Question about Coleman Powermate 4000 Watt Generator Parts, Rotor, Stator, End Cap, Brushes
Need stator for coleman powermate 40000
Model # Pm0544202----serial # 73211361---part # listed as 0049790' RPM 3600--60HZ
4 Suggested Answers
  • 75 Answers
SOURCE: Need to know about this generator will not power my home
Jo_jet, this should power most everything except A/C or heat. Most regular sized homes do not fun more than that constantly.
Posted on Dec 22, 2008
To find a manual for this generator go to powermate.com and search your model and serial number. Good luck!
Posted on Mar 16, 2009
19ken55
  • 426 Answers
SOURCE: Coleman Powermate Generator model PM0544202
Start by checking the circuit breaker.
Posted on Feb 04, 2011
Coleman Powermate 6750
You will need to check the resisitance of the stator and rotor windings, and also each rotor/ring to ground (IE rotor shaft) All tests to ground should be 0 M ohms, stators vary but typically around 1ohm or so, and rotors approx 20-30ohms
Nov 20, 2013 | Coleman Powermate Proforce 6,000 Watt 12...
I need to parallel my windings on a coleman powermate
You cannot parallel the windings, I assume it is a 240V system and you are attempting to do this to achieve more current at 120V you cannot do these and will damage the unit, the pitch of the stator windings are to achive out of phase 240V
Mar 30, 2013 | Coleman Powermate Powermate 5000W...
How to test stator
You will need a very high quality ohm meter that can account for test lead resisitance. Stator wire leads are ohmed right off the stator and their value is generally low 0.8 or less ohms (each generator model and windings is different) and needs comparing with a specific model factory service manual. Temperatore also affects this reading. Often best left to a pro with a low impedendance meter or a device called a wheatstone bridge, as the resistance is often too low to see on a conventional meter
Aug 04, 2012 | Coleman Powermate Powermate 5000W...
No output coleman powermate pm401211
Check the capacitor first,check rotor diodes, rotor and stator for shorts, and brushes
Oct 27, 2011 | Coleman Powermate Powermate 5000W...
Model pm0525312.18 serial 914080230 engine runs good but the voltage drops of from about 125volts to 90 volts when you put on about 1500 watts. does this model have a voltage regulator? what is a bridge...
According to the parts pdf, there is no voltage regulator. Voltage is adjusted by the rpm of the engine. If your have a meter that reads hertz (Hz), you can set the engine rpm by adjusting hertz to 60 cycles (Hz). At 60 cycles the engine is running at about 3600 rpm. Most engines develop their max horsepower at this rpm. If you are loosing power/voltage and the engine speed is not dropping below 3600, than most likely could be problem with capacitor, brushes or diode (bridge diode). The diode converts ac voltage from stator to direct current to power the magnet (rotor). Check for brush wear and test capacitor for value printed on part. It should test with 5% of stated value. Diode can also be easily tested with meter. Good holidays
Dec 05, 2010 | Coleman Powermate Powermate 5000W...
Coleman Generator not Making Power
actually, it sounds like the diodes are blown. Check our diodes.
As for checking stator, find the two wires, typically labeled L1 and L2 that are going to it. Measure with a multimeter. If there is no visual signs of damage, continuity can indicate a good stator. You should not have continuity between either wire and the stator frame.
The same goes for the rotor as well. The resistance measurements will not be the same for each one though.
Unfortunately, Powermate is out of business, and service information is scarce.
Aug 16, 2009 | Coleman Powermate Powermate 5000W...
Coleman 5500 watt output unbalanced
Get on their website and get the wiring diagrams. They should also have the resistances of the windings. Checking these resistances, may indicate a stator problem. Give the model number and it will be easier to help.
Jul 29, 2009 | Coleman Powermate Powermate 5000W...
Need to know about this generator. Coleman Powermate 6250 Gen power 305 5000 running watts Model PM0545008 Serial # E06601199B
Dec 05, 2008 | Coleman Powermate Premium Plus 6250W...
Coleman Powermate 4000 Watt Generator Parts, Rotor, Stator, End Cap, Brushes Logo
Top Coleman Electrical Supplies Experts
John Trevino
Shawn DuRee
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
