Question about Kenmore Washing Machines
I have a kenmore washer 90 series model 110 92292100 that leaks at the bottom when tub is filling up .what is the problem?
  • 249 Answers
SOURCE: kenmore 90 series top load
blocked pressure switch bottle.clean out bottle.Close.
Posted on Nov 21, 2007
SOURCE: 90 Series Kenmore Washer Not going to spin cycle not draining water
I've had the same problem...you can purchase a replacement lid switch at your local appliance parts store for about $35. Fortunatly, the sales person at the appliance store had diagrams and provided instructions to replace the switch. I was able to finish the job and fix the switch in less than 1 hour. Good Luck.
Posted on Jan 05, 2009
  • 7 Answers
SOURCE: Kenmore 90 Series Washer
Kenmore 90 series model 110.28912791 stops and wont spin
Posted on Feb 02, 2009
Maytag317
  • 1136 Answers
SOURCE: Kenmore 90 series washer is leaking water from the pump. How do I remove the pump to repair or replace? Thanks!
Hi, You can change the pump by disconnecting power, water fill hoses, & take drain hose out od drain. Lay the washer on its back (use some padding under machine so that you do not damage threads on inlet valve. The pump is located on motor and has two clamps holding it. Just remove those clamps and the two drain hoses from the pump. The pump should release from the motor shaft. If the motor shaft is rusty, the pump might not want to come off ease and the shaft will need to be cleaned with sand paper or emery cloth so the new pump will go on easy. Failure to get the pump on all the way will cause the new pump to leak also.
Put your hoses back on the pump and everything should be ok.
I hope this helps you some.
Vic
Posted on May 10, 2009
  • 864 Answers
SOURCE: kenmore washing machine series 90 is leaking
Tip the washer onto the front and you will be able to see through the bottom to look for leaks.
Posted on May 31, 2009
Where to find fuses. My dryer is not heating up.
Does your dryer have power? If yes, then check (1) the flow of air outside the house from your dryer tube and (2) your circuit breaker panel for each circuit in the house (I've not seen fuses/breakers built into dryers -- though that could change). Then check (3) your heating element, (4) thermostat, (5) high-temp thermal cutoff switch, and (6) for debris in the air flow path to / from from the centrifugal fan.
Here are 3 resources that helped me with my Kenmore Series 90 Dryer:
No Heat? - http://chris-doityourselfrepair.blogspot.com/2011/10/kenmore-90-series-model-110-clothes.html
Looking Inside My Dryer - http://chris-doityourselfrepair.blogspot.com/search/label/Disassembling%20Kenmore%20Dryer%2090%20Series
Exterior Exhaust Duct - http://chris-doityourselfrepair.blogspot.com/2013/08/cleaning-out-and-replacing-exhaust-duct.html
Oct 10, 2014 | Kenmore Dryers
Kenmore series 90 - new motor coupler
What's your model number? "Series 90" doesn't really help, there's a lot of machines with that number.
Aug 07, 2013 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore 90 Plus Series Gas Dryer that will not heat
It could be several other things thermal fuse, thermal cut out, hi limit thermostat, dryer coils, heat sensor,or igniter. All of these parts are inexpensive and easy to test and replace.There is a video at t http://appliancehelponline.com/gdryertroublevideo.html his will walk you thru the troubleshooting of these components. It may be a different model but the troubleshooting will be the same.You can also enter your model # for diagrams and illustrations. All parts come with installation instructions. Not all models are available. If you need help disassembling your machine there are videos of this also for most styles.
Jul 01, 2010 | Dryers
How much would a water pump cost for a 1992 audi s100
here is a list from autozone depending on the engine model.
Warranty: 90 DAY REPLACEMENT IF DEFECTIVE $192.99 Part No. 8811 Warranty: 90 DAY REPLACEMENT IF DEFECTIVE $195.99
Edelbrock Victor Series Water Pumpadd_to_bag.png CI_ItemIDs[itemCounter] = '17140131_true_298221_1992|Audi|100 S'; itemCounter = itemCounter + 1; 17140139_edb_8851_pri_thmb.jpg Edelbrock Victor Series Water PumpPart No. 8851 Warranty: 90 DAY REPLACEMENT IF DEFECTIVE $203.29
Edelbrock Victor Series Water Pumpadd_to_bag.png CI_ItemIDs[itemCounter] = '17140139_true_298221_1992|Audi|100 S'; itemCounter = itemCounter + 1; 17140523_edb_8805_pri_thmb.jpg Edelbrock Victor Series Water PumpPart No. 8805 Warranty: 90 DAY REPLACEMENT IF DEFECTIVE $206.39
Apr 14, 2010 | 1992 Audi 100
CHANGE THE LID SWITCH
Apr 18, 2009 | Washing Machines
You have a broken lid switch. Its # ll in the diagram. Part # is 3949238. Let me know if you need info on how to replace it, Dave www.washermd.com
Dec 17, 2008 | Kenmore 23822 Top Load Washer
The viewing screen on our Cannon Power Shot 8520 is not working. The camera still takes pictures and I can download them on the camera. I just can't see what I have taken. So I'm looking for the viewing...
Hi....
Canon parts and repair service is excellent. All the parts of canon powershot is readily available in the market for reasonable price.
For your reference i am giving you the site where they take up these kind of problems.
the website is " http://www.mcvr.com/canon_powershot.htm#LCD ".
Replacing a broken or cracked LCD display screen:
  • Powershot A Series: $90 for most all models (a few dollars less on some)
  • Powershot S Series (S30 - S80, S100-S500, S1-IS, S2-IS): $90 for most models (a few dollars less on some)
  • Powershot SD200, SD300, SD400, SD630: $100 (the LCD for these models is more expensive)
  • All other Powershot SD Series models (including SD700IS and 800IS): $90
  • Powershot G2, G3: $90. Some other G series Powerhot models cost $10-20 more because of the higher parts cost.
The above price list is from the mentioned website.Hope my info is useful.
Bye.
Sep 19, 2008 | Cameras
Dryer not getting hot
fist make sure the fuses are good.. unit will run on 110 but not heat.. check connectores and cables or pigtail. it not.. then check heater coils and or thermostat...
Jun 13, 2008 | Kenmore Dryers
Washing Machines Logo
26 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
