Westell Wirespeed LiteLine 6100 (B9961001002) Modem Logo
Posted on Jan 02, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Run Installation Wizard..
I received my westell modem DSL2+ Router today. I opened the box of modem and on the back there is a label that states that I need to run the installation Wizard before installing USB cable. Would you please explain to me how to do this? Does the modem have to be full connect before I can do this, in other words, all cables connect to modem and computer?? Please help, Dan
Anonymous
Level 2:
Scholar:
  • Expert 86 Answers
  • Posted on Jan 02, 2009
Anonymous
Expert
Level 2:
Scholar:
Answers
86
Questions
0
Helped
37766
Points
218
Yes. This means to say that you need to install all software that came with the modem, contained in a disc before connecting (installing) USB cable or anything else. After installation of the software and computer is restarted you can now then connect all peripherals for modem connection.
Is my westell modem (style: mstatea sku: f90 6100 2506) also a router?
to determine if a modem is also a router:
if it is a router:
1. at the back of the modem you should see 5 ports the first port labeled DSL and another 4 port labeled 1,2,3,4 that is for ETHERNET cable
if it is a modem only:
1. only 3 port that you can see at the back of the westell f90 1 for DSL, 1 for ETHERNET and 1 for power cord.
We bought the AT&T Motorola DSL Modem today, and we're trying to connect to wireless on a laptop and the connection isn't showing up. How do we fix this ?
  1. Ensure that your AT&T DSL self-installation kit is complete. At minimum, it should contain a DSL modem, an AC adapter, an Ethernet cable, a telephone cable, several telephone filters and an installation CD.
  2. Install the telephone filters on each telephone jack that you have a phone plugged into. Install a dual phone adapter on the jack closest to your computer if you have an answering or fax machine, telephone or analog modem in the same room. Then plug your telephone equipment into the filters. Connect the telephone cable that was provided with your installation kit into an unfiltered telephone jack.
  3. Insert the installation CD into your CD-ROM drive. If the installation program does not start automatically, click Start > Run > and browse to the CD-ROM drive directory to find the installation file.
  4. Connect the telephone cable that is attached to the unfiltered wall jack to the back of the DSL modem. Connect the Ethernet cable to the back of the modem and to the Ethernet network interface card port on the back of your computer. Connect the AC adapter to the back of the modem and plug it into an electrical outlet. Power the modem on.
  5. Check the modem lights. There should be at least two lights lit. These will have labels such as "Power" and "Ethernet." However, these labels may differ depending on the model of modem you received in your installation kit.
  6. Complete the software installation. Enter your chosen username and password when prompted. Check your modem to see if the light labeled "DSL" or "Internet" is lit. Open a web browser window to see if your DSL service has been successfully installed.
How to instal printer on dilink dir-888
i 1 D-Link DIR-855 User Manual 0
Section 2 - Installation
If you are connecting the router to a cable/DSL/satellite modem, please follow the steps below:
1. Place the router in an open and central location. Do not plug the power adapter into the router.
2. Turn the power off on your modem. If there is no on/off switch, then unplug the modem’s power adapter. Shut down your computer.
3. Unplug the Ethernet cable (that connects your computer to your modem) from your computer and place it into the Internet port on the router.
4. Plug an Ethernet cable into one of the four LAN ports on the router. Plug the other end into the Ethernet port on your computer.
5. Turn on or plug in your modem. Wait for the modem to boot (about 30 seconds).
6. Plug the power adapter to the router and connect to an outlet or power strip. Wait about 30 seconds for the router to boot.
7. Turn on your computer.
These instruction are on the CD that came with the router
Here is the start:
D-Link DIR-855 User Manual 13
The DIR-855 includes a Quick Router Setup Wizard CD. Follow the simple steps below to run the Setup Wizard to
guide you quickly through the installation process.
Insert the Quick Router Setup Wizard CD in the CD-ROM drive. The step-by-step instructions that follow are shown
in Windows® XP. The steps and screens are similar for the other Windows operating systems.
If the CD Autorun function does not automatically start on your computer, go to Start > Run. In the run box type
“D:\DIR855.exe” (where D: represents the drive letter of your CD-ROM drive).
When the autorun screen appears, click Install Router.
Section 3 - Configuration
Configuration
This section will show you how to configure your new D-Link wireless router using the web-based configuration utility.
Web-based Configuration Utility
To access the configuration utility, open a web-browser such as Internet Explorer and enter the IP address of the router (192.168.0.1).
Select Admin from the drop-down menu and then enter your password. Leave the password blank by default.
If you get a Page Cannot be Displayed error, please refer to the Troubleshooting section for assistance
Click Launch Internet Connection Setup Wizard to begin.
If you want to enter your settings without running the wizard, click Manual Configuration and skip to page 19.
follow the prompts.
You also can go to D-Iink.com for setup instructions
I need help connecting a westell 7500 router/modem,i want to get a notebook on line. i didnt receive any intsructions.i need help connecting the westell 7500 to my pc and notebook thanking you.
Westell makes a line of broadband home networking products that enable residential customers and users in small businesses to access and share broadband services. These inexpensive DSL router/modems offer multi-users Internet LAN access for home or business applications. The Westell router/modems allow you to have the benefits of the "always on" high-speed broadband Internet connection without losing the ability to receive voice calls over the same phone line.
  1. Step 1 288254_thumb.jpg Connect one end of the Ethernet cable to the computer's Ethernet port. Connect the other end to the Ethernet port on the back of the Westell router.
  2. Step 2 Connect the barrel end of the router's power cord to the connector labeled "12 v" on the back of the router. Plug the other end of the power cord into a wall outlet.
  3. Step 3 Connect one end of the DSL phone cable to the DSL line jack on the back of the router. Connect the other end to the wall jack.
  4. Step 4 Wait for the Ready and the Link LEDs to glow steady green. The router is now ready to use.
1helpful
Connecting 2 pc's to westel modem
No you cant.. But good router I preffer Linksys wrt54G2. Should just be able to plug ethernet from modem to WAN on wrt54g2.
Can I connect 2 PC's to a Westell DSL2 + ROUTER? 1 through usb and the other through Ethernet...
- If you want to connect 2PC's to your Westell, make sure your Westell router has 1 or more Ethernet ports on it for you to connect your 2PC'sto the Internet simultaneously, if hasn't you may need a desktop switch for it.
1helpful
2answers
I have a dlink router and I want to connect my usb modem to it
is this an additional router?
Verizon are issuing modem with built in wired and wireless modem.
Try this;
How do I properly set up a D-Link Router with a Westell Modem? (#7125)
This FAQ is for setting up a BellSouth supplied Westell 2100/2200/6100 modem (Models A90-210030-04, B90-220030-04 and B90-610030-06/C90-610030-06, respectively) with a D-Link DSL router. Although actual screen shots vary throughout the DLink line, the instructions below are applicable to all models. Important Note: These procedures and pictures are based on the most recent firmware for the Westell. Other Westell firmware menus and screenshots are slightly different but the bridge options and functions are still available. It is highly recommended that you click here and update your Westell firmware.
This FAQ has 3 Major sections:
Section 1 - Overview
Section 2 - Westell modem configuration
Section 3 - D-Link router configuration information
Section 4 - Connections and power up
bred.gifImportant Note: Due to some known operational issues it is VERY important that you have the latest firmware on your D-Link router. Please go to the D-Link Support Site for firmware updates.
bred.gif The best configuration for networking a router with the Westell is to set the Westell to "Bridged Ethernet" mode and allow the router to do the routing and DHCP functions. The Westell is also a router with full DHCP functions and may not function correctly when connected directly to another router. Not changing the modem to Bridged Ethernet will result in double NAT'ing, increased latency, possible IP conflicts, or possibly a network that doesn't work at all.
bred.gif Before proceeding both the modem and router should be set to default. Despite what the help desk tech tells you, resetting the Westell does not put it into Bridged Mode.
bred.gif The BellSouth Installation CD and Connection Manager are not required to use this configuration.
bred.gif Since BellSouth assigns static WAN IPs via your username the configurations shown are applicable to both dynamic and single static IP customers. Select dynamic PPPoE regardless of your setup.
bred.gif You must connect the Westell directly to the computer's NIC to make the necessary changes before you connect the router, because you will be unable to access the modem interface after you connect the router. The reason is that the modem interface is 192.168.1.254 which is a local IP. By default, most routers do not have the capability to route a local IP out of their WAN port (where your Westell is connected). Additionally, they may be on completely different subnets. After you have made the changes to the Westell you can then connect the router and configure it for use with FastAccess. There are several alternatives around this problem. One method involves extra equipment (second NIC and a hub) and major configuration changes. The second method requires you to utilize the router as a simple switch and use the Westell's PPPoE and DHCP functions. Click here for more information.
bred.gif If you encounter any problems simply reset the Westell, connect it directly to your NIC, restart your computer, log into the Westell interface, and start over again.
bred.gif More information about the Westell is available here.
Section 2 - Westell Configuration
bred.gifStep 1
Verify that your NIC card is set to "Obtain IP Address Automatically". Completely power down the Westell and the computer(s). Power up the modem and press the reset button on the back of the modem. After the modem has fully initialized connect the Westell to the NIC and then power up the computer.
bred.gifStep 2
Open a browser session and enter 192.168.1.254 in the URL address field to access the Westell interface. If you are unable to access the interface make sure your NIC is set to "Obtain an IP address automatically". This may require you to reboot the computer (or release/renew) to obtain a proper IP.
bred.gifStep 3
Click on Broadband DSL Line from the top menu. Click on Configure Connection from the right menu. Select "Bridged Ethernet" from the Protocol pull down. Click on Save and restart the connection at the bottom. This will automatically restart the modem and the interface will return after the changes are saved. Note: functions like NAT, DHCP, IP Passthrough, and username and password will be disabled or irrelevant and can not be selected. After the modem has restarted, power down both the computer and the modem then physically disconnect the Westell.
Section 3 - D-Link Router Information
bred.gifStep 4
After the PC is powered down connect one of the router LAN ports to the computer NIC and power up the router and then the computer.
bred.gifStep 5
Use the following steps to configure your D-Link DI-604 Router. Important Note: You must use the [email protected] format for your username. If you do not add "@bellsouth.net" after your username you will be unable to connect to the internet.
Section 4 - Connections and Power Up
bred.gifStep 6
Power everything down and physically connect the Westell, the router, and any computer(s).
Westell 2100 shown. Pictures by Andy Houtz
bred.gifStep 7
Power up the network equipment in this order:
•Westell Modem (wait till the Ready light is a steady green)
•D-Link Router
•Computer(s)
Open a browser session and go surfing!
bred.gifAdditional Imformation
•You should check your tweak settings to optimize your new network. Reminder: If you are required to change your MTU, make sure that it is identical on all equipment (PCs and routers) in the network. For more information about changing MTU on a D-Link please click here.
•The 6100 has an "Internet" light that is green whenever there is an active PPPoE session initiated by the Westell. Since you are using the DLink to establish the PPPoE session the light will stay off. This is normal.
Belkin router F5D7230-4
To be honest, I have installed several routers of my own and it runs better without the installation CD. Those CD's are controlling and make your life harder. All you need to do is turn off your computer. Then turn off your cable/DSL modem and unplug the power. Take the router, position it where you want, and plug in an ethernet cable going from the Modem to the back of the router in a slot labeled Internet. Then power on the modem and let it run for 1 min. Then power on the router, let run for 1 min. Take a second ethernet cable and plug it into your router labeled "1" and into the computer. Turn on the computer and check to see if you have internet. If you do, then you are good to go.
If you need additional help, contact me with a direct message.
1helpful
2answers
Westell Dsl2+ Router internet sharing
You can only use one or the other.
What you need is another router to plug the Westell one into. I have the same Westell modem and what I did was I plugged it into a wireless modem (since my Wii and Laptop use wireless) but it also has 4 LAN ports in case I need them.
Having a problem with netgear
Hook up the Cable from the DSL or Cable modem to the Router. Run one cable from the router to your main computer.
Open up Internet explorer and type in 192.168.0.1. or 192.168.1.0 to access the router setup . Run the setup wizard,
Top Westell Wirespeed Computers & Internet Experts
Sean Wright
Sean Wright
deton8 von Splosion
Are you a Westell Wirespeed Computer and Internet Expert? Answer questions, earn points and help others
