Question about Altec Lansing Inmotion-IM600 (0021986954446) Docking Station
Battery into wireless remote?
How do you insert the battery to the wireless remote?
  • brubin0108 Jan 09, 2009
    Can't figure out how to get the battery into the remote.
  • Anonymous Jan 27, 2009
    remote control dosnot work
Turn the remote upside down, so the back side is facing you. Where the lines are on the bottom, take your thumb & move it in towards the right & pull towards you to open. Place the battery in the tray (you'll see it fits right in the slot) with the words on the battery facing up. Slide the tray back into the remote.
Hope this helps :)
Posted on Feb 26, 2009
  • 27 Answers
Look for a screw around the remote. a screw that could as small as an ant.
good day
Posted on Jan 10, 2009
Replaced batteries, outsid temp. does not display
Base Station Battery Installation
·Remove the printed vinyl label from the LCD screen of the base station
·Position the remote sensor near the base station
·Open the battery compartment at the back of the base station and insert (2) AA batteries according to the polarity markings. Replace the battery compartment cover.
·Within a short time the RF signal icon (located to the left of the outdoor temperature channel indicator) will start flashing. This indicates that the base station is ready to pick up the RF outdoor temperature signal from the remote sensor. It will continue to flash for 3 minutes or until the signal from the remote sensor is detected.
Register the Remote Sensor
·Open the battery compartment at the back of the remote sensor and slide the channel selector switch to your desired channel. For the first remote you may select any channel, for additional remotes select any unused channel
·Insert (2) AAA batteries according to the polarity markings. Be sure to install the batteries in the remote within the time that the RF signal icon is flashing on the base station.
1541 WeatherGuide Wireless Weather Forecaster with Barometer
Jan 05, 2016 | Taylor Measuring Tools & Sensors
We can not open the fob to insert the battery.
Sometimes the cover is small and hard to see. You may need to use a safety pin to push on the small release arm to get the cover off.
Mar 25, 2015 | Sharper Image The Wireless Remote Key...
Hi my desa door chime so-6180-RX does not ring. I have replaced the batteries and I have purchased a wireless remote WD-6104A, how do,I set it to function?
check if it has multiple radio channels and check if remote and door chime are on same radio channel. Check remote does not have a plastic insert stopping battery from contacting with its terminals also.
Jan 04, 2015 | Home Security
Cursor not working
Either the drivers were not installed or the device needs fresh batteries. Try a wireless USB mouse and keyboard.
Mar 17, 2014 | LG New Original ANMR3005/INSERT Remote...
Reset oregon scientific weather station
I always have trouble getting mine to work after changing the batteries, but I have just managed to get it going by doing the following:
taking batteries out of main unit
putting new battery in remote unit and pressing remote unit reset button
re-inserting batteries in main unit and pressing reset button.
i think the trick is to ensure that the batteries go in the remote unit first, then the main unit after that. It has taken me days to work this out!
Jan 19, 2013 | Oregon Scientific BAR206 Wireless Weather...
Using the soundlink wireless music system. was working fine. suddenly, both aux light and wireless light are on. not getting sound output from PC. how do I turn 'aux' off? pressing the 'sux' button...
Simply plug the small USB key into your computer, turn on the SoundLink system and select your music--iTunes, Pandora®, whatever you like. That's it. No networks to configure, no cables to run. And you can control your music using the handy remote.
Remove the battery in the machine and put back. Also, remove the battery in the remote and insert a good battery.
To turn off youe aux simply press the aux botton on your phone i am sure it will work.
Thanks for contacting Fixya
Jul 04, 2010 | Bose SoundLink Wireless Music System...
Trying to add the Dynex wireless remote to my HP Notebook
Right below the scroll button there is an eject button. Push this and slide out the cover. You will find the battery compartment. Insert 2, AAA batteries. Be careful about the polarity. It is marked. Just match the polarity. In between the 2 batteries you will find the receiver unit. Slide this one out. Insert this receiver unit into the USB port of your laptop. Close the battery compartment cover. Turn the mouse upside down. You will find an on/off (on the right side top) switch. switch it to on position. If the mouse is not detected, press the connect button below the on/off switch. Good luck.
Feb 08, 2010 | Dynex Wireless Optical Laptop Mouse...
How can I re active the wireless remote control system ?
sit in car all doors closed put key in ignition and turn from OFF to ACC 3 times as fast as you can leaving it in ACC on the last cycle then press your remote button. your blinkers should flash to tell you this has worked.... may take you a couple of tries to get it!!
Jun 30, 2009 | 2002 Toyota Camry Solara
This Rockster guitar from Psyclone Essentials, PSE6300B, is bad.
For use with RB (The Beatles version of RB, anyway), the instructions that come with the Rockster guitar are completely wrong. Unplug the wireless USB remote from the Wii. Insert a Wii remote into the guitar and use it as you would expect. Works just like it is supposed to.
Jun 05, 2009 | EA Sports Tiger Woods PGA Tour 08 for...
Altec Lansing Inmotion-IM600 (0021986954446) Docking Station Logo
369 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Sharps s
Level 1 Expert
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
