Question about Plumbing
Price Pfister WKP-70 won't swivel
Faucet is very hard to move to the left or right. How do I fix that?
2 Suggested Answers
canwoodjc
  • 3301 Answers
SOURCE: Price pfister classic f-wkp-533s -
remove the handle,, Now you don't say if its the handle or the swing spout thats hard to turn, but this will work on both , (make sure the water is turned off) remove the retaining ring that holds down the ball cover sleeve, take that off and remove the either brass or plastic ball, NOTE: be sure and keep track of the direction of the slots in the ball so it goes back in the same way, some only go in one way, its those others that will give you fits ... once thats off remove the swing spout,, Now at home depot or most hardware stores they have plumbers grease, Its Kind of tacky but clear, and usually comes in a little disc , rub that on all O rings that you can see, replace any that look pinched or worn, reassemble,, your good to go !!
Posted on Jul 08, 2011
Price pfister classic series kitchen faucet stops between double sinks and will not turn into left sink.
Shut off the water under the sink, loosen the nut for the faucet careful not to strip it. Try to move the faucet into the desired position, if it works clean the areas of the connections that you can get to and tighten back down carefully so that the connections are not stripped and its not too tight. Make sure it moves as desired, turn the water back on. If it doesn\'t move after the main nut is loosed, then I suggest dismantling the faucet, clean it all with alcohol and try again. If not a new faucet may be in order, it is hard to properly replace the inside portions of a faucet without proper training, a handy type person could though. I suggest if internal faucet repair is attempted that you take the parts with you to the store and compare carefully. Good luck!
Oct 25, 2013 | Price Pfister Plumbing
Price pfister kitchen faucet spot leaking at joint
They are wrong. There is no O-Ring at the swivel joint and it is NOT serviceable.
May 20, 2012 | Price Pfister Plumbing
I have a Price Pfister faucet model F-534-70CC. It won't swivel,what do I do????
If this was a new install, back off the retaining nut a half turn. Most people have a habit of overtightening.
If it has been installed for quite some time, check to make sure that the sprayer hose is not wrapped around something or wegged somehow (under the sink).
Jul 08, 2011 | Microwave Ovens
Price pfister classic f-wkp-533s - too hard to turn left or right, help please
You have to take it apart, clean everything, replace the upper and lower "O" rings, and lube before putting it back together. You can often get the parts for free, due to lifetime warranty.
Furthermore, you may be able to have Price Pfister send you what you need, except the lube. Go for full cartridge, if you call them. You would prefer to only take it apart once. They are happy to ship to you for free, usually.
Jul 08, 2011 | Price Pfister Pfirst Single Handle Kitchen...
I have a Price Pfister Marielle Kitchen Faucet that looks exactly like Model No. F-026-3NCC. I need to replace the ceramic valve so I ordered part #Price Pfister 974-035. It looks similar to the valve in...
That faucet was discontinued some time back for the one you ordered parts for and the only way to get the part if it is still available is to know the part number. Now if you have a plumbing parts house in your area that specializes in faucet parts they may be able to match up the old part if you still have it.
If you can find the part number for the faucet you have then the part may still be available from Price Pfister.
Mar 03, 2011 | Price Pfister Marielle Kitchen Faucet with...
Looking for a price pfister marielle faucet installation instrucction. Model number026-4nzz
Call price Pfister at: 1-800-PFaucet
They have excellent customer service and can point you in the right direction.
Sep 30, 2010 | Price Pfister Marielle Kitchen Faucet with...
We cleaned our price pfister faucet because we had low cold water pressure - when we hooked it back up and put the handle back on the water will not turn off.
You more then likely replaced the diverter washer backwards. There is a washer/gasket that has multiple holes (2 or 3) and it is probably just rotated 180 clockwise (or counter).
There are very few moving parts in a faucet so this should fix it.
Apr 13, 2009 | Price Pfister 34-3LC Genesis Kitchen...
Need to install faucet
there need to be 3 coming off tap hot cold and infeed to pull out counter wieght about half way on pull out use plumbing tape thank you for useing fixya
Feb 22, 2009 | Price Pfister 18 Series Polished Chrome...
Plumbing Logo
44 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
