Question about Marvel 61WC Wine Cooler
Marvel wine cooler model # 61WCM606 manual
System running but not cooling
4 Suggested Answers
aborcass
  • 2651 Answers
SOURCE: Marvel 61WC Wine Cooler
sorry for the delay in response time you definatly have a bad thermistor, not able to stabilze temp so it contionues run never shutting doen freezing everything, who ever repairs it (if they haven already,)make sure they put all 3 new peices in, thermistor, potentiometer, and contol box. all 3 come in one kit, 20 min to install
Posted on Mar 01, 2008
  • 101 Answers
SOURCE: Marvel wine refrigerator running,but not cooling
If your unit runs but does not cool, you have a "sealed system" issue. Either you are low on refrigerant which would be evident by frost build-up near the area where the freon first enters the evaporator plate. (lower middle, then travels left) or the compressor has lost the ability to develop the necessary differential pressure. You do not want to run the unit like that...you can **** in contaminants that will harm the compressor if you already haven't. You should contact a servicer to get it repaired. If you are still within the warranty period you should contact the dealer you got it from to initiate service.
Posted on Sep 15, 2009
  • 101 Answers
SOURCE: Marvel 61wc wine cooler turns on, but doesn't cool
If you can hear the compressor running and there is no cooling happening your unit has either lost it's refrigerant due to a leak or the compressor is completly worn out (or both). If you just hear the condenser fan running (air blowing), then maybe the compressor just has bad electricals (starting relay, overoad, run capactor) or it has developed a bad winding and will need to be replaced.
If you know you have lost refrigerant the repair will be quite costly and you should consider replacement. If you feel it is a failure of the small electrical parts for the compressor, repair would be more cost effective.
You can get further trouble-shooting assistance and order parts direct from the factory at 800-223-3900.
You can look up a local servicer on their web-site at www.lifeluxurymarvel.com
Should you desire to attempt electrical repair yourself, reply to me and I will provide further troubleshooting assistance or you can contact Marvel Customer Service at the number above. Good-Luck, Subdriver
Posted on Feb 05, 2010
Why does my wine cooler run too cold?
If after adjusting your thermostat to desired temp and is still cooling. The thermostat is bad or your relay is bad
If you disconnect the thermostat and the compressor stops it most likely a bad thermostat
If you disconnect the relay from
The thermostat and it stay running it is the relay. It is sticking
If possible store you wine somewhere else and shut the unit down and unplug for 10 to 20 minutes this may cause some melt of condensation some water may be on the floor if is to cold
This may also reset the system.
Jul 26, 2015 | Marvel 61WC Wine Cooler
Marvel 6BAR6004 not cooling
check you themoistat it may be coated with sofa
Jul 04, 2014 | Marvel 61WC Wine Cooler
My wine cooler will not run at all. The compressor is Ok. The cooler uses relay 41006036 rev E. I do get continuity on both the pot and the thermistor. What is the correct resistance for the thermistor...
Hi
Please check this link to read detailed information related to wine cooler as per your query:-
http://www.winecoolerexpert.com/wine-cooler-faq.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
May 05, 2011 | Marvel (6SBARBSG) Wine Cooler
I have a marvel wine cooler that frosts up and also tends to have temperture issues. Bottles on second shelf freeze. Temp adjustments to less cold make it too warm.
you have a restriction in the cooling side sounds like the filter line dryer is clogged up and will need to be replaced. Also the system will have to be recharged by a professional check to see if its in warranty.
Dec 17, 2010 | Marvel 6BAR Wine Cooler
Not cooling and frosting up on the upper right side in back
Sounds like a leak in the refrigerant system. Need a certified technician for this repair.
Apr 22, 2010 | Marvel (6SBARBSG) Wine Cooler
Jan 28, 2010 | Marvel 61WC Wine Cooler
My marvel wine cooler is 9 years old and no longer runs. The light works but nothing else runs. Might this be the thermostat? iif so where would I ge a replacement and would would it cost?
This could very well be the thermostat (pre-2000) or part of the temperature control system (2000 to 2009) which has three parts: The thermsitor (usually the culprit), the potentiometer (connected the the control dial) or the control board. Call the factory at 800-223-3900 with your serial number (to identify which control it uses) and you can buy the part direct from them. The control kit is about $150.00, the old style thermostat about $100,00 and if it is just the thermsistor, it's about $50.00 (I haven't checked their prices in awhile)
Jan 18, 2010 | Marvel 61WC Wine Cooler
Marvel Cooler/Fridge Light Not Working
It sounds like the bulb is not getting power. There is a door switch that turns it off when the door closes...this may be stuck. There is usually an optional (depending on age) ON/OFF switch that overrides the light to be on full time. If the light will also not turn on with that switch then there must be a disconnected or broken wire either going to the light switches or going to the light socket from the switches. I hope this helps.
Aug 30, 2008 | Marvel (6SBARBSG) Wine Cooler
Dec 02, 2007 | Marvel 61WC Wine Cooler
Wine cooler doesn't cool properly
Few things to check here. If the compressor is not running then the problem may be a bad thermostat or the compressor start device (ptc starter). Most common would be the thermostat on wine coolers. Also need to check if the fan is running. If everything is running then you have a sealed system problem. If the fan is the only thing that is not running that will cause a no cool situation.
Oct 07, 2007 | Marvel 61WC Wine Cooler
Marvel 61WC Wine Cooler Logo
108 people viewed this question
Top Marvel Furniture Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Joseph Hoffmann
Are you a Marvel Furniture Expert? Answer questions, earn points and help others
