Hot Water Stays On
Everytime I Switch On My Boiler, the hot water starts automatically without any hot water actually running. Help!
  • 30 Answers
If this is a combi boiler switch off the boiler and call an engineer it sounds like the diverter valve is stuck
Posted on Mar 26, 2009
My central heating turns off when i turn the hot water tap on. when i turn it off the central heating doesn't come back back on until i turn the power off and on.
Combi-boiler-turn hot water tap on/off and the heating stops for ...
singletrackworld.com/.../combi-boiler-turn-hot-water-tap-onoff-and-the-...
Combi-boiler-turn hot water tap on/off and the heating stops for 20secs ... hot watertakes priority over central heating so when you run the hot tap, heating is ... Yeah onmy worcester combi there is a diverter valve - it feeds either the heating or ...
My central heating works but I have no hot water - 24'7 ...
https://www.247homerescue.co.uk/my-central-heating-works-but-i-have-...
Diverter valves switch heat between the hot water and the central heating. When youturn your hot tap on, the diverter valve temporarily shuts off the water supply ...
Does your boiler keep switching itself off? Here's why ...
www.dhs-uk.com/does-your-boiler-keep-switching-itself-off-heres-why/
Jul 7, 2015 - ... Bathroom Suites, - Showers, - Wet Rooms, - Taps and Accessories, Information and ... Low water pressure can cause your boiler to turn itself off. ... boiler is not turning off, you aren't getting the amount of hot water you require. ... If there is air in your central heating system, then your boiler may shut down.
Feb 09, 2016 | Water Water Heaters
Why can't i fill my boiler
You didn't specify what kind of boiler you have. Some low pressure steam boilers have a manual fill valve as well as an automatic float switch valve. Hot water boilers have a pressure reducing valve that constantly monitor the boiler pressure and maintain 12 to 18 PSI for the safety of the boiler. If the boiler runs out of water there is a good chance it will rupture and become unrepairable. If you are saying your boiler won't fill, and its a hot water boiler, the pressure reducing valve is probably blocked with sediment and needs replacement. The valve is in the water line that feeds directly into the boiler return line from city water. Hope this helps.
Oct 01, 2014 | Water Heaters
Wickes 102 combi boiler constantly loosing water pressure
It sounds like your thermostat could be the problem. Have you noticed the boiler cutting off at all, or does it run continuously until it goes out on low water?
You stated, "when boiler is on", so I am wondering how you get the boiler on. If your boiler is controlled by a thermostat, you need to check it for a cold draft possibly from behind the thermostat in the wall where the wires come through. The thermostat should never be on an outside wall. The thermostat could be defective.
An aquastat can also control your boiler. If you have an aquastat, check the setting, typically 175 - 180 degrees. You should also have a "high limit" which should be set at 210 - 220. Some people run that high side limit higher; not a good idea - defeats the purpose. If the aquastat is set too high, the boiler will operate too hot and the problem you have will occur.
"pressure rises and pressure relief valve opens" This could mean that your pressure switch is prematurely venting. Check boiler temperature to see exactly at what temperature the T&P valve purges. If it blows off below the high side setting, either adjust or replace. The T&P valves are usually not adjustable. That blow off temperature is stamped on the head of the valve. So, if it discharges too soon, replace it.
Have you actually seen evidence thgat the T&P valve is opening? You may have a bad bladder in your expansion tank and your system may have air in it. Your boiler should have 12 psi when cold and 20 - 22 psi when operating. Check your boiler pressure guage.
this eventually drops below the minimum operating pressure" Technically, there is set point for a NO MINIMUM OPERATING PRESSURE. That is a function of the amount of water in the boiler. If the T&P is blowing off, it will vent water from the boiler and the boiler pressure will go down. There is a minimum operating TEMPERATURE.
Your boiler could be low on water. You will have to manually fill the boiler. Be careful of thermal shock to the boiler. Feel the piping, and fill only when the circulator is running. Make sure the water is not going directly into the boiler. The supply water should go into the circulating supply side which feeds the radiators, radiant floor, or base board circuits.
All this will adversely affect your hot water. The heat exchanger for the potable hot water may have scale build up in it. Using the hot water keeps the boiler running, and a scaled heat exchanger will give you cooler hot water and the boiler keeps running. If this is a problem, you will need to replace the heat exchanger. A better idea is to not use the boiler for your domestic hot water. Why run the boiler in the summer?
Feb 02, 2013 | Water Heaters
Puma 80 potterton hot water on and off
Boiler compartment ventilation will not stop you getting hot water . Its sounds like you have problems with a sensor or the water section on the boiler .
Apr 20, 2017 | Water Heaters
Problem with hot water from Vokera Excell 80sp boiler
Hi - hope someone can help. I have a VOKERA EXCEL 80SP combi boiler and been without hot water/central heating for two days. The pilot light is on, the fan is on, but boiler not triggering once the hot water tap is turned on.
Hopefully someone come to look at it today but hoping for some advice. Anyone else had this problem?
Thank you.
Dec 21, 2009 | Water Heaters
Code 13 help... Everytime I go to use the shower (a mixing system of hot and cold) Code 13-- Code 12 the system shuts down. If I just use hot or cold I am fine-- Any one?
if cold supply to boiler and shower are off the same feed this could be your problem as the boiler governs flow of hot water best of luck
Oct 20, 2009 | Rheem EcoSense by 4.2 GPM Tankless Water...
Vaillant ecoMAX 828/2boiler goes on & off when running hot water!
water must be set at 3lts a min ,check diaphragm valve move when hot tap is on, check microswitch ,best of luck
Aug 09, 2009 | Water Heaters
Baxi/Potterton wall hung fan assisted combi boiler
does the boiler come on when the hot water tap is run if not change the hot water flow switch or the diaphram in the hot water flow valve it may be split
Nov 02, 2008 | Combi Centre DX - Mango
No hot water help
have a ariston euro combi boiler ,the problem to get hot water i have to turn the heating on to get hot water. but now it only run for a few min then run cold please help
Feb 18, 2008 | Washing Machines
Heating & Cooling Logo
102 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
