Question about Lexmark X4270 All-In-One InkJet Printer
Says spooler not running
Everytime i try to down load,and you try to print it says spooler not running.
  • 787 Answers
This is not really a printer problem. The spooler not running is actually a computer problem. A quick non-technical way to try and get it going is to simply reboot your computer (it is a service that automatically loads on startup). If that does not work, right click on My Computer, select Manage, on the left at the bottom select Services. This should open a list of service in the pane on the right. Scroll to Print Spooler, Startup Type should be set to Automatic, if not, change it. If it is shown as Stopped, attempt to start it.
If this does not work you have deeper problems, make notes of any error messages when you try this and then post them.
Posted on Jan 02, 2009
I cannot print my documents, everytime I click the printer "print spooler is not running". I already restart my printer as well as my computer. And I also tried to reinstall my printer but it doesn
Click Start.
Type services.msc in the start search box and press enter.
Right click on print spooler and click on properties.
Check if the startup type is automatic. If it is not then change it to automatic.
Check if the service status is stopped.
If yes then click on the start button.
Try to add a printer and print a test page.
If you need any technical help on printer then you can reach at here
Jan 25, 2013 | Office Equipment & Supplies
When i try to load winfax pro 10 i get message stop printer spooler?
to stop the print spooler do this . Start ---Run----type Services.msc, it will open the services box there find for print spooler , open it and slick Stop button to stop and start to start.
Aug 14, 2012 | Symantec WinFax Pro for PC
My Lexmark Z705 Will not Print HELP
Use the Vista driver in Windows 7.
Also, make sure that the Print Spooler service in your computer is running. Try following the steps below:
  1. Browse to Start -> Run... and type in NET STOP SPOOLER (this will stop the print spooler service)
  2. Browse to your windows\system32\spool\PRINTERS\ folder. You should see files there ending in .SPL and .SHD created around the time you tried to print - delete these files.
  3. Browse to Start -> Run... and type in NET START SPOOLER (this will restart the print spooler service)
Try to print a document again to verify that the problem is fixed.
Feb 11, 2012 | Lexmark PhotoJet Z705 InkJet Printer
Spooler not runing
1. Click Start ---> Run 2. Type Services.msc 3. on the list look for Print Spooler Double Click
4. Set the dropdown to automatic... Click on start apply ... and then click on OK
Thanks for Choosing Fixya
Jul 18, 2011 | Office Equipment & Supplies
Actually my computer has a problem.everytime i want to print some documents is shows an error named spooler subsystem application error..i have canon LBP 2900B printer. plz help me out
Print spooler is no less than the main master of printing proceeding. Print spooler is a linking section between your PC and printing hardware. Print spooler is the only master of print province of your PC office. Print spooler can inkle nothing and encounter an artificial virus threat which will cease your printing operation and compel your print spooler down on the count. Sometimes to solve print spooler problem it is enouph to clear print spooler, but in most cases you won't get rid of it.
To get rid of it there is a tool named printer spooler fixer.
The link to get that is below.Just copy it and paste in your browser
http://www.printer-spooler.com/download/fix-wizard/PrinterSpoolerFixWizard3.exe?key=FixWizard
Jan 07, 2011 | Canon LASER SHOT LBP-2900 Printer
Out of paper issue
Instead of restarting, try this:
1. Start
2. Run
3. Type this in the box: services.msc
4. Hit ENTER
5. Scroll down to PRINT SPOOLER
6. Right-click on it and choose RESTART
this will clear out your print queue without having to restart. Good luck!!
Hi this is the more effective way to refresh the print queue.
Manually Stop and Restart the Spooler Service
1. Click Start, click Run, type command, and then click OK to display the command.com window.
2. Type net stop spooler, then press .
3. Type sc config spooler depend= RPCSS start= Auto, then press . The spaces between = and RPCSS and = and Auto are important. Without these spaces, the command fails.
Type net start spooler, then press
NARENDER KUMAR RANA
narendertacl@gmail.com
narendertacl@yahoo.com
narendertacl@hotmail.com
Nov 15, 2009 | Kodak EasyShare Printer Dock Series 3
Compaq computer running vista trying to add a printer message local print spooler is not running I have started the print spooler through admin tools but everytime I close the control panel it must switch...
Start the simple route: uninstall and reinstall the printer and its software. If the software is old, head to the printer manufacturer's website and download the latest driver package.
Meanwhile, track back to when the print spooler worked successfully. Was there any new software installed that may have caused the problem? A possible update from Windows, perhaps?
Sep 24, 2009 | HP Compaq Presario C500t Notebook
Print spooler
To prevent the spooler from stopping, which is usually caused by invalid printer drivers left on a computer.
Go into "Printers and Faxes" delete all printers which no longer exist by right click --> delete
To restart the spooler :-
click start --> run
type net spooler start click ok
or
click start --> run --> services.msc --> click ok
scroll down to print spooler --> right click on it and select start
Jan 30, 2009 | HP xw6600 Workstation with 650W 80 PLUS...
Trying to install the HP Deskjet F2210 printer onto my Dell with windows XP everything loads except the printer spool. What do I do?
Restart the Print Spooler:
start-> run-> type services.msc-> scroll down to the print spooler service n hit start.
Verify that that the Print Spooler service, and all the services that it depends on, are correctly installed and running.
  • Open the Services Management Console (click Start, Run and enter services.msc).
  • Double-click the Print Spooler service to open its Properties window.
  • On the General tab, check that Startup type is Automatic.
  • Select the Dependencies tab.
  • Note all of the dependent services listed, then close the Print Spooler Properties window.
  • Repeat the above steps for the dependent services noted.
If any of the dependent services are missing or cannot be started, try uninstalling all installed printer drivers and then reinstalling them.
If this method cannot be completed or does not resolve the problem, try Method 2.
Method 2
Remove all Print Spooler service dependencies other than the Remote Procedure Call service.
  • Click Start, Run and enter sc config spooler depend= RPCSS (there must be a space after "=" but not before it.)
By removing the other dependencies the Print Spooler service should be able to run, but the printer functionality may be affected, and it may be necessary to reinstall the printer drivers.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jan 11, 2009 | HP PSC 2210 All-In-One InkJet Printer
Spooler sub system app??
The issue occurs because of a corrupted printer driver installed and because of the Vista OS that keeps updating.
-Open up c:\windows\system32\spool\PRINTERS
-Delete the contents of the directory (not the directory).
-Restart the print spool service. (service.msc)
Jul 08, 2008 | Datacard SP55 Printer
Lexmark X4270 All-In-One InkJet Printer Logo
26 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
