Question about Epson Stylus Photo 825 InkJet Printer
My epson stylus 825 is flashing error and Sr on the screen and won't print or respond to anything
Ink light is is flashing red
SOURCE: repairing
I have a epson stylus c65 printer. My printer is keep flashing the two red light. The out of paper and the out of ink. what do I have to do to stop the problem. The two red light is keep on flashing alternately
Posted on Sep 18, 2008
jacklee366
  • 541 Answers
SOURCE: Epson stylus D88 - blinking red lights
this means that your printer need to be reset this should work http://www.ssclg.com/epsone.shtml
Posted on Nov 23, 2008
SOURCE: epson stylus photo 950 printer flashing lights
I had the same Problem and checked the solution:
This is a Printer Maintenance request.
Ink Overflow -
you sould change the waste ink pads under the printer mechanic.
Solution:
Posted on Feb 16, 2009
SOURCE: Red & Green Lights keep flashing on Epson Stylus Photo1280
I had the same problem. You need to reset the waste ink counter:
1. Turn printer off, unplug power cord. Disconnect computor interface cable (back of the printer).
2. After one minute, reattach power cord, but not the computor interface cable.
3 Hold down the LOAD/EJECT and CLEANING buttons simultaneously (cleaning button has ink drop on it) .
4 Turn printer on. Release all buttons as soon as the paper out light flashes.
5 Quickly press the cleaning button, and hold for 10 sec while paper out light flashes.
6 Release the button and the printer will initialize.
7. Once the initialization is complete, turn the printer off.
8. Reconnect the interface cable.
9. Turn the printer on and try to print your document.
This process worked for me. Good luck!
Posted on Mar 30, 2009
aicaxz
  • 511 Answers
SOURCE: alternate flashing red lights on epson stylus photo 900
Flashing alternately? Need reset waste ink. SSc ver 4.3 support this model. Find at indoreset.blogspot.com.
Posted on Jun 26, 2009
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
Installed new colour inks on Epson stylus C48 and printer will not respond red light keeps flashing
hewlett packard c48 printer had a piece of paper stuck in it pulled it out, now paper goes through but print head does not print any suggestions
Oct 04, 2010 | Epson Stylus C48 InkJet Printer
Red and green lights flashing, won't print or respond to commands. Problem started when cleaning heads and subsequently testing with the print pattern. Monitor says a general printing error and suggests...
The heads are clogged. Unplug the printer remove the cartridges and dump them (never use the same brand of it or the same ink),pour some cleaning fluid there and leave it to soak. If you have some empty cartridges fill them with cleaning fluid and use them.
Oct 04, 2009 | Epson Stylus Photo 1290 InkJet Printer
Flashing Green and Red lights
i querried from epson site it says the ink is low, repalce cartridge
Step 1 WHICH MODEL ARE YOU USING? Stylus C44UX Step 2 What were you doing when the problem occurred? Turning on the printer Step 3 What happened when you were turning on your printer? An error appeared on its control panel Step 4 What is the power light's current state? Flashing Step 5 What is the error light's current state? Flashing Step 6 WHAT IS THE PRINTER'S STATUS? Ink low
Oct 28, 2008 | Epson Stylus C44UX InkJet Printer
Nothing comes out when I print
Epson 777 will not print. No paper jam. Power light flashing; red error light on steady. Paper does not feed; if paper supply is placed deeper in feed, entire paper supply (about 12 sheets) feeds thru as one sheet normally would , without printing.
Feb 27, 2008 | Epson Stylus Color 777i InkJet Printer
Epson C48 inkjet printer flashing lights
I can tell you how to fix this if anyone is interested - report back if so.
Jan 13, 2008 | Epson Stylus C48 InkJet Printer
Epsonstyluscx3810printer
try reseating the ink cartridges
if you still get the red ink error light - call EPSON with the date&place of purchase of the said inks
Dec 30, 2007 | Epson Stylus CX3810 All-In-One InkJet...
Epson Stylus Photo 825 InkJet Printer Logo
76 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
