Question about Refrigerators
Is the push button on my hotpoint fridge freezer ffa52 iced diamond a fast freeze button
2 Suggested Answers
  • 833 Answers
SOURCE: Hotpoint Ice diamond fridge freezer both green & red lights on.?
bulmer...it takes about two days to fully defrost these units unless you take the freezer section cover off and use a heat source. If you do...be sure to protect yourself against water and electricity mixing....not healthy. See below for another note.
clean the condenser coils below the unit.
check for the amount of gas in the unit. It must be off for half an hour. Remove the back fiber panel. The big thing is the compressor. Clean off the largest pipe coming out of it. Plug the unit in...watch out for the fan! The pipe should frost up and then clear off or stay wet after about 5 minutes. It should not be frosty. If it is, you need refrigerant.
Note: If you do remove the inside freezer panel and defrost, you can see how much refrigerant you have in your unit. Start the unit. Wait 5 minutes and observe the coils. They should be evenly frosted end to end. If approximately so, you're good. If not, you're low on gas.
Posted on Dec 18, 2007
Hi Iv got a Hotpoint fridge freezer iced diamond rfa52 it keeps switching on and off it seems when the fridge gets warm it turns back on my freezer is not defrosting but the fridge is then freezing again...
Okay, have you adjusted your cold temp knob inside the fridge part? There are two switches one in the freezer and one in the fridge you will need to watch it day by day until the optimum temp setting has been achieved same goes for the freezer if it defrosts that is the exact point where your freezer is at best! It takes patience so be patient and your problem will be solved! Good luck and thanks again for using fixya.com
Oct 09, 2014 | Hotpoint Refrigerators
Hotpoint ffa52
a little tip you have to totaly defrost your f/f it will take a couple of days for the pipes in back to defrost compleatly and then dry it with a hairdryer and then plug it back in hope it helps
Jan 27, 2014 | Refrigerators
My two year old hotpoint FFA52 fridge freezer is not freezing the foods in the freezer and the fridge's body is worm, it sounds like it is working it just this two problem.help
since its been 2 yrs , there might be a problem with the condenser , the gas would have been empty, so its better if you get it checked by a technician, and refill the condenser.
thanks for rating Good luck
Jan 25, 2011 | Hotpoint Refrigerators
Hoypoint ffa9op.defrosted
hotpoint ffa90, I have fridge and freezer problem, non of them are keeping the required temperature though the fridge temperature is showing the right temperature but not cold and the freezer is not freezing as it is contstant between -2 to -5 but it should be
-22, the fast freeze bottom does not fridge either, it does not take instruction.
Feb 01, 2009 | Hotpoint FFA90 Bottom Freezer Refrigerator
Red light on Hotpoint Iced Diamond freezer
got a hot point iced diamond fridge/freezer, just got back off hols and red light on, all food defrosted with water running out of bottom. whats wrong?
Aug 27, 2008 | Refrigerators
Refrigerators Logo
51 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
