Question about Brother MFC-8480DN All-In-One Laser Printer
Mfc-8480dn amber flashing light and will not print to a computer or copy (any fuction from the machine.) How do I clear the yellow/amber light?
cene765
  • 787 Answers
SOURCE: I have a Brother mfc-240c - will not print yellow
The print head is clogged.If not unclogging with cleaning process may you try to clean manualy.You need to dissasembly the hole printer to remove the print head.Put it in hot water.If you don't have a technical skills, don't try anything.
If not help just buy new printer, because the new print head will cost you as much more.
Posted on Nov 06, 2009
  • 127 Answers
SOURCE: I have a Brother MFC-8480DN and since I've moved
your drum or toner needs replacing and or both of them..
Posted on Mar 31, 2010
techbuster
  • 5081 Answers
SOURCE: I have a Brother MFC-8460N printer all-in-one.
Did you check for paper jam?If not please do check it out there are chances are so minute paper being hidden some where
Posted on Jun 16, 2010
wheatlandsvc
  • 1110 Answers
SOURCE: I have a Brother printer MFC-8480DN and on the lcd
There is an installation sheet in the box the drum unit came in that tells you how to reset the drum indicator. Here is a link to my tip posted here at Fixya that may help you as well. If it works for you then please return to this posting as give feedback.
Thank You for using Fixya.
http://www.fixya.com/support/r5014960-brother_mfc_laser_printer_facsimile
Posted on Jul 23, 2010
  • 1570 Answers
SOURCE: IS THERE RESET OR CIRCUT
Yes, there is a RESTORE DEFAULT SETTING into the printing. But no circiut breaker for the bother. Go navigate to the LCD screen and it should be there in the GENERAL SETTING and choose LAN SETTING. From there choose RESTORE DEFAULT.
Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help.
Regards and thank you for using Fixya !
Posted on May 02, 2011
How do I reset my MFC8480DN after I have replaced the laser unit?
With the unit turned on and in ready state, press #'s 3 and 9 together and hold them down untill display changes to reset menu. Then scroll down to drum reset and follow prompts on display.
Feb 10, 2015 | Brother MFC-8480DN MFC8480DN...
Brother mfc-8480 with light print
Could be toner life end or laser unit is weak.
Jul 25, 2014 | Brother MFC-8480DN All-In-One Laser...
"Cannot be contacted over this network" after trouble shooting.
USB or Bluetooth? Put network settings in copier that match your inernet settings in Windows.
Nov 15, 2013 | Brother MFC-8480DN MFC8480DN...
I have a problem with print quality of my Brother printer mFC-6490CW, I have run the ink management utility, the black, yellow and magenta printed to about 95% just one dotted line missing on the black,...
Well, this is a common problem with people who purchase Brother printers, but do not always use Brother Ink Cartridges. Brother has a cleaning agent in the print cartridge and the compatibles do not.
"If you have a lack of one (or more) color do the following:
Make sure all carts are full, placed well and are secured. Insert a new ORIGINAL BROTHER CART for the one that shows no color.
Press menu then start bk-copy then four times arrow up quick after another. machine will switch into maintenance mode and all lights will flash. Press 7 then 6 then 4 then start bk-copy. machine will initialize the carts and refresh ink within tubes and print head. After that it does some power cleaning. When finished press 7 then 6 then 3 then start bk-copy. machine will run a power purge. when finished press 9 then 9 to leave the maintenance mode. do run a quality test print.
This should clean the lines out and clear up your issue.
Jun 20, 2011 | Brother MFC 6490CW InkJet Printer
Brother Printer 8480DN. How do I print an address
If you have Microsoft Word, open it, go to Tools, Letters and Mailings, Envelopes and Labels. You will have to set up the options for your particular printer. It works great with my Brother
Feb 02, 2010 | Brother MFC-8480DN All-In-One Laser...
Hi i have a mfc 210-c & the yellow wont print , i get 3/4 dots i have tried to clean with no luck
Try powerful cleaning:
Press menu, then start black copy, then four times arrow-up quickly after another.Machine will be in maintenance mode
(all lights will flash).
Press 7-6-4 and OK (or start-black-copy).
When finished press 7-6-3 then start black copy,
printer will do a power purge.
Leave maintenance mode by pressing 9-9.
If this not help better think about new printer, because cost of repairing this one is profitable.
Nov 19, 2009 | Brother MFC 210C All-In-One InkJet Printer
I Have a Brother MFC-640CW all-in-one Inkjet Printer. I changed the ink cartridges and I can get them all working except the yellow, when I do a Test print all the other colors come out perfect except for...
press menu then start bk copy then fourtimes arrow-up quickly after another. machine will be in maintenance mode (all lights will flash).
press 7-6-4 and OK (or start-bk-copy).
Machine will do some refreshing of ink and some special cleaning.
When finished press 7-6-3 start-bk copy
machine will do a power purge.
leave maintenance mode by pressing 9-9.
do run a test print.
DO USE ORIGINAL BROTHER INK or skyhorse generic ink only due to the fact that other generic ink will defenetly do damage to the printer!
Apr 23, 2008 | Office Equipment & Supplies
Colors not print well
This could be because of a defective valve.
DO NOT CLEAN THE PIEZO PH WITH ANY SOLUTION EXCEPT ORINIGNAL BROTHER INK!!!! OTHERWISE YOU WILL DEFENETLY DESTROY THE PH!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Try this:
Place new carts into machine and make sure thy are secured.
Press menu then start bk copy then fourtimes arrow up. machine will be in maintenance mode and lights will flash. press 7 then 6 then 4 then start bk copy. machine will refresh ink within tubes and ph and do some cleaning. when done press 7 then 6 then 3 then start bk copy. machine will do a power purge.
Leave maintenance afterwards by pressing 9 then 9. Do run a test print by pressing ink etc.
If you still cant see any yellow and/or magenta the ph is defective and needs replacement.
Oct 25, 2007 | Brother MFC 420CN All-In-One InkJet...
Brother MFC-8480DN All-In-One Laser Printer Logo
277 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
