My samsung WF210 washer needs to have the temperature sensor changed, how do I do this myself?
Have part just need instruction on how to change
2 Suggested Answers
  • 3 Answers
SOURCE: I just got a NTC Temperature Sensor for a W1213 Wa...
Easy.
Make sure there's no water in the drum.
Important! Switch off and remove plug from electricity supply!
Remove front base plinth (pulls off use a plastic lever if necessary - one inside soap dispenser drawer). Remove front panel of machine (torx screws at bottom, torx screw under drum. Slacken wire around door seal and remove (hook it with a smallish screwdriver. Do not damage seal. they are ridiculously expensive).
Unclip seal from front panel. Pull front panel out from the bottom, then down. Reach around the now detached front panel and unclip door lock wiring). Put panel somewhere it won't fall over.
Locate element underneath drum at the front - oval rubber with connections to it.
Temperature sensor is in the middle of the element. Unclip the plug from the back of the sensor. Gently but firmly pull the sensor out toward you. It's just a friction fit in the rubber. you can use narrow pliers but don't crush the socket of the sensor. If you want to test it, put a multimeter set to ohms on it. Resistance will vary under say a hot or cold tap/faucet.
New temperature sensor will push fit into old hole - moisten case first to make it easier with a tiny bit of washing up liquid (or spit!). You might want to test it first as above.
Reconnect wires, lock harness, front panel, attach door seal, attach door seal retaining wire, screws, base plinth.
Congratulate yourself on saving shed loads of cash.
Posted on Jun 29, 2010
How to fit bearing
Change of bearing is a little advance project and over whelming for beginners.
Most bearing comes with instruction how to install bearings and some you could find instructions on line .
Most likely you need to use special tools or bearing installation tools .
Most likely you could buy them from appliance parts stores or auto parts and major tool stores or online tool stores stores and as you should know there are many different size and shape of bearing tools.
You have to be sure what kind bearing tools exactly you need
Jul 10, 2014 | Hotpoint Aquarius WF210 Front Load Washer
What does f-10 mean on hotpoint w630 washer
and may need replacing. Check the plastic tube has not come off the sensor or has become damaged or kinked as this would cause the same error.
Aug 16, 2012 | Hotpoint Aquarius WF210 Front Load Washer
Samsung p1453 error code 6e?
6e fault is saying that the temperature is not high enough, this is most likely a malfunctioning temperature sensor or an issue inside the electronics.
Mar 10, 2012 | Computers & Internet
If we have a new Samsung WF210 washer. the drain that we have to reach is approximately 7'-6" high (from floor). We have attached drain extension to the washer and have run it into the drain. Will...
Hi it will have a impact on your washer in time because the pump will block up causing you problems the recommended hight is 2ft 6 ins short term it will be ok
Aug 03, 2011 | Hotpoint Aquarius WF210 Front Load Washer
I need to replace the paddles on the inside of the drum - is this a difficult job to do - if not i will go ahead and order the parts myself as an engineer call out is to expensive
Hi if you let me know what make & model washer you have I will let you know if its a easy fix or not some paddles you can fit yourself easy some you should not try
Jul 26, 2011 | Hotpoint Aquarius WF210 Front Load Washer
F 24
An F24 error code indicates a water temperature sensor error. You can check the wiring connections at the temperature sensor. If both wires are connected and are making a good connection then the temperature sensor will need to disconnected and tested with an ohm meter. The temperature sensor changes its resistance with temperature. The sensor should have a resistance measurement of 9.7k ohms at temperature of 86 degrees.
Below I have provided you with an image that will help you diagnose the problem.
Apr 17, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Door seal needs to be repleced
sorry not a answer as such. I found out the machine is still under guarantee. So I just called out the repair man.
Feb 12, 2009 | Hotpoint Aquarius WF210 Front Load Washer
Drum
try changing the brushes if you cant do it contact a local elctric shop see if they could check it out for free
Apr 03, 2008 | Hotpoint Aquarius WF210 Front Load Washer
Washing Machines Logo
47 people viewed this question
Top Washing Machines Experts
