Question about Panasonic RC-6099 Clock Radio
Panasonic clock radio RC-6099 How to set the time
No manual with it. Seems to default back to 12.00. Buttons side and front??? Suspect it is my fault, not the equipment. Having access to a manual would help.
  • Anonymous Mar 19, 2014
    How do I set the time on Panasonic Radion X210
1. Press and hold button on top front marked: "Time Set" (also has "OFF" above it) 2. Using LHS buttons to go forward or reverse as marked press and hold until correct time is displayed. Middle button here will move it fast then release and use single button when closer. To set alarms either the Alarm 1 or 2 (also marked "Display/Adjust" held down while using the side buttons as before.
Posted on Oct 24, 2012
  • 2 more comments
  • jeanniealice
    jeanniealice Oct 24, 2012
    1. Press and hold "Time Set" button (also marked "Off")
    2.Use buttons on LHS to advance or reverse time (as labeled) Middle button here increases the speed while. The other buttons move the time set slowly forward or back.
    To set alarms use the "Alarm 1 or 2" buttons instead of "Time Set" and the side buttons as before.
  • Alan Rhodes Oct 24, 2012
    11/10. Appreciated!
  • jeanniealice
    jeanniealice Oct 25, 2012
    No worries. Glad to help :)
  • Alan Rhodes Oct 26, 2012
    Yes. The solution was right on the button!!!!
How to set time on model HD211B clock radio
1: Remove screw from top back of radio and carefully lift lid that retains buttons. Might be a good idea to take a pic of buttons so they don't get mixed up as they will just pop off at this point.
2: On either side of the back middle button you will see a switch and three (3) buttons.
3: Move "Off On Lock" switch to "Off" (left) position. You will see the unlocked symbol appear on the display.
4: Push far right button first to set your time "Zone" using the "Alarm Time" or "Radio Tune" buttons. Wait 5 seconds for the beep when done.
5: Push the "Time Set" button. (It is the one closest to the "Off On Lock" switch).
6: Use the "Alarm Time" or "Radio Tune" buttons to set the time. (Note: "PM" will appear in the upper left corner of the front display when your time is after noon!)
7: The time display will stop blinking and set about 8 seconds after your last move.
8: Push "Calen" button to set calendar. First the year the push the button again to scroll to the date.
9: Push the lock switch to the right and the lock symbol should disappear from the front display.
10: p
If you removed any buttons put them back, then put the cover back on and re install the screw.
or
Call the front desk and ask them to set or replace the clock.....
Oct 17, 2012 | Audio Players & Recorders
HOW DO I SET CLOCK
1 Press STANDBY/ON to turn off the unit, if it is turned on.
The clock flashes on the display window.
2 Press and hold PROGRAM/CLOCK SET for more than 2 seconds.
The hour digits start flashing.
AM
3 Press the CD forward or CD back button (track skip buttons) to adjust the hour, then press PROGRAM/CLOCK SET.
The minute digits start flashing.
PM
4 Press CD forward or CD back button (track skip buttons) to adjust the minutes, then press PROGRAM/CLOCK SET.
I hope this helps.. !
If you need more info have a look here for the manual which is in pdf format:
The clock information is on page 10
JVC RC-EX25 manual
Regards
Mike
Oct 12, 2010 | JVC RC-EX25 Radio/Cassette/CD Boombox
How do youn set the alarm clock
http://www2.panasonic.com/consumer-electronics/support/Audio/Portable-Audio/Boomboxes-Radios-Clocks/model.RC-CD500
click on this link for the manual
best of luck
Sep 21, 2010 | Panasonic RC-CD500 Clock Radio
I'm using my dad's old Panasonic RC-6064 alarm clock. How do I set the time and the alarm?
The Hour/Minute buttons are on the bottom of the radio. Just press the hour or minute buttons to adjust the regular time. Alarm is the same but you hold the alarm button on top.
May 18, 2010 | Vacuums
Changing the time
you can go to http://www2.oregonscientific.com/assets/manuals2/bar338pa.pdf to see or print the user's manual.
If you don't want to get the manual, here's what you do to fix it. . . . .
*note: you need to do this anytime you change the batteries.
1) open the battery cover
2) on the left side you'll see 3 little buttons labeled a)zone, b)C/F c)reset
3) push the reset
4)push the zone button until your time zone is highlighted on the front display
5) look at the front display & if you see a blinking "radio signal" icon at upper left of time numerals
don't do anything else. The time, date, etc. will automatically synchronize your clock with the US Atomic Clock. This could take up to 10 minutes. As long as the "radio signal" icon is blinking, it's working on it. When the icon doesnt' blink, it's set. Cool, huh?
6) if the area you live in can't receive the signal from the Atomic Clock, instead of a blinking "radio signal", you'll see just a bare antennae. Since you probably set your clock manually, that's what it shows now before you do anything.
7) after you push reset & set the time zone do NOT touch any other buttons to set anything!!! (I know it's difficult to leave things alone, but just sit on your hands). Pushing the "clock" button or the up & down arrows will stop the radio signal & change to manual functions. Look at the signal icon mentioned in 5) and 6) above. If you only have the bare antennae icon. . . . . go ahead & set the time/date yourself. You have no signal.
Enjoy your clock!
debkresh
Jan 25, 2009 | Oregon Scientific FM Weather Projection...
CD500 Clock Radio Problem
there is a button that says alarm hold it down as well as the minute and hour buttons to set the alarm you must hold down the alarm button and only use min or hour not both at once
Feb 24, 2008 | Panasonic RC-CD500 Clock Radio
Clock settings
- Please let us know the make and model number so that we can try to find the user manual for you. -
Oct 02, 2007 | Panasonic RC-6299 Clock Radio
Panasonic RC-6099 Clock Radio Logo
357 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
