Question about Craftsman Air Tools & Compressors
What makes model 919 152920 craftsman air compressor rattle when it plugged in
What makes a compressor rattle when i plug it in
  • 6 Answers
SOURCE: air compressor won't run
Don't run it with the head off! the cylinder will just up and down with the piston and ruin the seals again. I have three Craftsman compressors in my shop and I've torn them all down at least twice. Rather than pay for the kit, I went to NAPA and got a roll of cork gasket material and made my own seals. They don't last as long but they work great.
I'd be willing to bet your seal it just too tight. I made this mistake the first time around too. it's not a very good design as the piston tilts through the stroke. I would try putting a light coat of heavy weight oil on the cylinder wall and move the piston by hand to lube the seal.
Posted on Dec 17, 2008
  • 1388 Answers
SOURCE: Oil capacity for craftsman air compressor circa 1978 model #106..
I have a 2hp craftsman air compessor with a two cylinder pump, Here is the info from my manual as far as oil capacitity:
Remove oil fill plug and slowly add
a compressor oil until it is even with the
top of the oil fill hole. NOTE: Do not
allow oil to be lower than 3/8"
from the top at any time. When filling
the crankcase, the oil flows very slowly
into the pump. If the oil is added too
quickly, it will overflow and appear to
be full. NOTE: Crankcase oil capacity is
approximately 16 fluid ounces.
I buy my compessor oil from Lowes in the tool department. It comes in 16oz and sells for about $3. I wouldnt worry about how many ounces it holds but rather that the oil level is to top of filler hole. Lowes also sells a synthetic oil for about $7 and is recommended for severe conditions (hot / cold / used all day). Good Luck!
Posted on Apr 26, 2009
ollie reece
  • 1167 Answers
SOURCE: i have sears craftsman 22gal 5 hp air compressor not enough press
hi buddy strip the end off the check valve out and inside is a rubber turn this rubber around and try this if it still downt work it sounds like the pressure switch faulty get back to me
Posted on Oct 05, 2009
Testimonial: "thanks i took out the check valve i see the rubber but the valve is 1 piece should i just get a new one"
dmftrucker
  • 1922 Answers
SOURCE: Wiring diagram to convert Craftsman 5HP Air compressor
look on the motor cover or on the wiring cvr on mtr or on the inside of the wire termination cvr
Posted on Oct 06, 2009
  • 41 Answers
SOURCE: Compressor turns on but no air in tank. Oil level
Dismentl the valve plate check the gaskets and the valves,cif not good change and it wlii be ok
Posted on Oct 10, 2009
Craftsman air compressor model 919.16726 wont build pressure and makes a rattling sound
My compressor runs for about 5 min and shuts off.....does any one knows what could be the problem?
thanks
Aug 20, 2012 | Craftsman Air Tools & Compressors
I have an older Sears Craftsman air compressor 1hp, 100 psi twin cyl Model 106.154541. on the cyl base there is an oil fill directly across from this on the opposite side of the cyl base there is another...
The pump used on your compressor was incorporated into different designs thus needed access to oil fill from one side or the other. Part number for oil plug was std-220 or 27642, but you can use just regular standard pipe thread plug with square head. If the oil plug fits the other hole. Buy plumbing parts at Lowes. Good Luck
Mar 25, 2011 | Craftsman Air Tools & Compressors
Lost manual for Craftsman professional 60 gal vertical air compressor model no. 919.727280 & require it to determine how much oil the compressor takes Thnaks
The manual for this can be found at managemyhome.com. Look under manuals. It requires Adobe to read it. If you do not have it there is a plug in there. Thanks BB
Sep 19, 2010 | Craftsman Air Tools & Compressors
I just bought a used Craftsman air compressor at a garage sale...100PSI, twin cylinder, 1HP motor. Model # 106.154440. Runs fine, but wondered how to check the oil level in the compressor case and if it...
I have a Sears 106.154581 most likely like yours. You will find a small plug (fill hole) and slightly larger plug on side of pump close to bottom (drain hole). Fill compressor with compressor oil to top thread of fill hole. Oil should look rather clear with very little odor. Compressor oil is available at Lowes for about $3. Good luck
Aug 16, 2010 | Craftsman Air Tools & Compressors
6hp craftsman air compressor runs to 3 or 4
make sure it is plugged into a 20amp outlet. and do not use an extention cord
Jan 16, 2010 | Craftsman Air Tools & Compressors
Apr 25, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
10 year old air compressor cuts off at 10psi
hello, if you plug the compressor into a none gfi outlet does the compressor still cut off ? it could be one a short in your compressor causing the gfi to trip our your gfi has a ground try the compressor in a diffrent outlet, when you use any other electronic equipment on the gfi does it still trip ? if you use the compressor in a diffrent outlet that's none gfi this should sholve your problem most likely a bad gfi outlet or the compressor is drawing to much amp's.
Mar 28, 2009 | Craftsman 1 Hp, 4 Gal. Air Compressor
Over service craftsman air compressor with oil
Just find the drain plug and drain out some of the oil and put the plug back at the right time to get about the correct oil level.
The drain plug may be the sight window itself, if you can't find one.
If you need more help, post a comment.
Thanks,
Tim
Mar 27, 2009 | Craftsman 1 Hp, 4 Gal. Air Compressor
Air Tools & Compressors Logo
49 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
