Question about Apple Power Mac G5 Desktop
Mac G5 shutdown and now won't power up
My Mac G5 has shutdown unexptedly and now won't power up. There is no response at all to pressing the startup button. I have unplugged it and reseated all the RAM but it still won't power up. I have checked the battery (which is a round barrel shape 3.6v not a flat round type) on a meter and it shows a poor charge, is it likely this is the problem?
  • 42 Answers
Sounds like a bad power supply. They do go bad... get a new one and hook it up without installing it. If it boots your machine...you've solved your problem. That battery retains some boot info and your date/time settings.
Posted on Jan 04, 2009
Mac g5 wont start led light blinks once every 7 sec
Hold down the power button until the computer shuts off. The press the button to restart and see what happens. There are several different ways to startup. immediately upon hearing the boot tone, press and hold the shift key to boot in safemode. If this fails as well, then you will need to boot with the install CD. This is done by immediately pressing holding the C key upon powerup
Jun 27, 2012 | Apple Power Mac G5 Desktop
I have an all in one Mac OS X with 2.4 GHz Intel Core 2 Duo processor. When I turn it on the screen is white with the spinning circle in the middle like its powering up but never does. It just stays...
Hello
You can check your hard drive's health at startup pressing command-s. you will see a black screen with white text. simply type "fsck -f" and press return. It should check your drive and tell you if something goes wrong with it, and repair it if possible. Then type "reboot" and press enter to test.
It this does not help, you can press the shift key at startup. It does the same thing, but also disables the extensions at startup, this will help you to find out what the problem is. The startup will be longer and it should ask for your admin password.
If this still doesn't help, you might have a hardware problem (hard drive). You can try to backup your data, erase the disk and reinstall the system. To backup you need another Mac, and a firewire cable. Press the "T" button at startup, this should set the Mac in "target" mode, allowing you to use it as an external hard drive. Then connect the firewire cable between the two macs. On the mac that is OK, you should see the hard drive icon of the other mac...
Hope that you will succeed and that it helped you someway
Aug 05, 2011 | Apple iMac G5 Desktop
I left my mac g5 open overnight i forgot that i did not shot it down i just remembered the next day that it was still open but when i used my computer the monitor is blinking and i cant do anything now
By pressing and holding down the power key for about ten seconds on the front of the G5 you can perform a hard shutdown although you will have lost any changes on any open documents. Once the machine has shutdown you can then restart per normal. Hope this helps.
Nov 09, 2010 | Apple Power Mac G5 Desktop
Power mac g5 automatically shutdown
Check if its not overheating.
Also check your power settings
Feb 04, 2010 | Apple Power Mac G5 Desktop
Hello, I have an X800XT Mac Edition graphics card with a G5 2.0 dual processor and the problem I'm having is that when I boot up my G5, it goes through the spinning weel process, but when it's finished and...
I am going to recommend a hardware approach first and then a software approach, to this issue, in order to assist you. At the end of these procedures, is a general support link from Apple for additional support for no picture in your iMac G5 display
I am seeing more of such display issues like this, and more often than not, if the problem does not have to do with the firmware, it may be a damaged or corrupted file which can hinder the iMac G5 from normal start up functionality.
PMU Reset (try this first)
The PMU (Power Management Unit) is a micro controller chip on the logic board that controls all power functions for your Mac.
• Shut down the computer.
• Unplug the computer's power cord.
• Press and hold the power button for 20 seconds.
• Release the power button.
• Attach the computers power cable.
• Press the power button to turn on the computer.
* Boot to your desktop.
This procedure may help but if it does not, follow the procedure below
-SAFE BOOT MODE-
• Reboot your Mac
• Upon restarting your Mac, press the Shift key.
• Hold the Shift key until you see a White Screen with Gray Apple icon and eventually a spinning gear.
• When you see the Spinning gear, release the Shift key.
• Allow the Mac to continue booting up. Also this may take a little while
(NOTE: this may take anywhere from 5 to 15 minutes to load to the Safe mode screen depending on the performance of your Mac, but if it exceeds this time, shutdown your Mac and try just once more. It may have just frozen up the first time around for you.)
• You are going to enter the Safe Mode (which looks like your main desktop environment - the only difference is certain startup items are disabled.)
• Once within the Desktop in Safe Mode
• From the Finder Menu, click Go> Go to Folder
• Type in this line: /System/Library/StartupItems
• This path, is going to take you to the System Library folder which has all of your Mac OS X Startupitems.
• Remove all of those folders to the Trash.
*Reboot your Mac normally and see if you can access your normal User desktop environment.
One of these two procedures should help resolve the blank display issue you are experiencing,
Additional Support Link:
Apple Support iMac G5 - No picture on display
Regards,
-Mactechtrainer
Dec 11, 2009 | ATI Radeon X800 XT Mac Edition AGP Video...
Wont start up completly
there is the single user start-up, which you were thinking of. There is also a safe-boot for macs.
To start up into Safe Mode (to Safe Boot), do this:
1. Be sure the computer is shut down.
2. Press the power button.
3. Immediately after you hear the startup tone, hold the Shift key. The Shift key should be held as soon as possible after the startup tone but not before.
4. Release the Shift key when you see the gray Apple icon and the progress indicator (looks like a spinning gear).
During startup in Mac OS X 10.4 or later, you will see "Safe Boot" on the login window, which appears even if you normally log in automatically.
During startup in Mac OS X 10.2 through 10.3.9, you will see "Safe Boot" on the Mac OS X startup screen.
To leave Safe Mode in any version of Mac OS X, restart the computer normally, without holding any keys during startup.
Jun 24, 2009 | Apple iMac G5 Desktop
Trying to choose hd startup disk on g5
Hello, To choose a startup disc, press the alt ket at startup, and you will see a list of disks to start on Best regards
Jun 11, 2009 | Apple Power Mac G5 Desktop
Eject is stuck on my power mac g5
try a reboot and hold the left mouse button down during the startup. You can also hold the spacebar during startup. This should force eject the drive
Mar 20, 2009 | Apple iMac G5 Desktop
Power PC G5 Dual 2.5 sudden shutdown and no reboot
In G5 always the cover should be closed properly if not it will start the fan very fast like a blower and the red leds will be on showing that the heat is over so please check that the cover is closed and locked from behind so itworks smooth and the power supply is standard or normal
u should always use genune parts with mac..
thanks
Dec 19, 2008 | Apple Power Mac G5 Desktop
Changing mac preferences in single user mode
Start your computer by holding down the option key before pressing the start button. This should give you an option to choose which startup disc to use when starting the computer. Once it's restarted, go to the System Preferences and choose the specific startup disc that you want to use.
Feb 21, 2008 | Apple Power Mac G5 Desktop
Apple Power Mac G5 Desktop Logo
429 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
