebay.
Sep 09, 2017 | Gateway Computers & Internet
Mms/gprs settings.my network provider is smart
(How to get there? Open settings - Network - APN/Access point - New apn).
On internet settings try this first: Usually works but not always. Under are SMARTs own settings.
Connection name: Internet
Acces point name: Internet
NOTHING ELSE
Hope it helps.
I. GPRS/WAP Internet Settings
Connection name: SMARTGPRS
Data bearer: Packet data
Access point name: smart1
User name: leave this blank
Prompt password: No
Password: leave this blank
Authentication: Normal
Homepage: http://wap.smart.com.ph
Network type IPv4
Phone IP address: 10.102.61.46
Name servers: Automatic
Proxy server address: 10.102.61.46
Proxy port number: 8080 or 9201
(differs from one handset model to another)
Default access point: SMARTGPRS
Data bearer: Choose GPRS
Access point: internet
User name: (leave it blank)
Prompt p'word: No
Password: (leave it blank)
II. MMS Settings
Connection name : SMARTMMS
Data bearer:Packet data
Access point: mms
User name: leave it blank
Prompt password: No
Password: leave it blank
Homepage : http://10.102.61.238:8002
Network type IPv4
Access point: mms
Prompt p'word: No
Homepage: http://10.102.61.238:8002
Jun 08, 2011 | Sony Ericsson XPERIA X10 Cell Phone
Wireless connection
Start->Settings->Control Panel. Double click in Internet Options.
On the Connections tab, click on Never Dial a Connection. While you're there, click on LAN settings. Automatically detect settings should be checked, but normally nothing else should be checked.
If this doesn't help, you may need to rebuild the stack:
Start, Run, CMD to open a command prompt.
Reset WINSOCK entries to installation defaults: netsh winsock reset catalog
Reset TCP/IP stack to installation defaults. netsh int ip reset reset.log
Reboot the machine
Apr 16, 2009 | Computers & Internet
Cant connect to the internet.
Click on Start and type CMD. Open CMD and type ipconfig. Check out the IP address V4 for the Local area ethernet adapter or wireless area adpater depending on wireless or wired connection. Any ip address other than of the class 169.254.x.x shoud be considered good. If you have an IP address is any other number other than the above you have a good IP address. to test the internet connectivity type PING www.google.com. If the results are Packets sent 4 Recieved 4 Lost 0 then the issue could be due to Internet Explorer bing corrupt or a firewall blocking the internet access. Power off the computer. Power on the system and as soon as you see the Dell logo please tap the F8 button 3 - 4 times. You'll get to teh Advanced Windows boot option screen. Select safe mode with networking and see if the internet works in the safe mode. If yes then it could be the firewall. Uninstall you antivirus and check.
Apr 02, 2009 | Dell Studio 1537 Laptop
No internet connection
I received this solution from Belkin. It worked for me & I hope it does for you. Good luck!
Belkin solution:
Please follow the details given below:
1. Please contact your internet service provider to know the connection type details (Is it PPPOA,PPPOE, Dynamic or static)
2. Belkin router F5D8633 ADSL router works only with ADSL broadband connection and does not support Cable broadband connection.
3. Do not use the Setup CD Assistant; reset the unit and configure it manually. Make sure to set the correct VPI/VCI values in the process as the default settings may not be correct.
4. When using PPPoA, always use VcMux encapsulation, when using PPPoE, always use LLC encapsulation. Keep the VPI and VCI as 0/38.
5. Please follow the instructions given below to configure the router manually:
- Connect the phone line direct to the router, or through the filter.
- Connect the computer to one of the LAN ports on the router.
- Switch off the router and power it back after 5 seconds.
- Restore the router to factory defaults by holding down the reset button on the back of the router.
- The power light will flash and then come back ON solid, indicating that the router is being restored to factory defaults.
- The corresponding lights on the router should be lit-up.
- Check if the computer has an IP address in the range of 192.168.2.x
- Click on `start` & click `Run`.
- Type in `cmd` & click `ok`.
- Type `ipconfig` and Enter. Check for IP address, subnet mask & Default Gateway.
- If not, specify a static IP address, gateway and DNS by following the steps at http://web.belkin.com/support/kb/kb.asp?a=2824
Then follow the below instructions to reset IE.
-Open Internet Explorer
-Click on Tools -> Internet Options
-In the General tab, click on Delete Files under Temporary Internet Files
-Click on Clear History
-In the Connections tab, select Never Dial A Connection and click on LAN settings
-Uncheck all the options and click on OK
-In the Advanced tab, click on Restore Defaults
-Click on Apply and then OK.
- Open a new Internet Explorer window and on the address bar please type in http://192.168.2.1 and click on go.
- You should be able to access the routers set up page.
- By default the password is blank.
- Click on Connection Type and Reconfigure the connection on the router (using your ISP details).
- Save the Changes.
Note: Please obtain the correct values regarding the Internet connection from your Internet Service Provider.
Internet Status should show Connected on the top right hand corner of the web page.
If the problem persists, please get back to us with the following information given below:
1. Type of connection provided by the ISP (Is it PPPOA,PPPOE, Dynamic or static)
2. The ADSL light status on the router. Please let us know if the ADSL light status on the router is solid or flashing.
3. ADSL broadband connection or Cable broadband connection.
4. Operating system on the computer and the version number for the internet explorer like IE 6 or IE 7.
5. Internet Status shows as Connected or Disconnected on the top right hand corner of the router web page.
Log on to the router web interface at http://192.168.2.1
- By default, the password is blank.
- Click on Security log under "Firewall" option (let us know the message you see under the security log or send us the screen short of the message you see under the security log)
6. Then, check the IP address of the computer. For checking the IP address:
- Click on start & click `Run`.
- Type in cmd & click `ok`.
- Type IPCONFIG and Enter. Check for IP address, subnet mask & Default gateway.
- The IP address should be in the range of 192.168.2.x (x=2 to 254)
- In the command prompt type PING 192.168.2.1 & Enter. Check if you are getting replies.
- Type, PING 4.2.2.2 & press Enter. Check if you are getting replies.
- Try pinging yahoo by typing PING yahoo.com and Enter. Check if you are getting replies.
Dec 28, 2008 | Belkin N Wireless Modem-Router F5D8633au4A
Hawking wireless router (HWRN1A300N) will not connect ot internet
First of all - your ISP has nothing to to with DHCP. DHCP is handled internally by your router (or DHCP server).
If you did not configure your router otherwise, it should hand out an IP address automatically.
If you ipconfig shows that you have an IP address, then I assume that this address is manually configured.
You should set everything to automatic until you know it works.
So...
Go to your start menu -> Control panel -> Network connections.
Right-click on "Network Connections" and choose "open".
Look for your "Local Area Connection", if you are wired into the router, or something like "Wireless Network Connection" if you're using wireless.
Right-click "Local Area Connection" and choose "Properties".
Double-click "Internet Protocol (TCP/IP) and see that both "Obtain an IP address automatically" AND "Obtain DNS server address automatically" are selected.
Click "OK" twice and make sure that all property windows are closed.
Go to the command prompt and re-do "ipconfig /all" (No quotation marks of course).
Check the line that says DHCP server, it should be the same IP as your Default Gateway (your router).
If this does not work for you, copy the result form that command here and I have another look.
If it works, please come back and leave a comment. This might help others with the same problem.
Dec 28, 2008 | Hawking Computers & Internet
No connectivty to internet
Your problem is very indicative of an assigned ip address to your wireless card. Assuming you have windows xp as your operating system. Go to start, run, type in CMD, once the dos screen appears type ipconfig and look to see what your assigned ip address is.
Nov 23, 2008 | Toshiba Tecra 8000 Notebook
Problem with philips voip841
Try retrieve the IP address of your VOIP841, on the handset press the “Menu” button, navigate to the “Settings” menu and choose the option “Network”, then "DHCP", it should give you an IP address, make a note of this. Open your Internet browser and type in the IP Address of the VOIP841 into the address bar. The Internet browser will show the internal Internet page of your device. Login with the following username and password:
Username: philips
Password: voip841
After logging in please navigate to the “Skype” menu option in the left side menu. On this page y ou can type your Skype username and password. Once they are filled in save your settings and test on the handset if everything is working.
Sep 25, 2008 | Philips VOIP8411B/37 IP Phone
Unable to Connect to Internet
Make sure that the cable/dsl modem is connected to the blue port on the Linksys router that say's internet and your computer to any of the yellow ethernet ports. Check what is the IP address of your computer by typing ipconfig on the command prompt(assuming your using Windows, to open command prompt click start and go to Run and type cmd, a black windows will open normally it will say C:\Document\Settings\Owner>. Your computer should obtain an IP address of 192.168.1.x, open Internet Explorer and type this address on the address bar http://192.168.1.1 when you get a prompt for a username and a password, leave the username blank and type "admin" for a password from there you can now check the entire settings of your linksys router, check the Status and make sure your router is getting a valid Internet IP address if not you may require manually setting up the configuration of your ISP on the router.
Aug 29, 2008 | Linksys RangePlus WRT100 Wireless Router
Acer Aspire 5100 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
