Question about Husqvarna 639005103 115 .105 Trimmer Line
Do Stihl, Echo, Husqvarna and Hitachi trimmer attachment interchange and fit on each others trimmers. I do know that some of the lower quality trimmers interchange attachments, but don't know about the higher quality ones. Thanks!
SOURCE: how to change blades
Use a large pair of pliers to hold the turning metal ring above the T35 trimmer head. I used a medium-sized pair of Channel Lock pliers. Then, turn the trimmer head counter-clockwise and it should unscrew from the mount. There's no need to open the trimmer head for this operation. Then, follow the parts diagram in the trimmer user manual to install the blade parts in the right order.
Posted on Jun 08, 2009
Tunneler
  • 27 Answers
SOURCE: I LOST THE MANUAL TO HUSQVARNA 128L TRIMMER HOW
Here's the link to the manual: Husqvarna 128l Manual
Posted on Aug 24, 2009
popsgifts
  • 160 Answers
SOURCE: how to replace accessories from a husqvarna power motor
Straight from Husky, the pole saw runs about $200...or if you have the straight shaft, you can get just the head for $185:
http://www.husqvarna.com/us/homeowner/products/trimmers/popular-accessories/
Posted on May 06, 2010
SOURCE: I have a Husqvarna trimmer model # 128LD.I want to
If you have the 128LD from Lowe's, Tractor Supply or Sears you can use TrimmerPlus attachments, any MTD manufactured attachments should work.
http://www.trimmerplus.com
Posted on Jul 17, 2010
suzukiracing
  • 200 Answers
SOURCE: Husqvarna vs Echo gas weed trimmers...needing your opinion.
They are very reliable brands stihl is a very good brand also.
Posted on Jul 19, 2010
Hi there, Im looking for a repair/workshop manual for a Stihl HS80 hedge trimmer. Any assistance would be greatly appreciated. Cheers Gavin
Stihl don't publish manuals as such, they want to preserve their dealers. An HS80 is not complex and if you go to Barretts Small Engines online they have exploded parts pictures which should be all you need to strip it. Stihl do owners manuals online.
Sep 27, 2016 | Echo Stihl Primer Fits Hs80 Hs80 Hs45 Hl45...
Does anyone know of another gear head that fits on a Stihl FS66 trimmer?
I was told the old shaft is 7/8 and the new one is 1 ". Looks like you could use a sleave.
Aug 25, 2012 | Stihl Garden
Echo tgrimmer wjring
hello, need a operators,parts manual for a stihl,echo chainsaw,hedge trimmer,line trimmer,edger,pole saws,concrete saw, as far as i know thay don't post any of these on line for the consumer,if i had a dealer number than i would be able to provide you with one,these manuals are available through the dealer only,hope this helps.``
Feb 08, 2012 | Echo Garden
Husqvarna 124 C trimmer. I need to find a piston stop and I don't know what size to order.
Stihl make a plastic piston stop that has both 'big' and 'small' fittings
Jun 23, 2011 | Husqvarna Garden
What oil mix ratio do i use for my huskvarna 123hd60
Husqvarna engines are made to tighter tolerances and are designed to run cooler. This is why the manufacturer recommends running a 50:1 mix. A richer mix of oil (such as 40:1) will run in the trimmer, but it will make alot of smoke, foul the spark plug, and clog the spark arrestor in a short period of time.
I recommend you stick with the 50:1 mix, and use Husqvarna, Stihl, or Echo 2 cycle mix. All three of these 2-cycle oils are a high grade oil designed to run in air cooled engines and they should not be substituted with cheaper brands
Feb 28, 2011 | Husqvarna 123HD60 22Inch 225cc 2Stroke Gas...
Jul 19, 2010 | Husqvarna 28cc Gas Line Trimmer
Need to know the gas to oil ratio for my feather lite weedeater. Model FL21
"Echo Power Blend Universal 2-Stroke Oil can be used in all of our 2-cycle air-cooled equipment ever made. You may also use this oil in any other brand of 2-cycle air cooled equipment, but it should always be mixed at the 50:1 ratio whether or not it was a 32:1 or 16:1 etc. machine. This oil is the highest quality 2-cycle oil on the market today. There is no need to have more than 1 tank of fuel for your 2-cycle equipment any more."
The above excerpt is from the Echo FAQs (6) here:
http://www.echo-usa.com/faqs/
Oil Mix Ratio:
The following ratios have been recommended for the last 10-15 years.
Dolmar, Echo, Efco, Homelite, Husqvarna, Jonsered, Makita, Oleo-Mac, Red Max, Ryobi, Shindaiwa, Solo, Spear & Jackson, Stihl & Tanaka; all recommend 50:1.
1 gallon of premium fuel to 2.6 ounces of quality 2-cycle oil.
4 liters of premium fuel to 80 milliliters of quality 2-cycle oil.
McCulloch, Poulan & Wen; recommend 40:1.
1 gallon of premium fuel to 3.2 ounces of quality 2-cycle oil.
4 liters of premium fuel to 100 milliliters of quality 2-cycle oil.
Chinese chainsaws recommend 25:1.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
May 17, 2010 | Echo Rapid Loader, Trimmer Head
The cable broke in the lower section of my ryobi trimmer rendering it inoperable.. please help! I do have 2 lower attachments for the ryobi trimmer however both the top section and the lower sections are...
These inexpensive trimmers are designed to be "throw-aways". It usually isn't cost efficient to repair something like this. Do yourself a favor and buy higher quality such as Echo. It will pay for itself and you will have less headaches.
Oct 08, 2009 | Poulan Weedeater/Electric Trimmer 4.1 Amp
How do fit a hedge trimmer attachment to a rbc 40 sb brushcutter ? thanks
This unit was not made to have interchangeable heads. Ryobi makes a hedge trimmer attachment for some of its units that are quick connect.
Otherwise, you may buy this attachment and see if you can interchange the head from the brushcutter to the hedge trimmer. You may find it more work than you want to tackle.
Sep 26, 2009 | Ryobi Garden
Husqvarna 639005103 115 .105 Trimmer Line Logo
970 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
