Question about Craftsman 10" Inch Miter Saw Sears Model 113.235110 Compound 12 Black Stand Amp
Craftsman miter saw will not turn on
When plug saw into wall socket. Miter saw will not turn on
rowdy45176
  • 2176 Answers
SOURCE: Have a 10
I have tried that number in numerous sites and nothing comes up. Can you recheck and I will try again, but in the meantime, make sure the blade is tight (unplug tool) try turning the blade by hand and do you feel resistance. Is this a belt drive and if so what is the condition of the belt and tension. Let me know and I will do what I can
Posted on Mar 21, 2009
efs_perpends
  • 1996 Answers
SOURCE: need to change the blade on a craftsman 10
First off, unplug the saw. No need to remove the guard, though you may have to loosen the cover over the lock nut to access it on some saws.
Look for an arbor lock button on the back side of the blade housing or motor, to lock the blade in place.
Hold that down and use a wrench to loosen the nut holding the blade on.
If you don't have an arbor lock, you'll have to wedge a 1x 4 or 2x4 under the blade and hold pressure on the handle to keep it from spinning while you loosen the lock nut. Once it's loose, spin it off and remove the washer and blade, replace and retighten the nut.
Should be pretty straightforward, as long as you have no power to the machine and lock the blade from turning, not too much can go wrong.
If you want to find an online manual with instructions for your saw, please try Sears online support site at www.managemyhome.com.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on May 14, 2009
  • 1214 Answers
SOURCE: Have craftsman 12 inch combination miter saw and need owners manu
I found a copy by going to the Sears Parts Direct website, then select the link on the right that says "View Manual". It will take you to the Manage My Home website, where you will find a button for "View Manual".
I would upload to Fixya, but I cannot get the Manual upload link to work.
Posted on Dec 14, 2009
  • 333 Answers
SOURCE: I need to unlock the arm on my craftsman compound
there is a black round pin towards the back top. Pull it out
Posted on May 02, 2010
agent91
  • 2100 Answers
SOURCE: I have a craftsman table saw model 137.248830 and
You should have 4 bolts holding the trunnion on to the table, just loosen these bolts up a little, tap the trunnion with a hammer, the right way, put a straightedge on the blade fully extended and measure across the table to a dado slot, front and rear, tap it till it is exact, tighten bolts and check again. This should do it. You can check your fence the same way. hope this helps.
Posted on Jul 26, 2010
What's best craftsman 10 miter saw?
More $$ generally = better quality, but not always. Many Craftsman tools today are very lightly built. Go to Home Depot and get a Ryobi or Ridgid saw, or Lowe's has Kobalt miter saws. All are at least as well made as Craftsman, and Ridgid comes with a lifetime warranty!
Oct 12, 2017 | Craftsman Saws
Craftsman miter saw motor runs blade does not rotate.
YOU PROBLEPLY WORE OUT THE WORM GEAR.ALWAYS KEEP YOUR BLADES SHARP. I HAVE THE SAME SAW AND THE ONLY PROBLEM I HAD WAS I BROKE THE DUST BAG OFF, MY FAULT.
Jan 31, 2013 | Craftsman 12 In Miter Saw With Laser Trac...
I am Looking for a miter gauge (which is an accessory) for a old craftsman model 113.244512 band saw. Is there any around out there?
You may look up to ebay or search on google. I actually order band saw parts with www.bandsawparts.com but I think they don't have the miter gauge for your bandsaw model.
Dec 20, 2012 | Craftsman 1/3 hp 3.5 amp 10" Band Saw...
Craftsman Miter Saw stopped working
Are you plugged into a GFI receptacle? If so maybe you have to reset the GFI. I would also check for loose wires on the switch or plug and make sure your cord is good.
Aug 20, 2012 | Craftsman Saws
Craftsman 10 in miter saw just stopped working...not getting any power. Any ideas?
Check the brush under the black caps on the side of the motor. Make sure the plug is unplugged while you are checking it out.
Feb 04, 2011 | Dewalt DW715 Heavy Duty 12" Single -...
Changing the blase on a craftsman miter saw, model nimber 315.212240
my miter saw has stopped working. i have checked the plug and electrical connection. it worked without problems 2 days ago. it gave no warning of problems. is there "a built in" fuse or circuit breaker?
Oct 07, 2010 | Craftsman 12 In Miter Saw With Laser Trac...
Craftsman Miter Saw - can't remove the blade
It is left hand thread and if the lock won't hold what you can try is put a 2x4 on the table and pull the head down against the wood and with a good socket and ratchet loosen it that way.. remember to tighten to loosen
Jul 20, 2009 | Dewalt DW715 Heavy Duty 12" Single -...
Craftsman compound miter
if its like my dewalt, u have to unscrew it before u canunlock the handle. try unsrewing it.
Sep 05, 2008 | Bosch 12" Dual - Bevel Compound Miter Saw...
Craftsman 10" Inch Miter Saw Sears Model 113.235110 Compound 12 Black Stand Amp Logo
61 people viewed this question
Top Craftsman Saws Experts
Craig Butler
Craig Butler
Mike
Are you a Craftsman Saw Expert? Answer questions, earn points and help others
