Question about Maytag SDE3606A Electric Dryer
Dryer is not heating air
I have a Maytag dryer, Model SDE3606AYW. It had been working well with no problems and suddenly stopped heating. It had been used to dry a couple of loads earlier the same day and was operating fine. Later that evening while trying to dry another load of laundry the dryer failed to heat the air.
  • 407 Answers
Sounds like the heating element or coil is out, but it could also be the board to. At any rate, if your not getting any heat what so ever, its more than likely electrical and its best to take it in. If it gets some kind of heat, then you might try cleaning out your dryer vents really good, and also in the dryer. Hope this helps.
Posted on Dec 28, 2009
Dryer was working fine. It's between 5 and 10 years old. Suddenly stopped heating. Model #HYG3658AWW Rev 14
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jul 06, 2011 | Maytag HYG3658AW Gas Dryer
My Maytag sde3606ayw dryer does nothing when you press start? Is it shot, or are there some things i can try to fix it? A reset button? etc? Thanks,
check for power, if power is good then check these things:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Dec 25, 2010 | Maytag Dryers
I have a Kenmore dryer model # MC0329088 that is 10-11 years old that all of a sudden stopped blowing hot air
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 18, 2010 | Dryers
My Neptune all of a sudden has stopped blowing hot air , I have had all the setting correct.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 10, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Open front panel on maytag Sde3606ayw?
there are 2 screws near the floor below the door that will let you access the lower front area,then you can remove the door assy and finally the top cover if necessary
Apr 19, 2010 | Dryers
Maytag dryer does not maintain heat and clothes smell
Check coils on burner assembly. Often when a dryer heats initially and then stops heating a coils has gone bad.
Nov 09, 2007 | Maytag MDG7600AW Gas Dryer
Maytag SDE3606A Electric Dryer Logo
243 people viewed this question
Top Maytag Dryers Experts
Mike Cairns
Mike Cairns
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
