Question about OKI C Office Equipment & Supplies
RESET OKI MC360 DRUM
I DON'T WANT TO BUY NEW DRUMS, I WOULD LIKE TO RESET DRUM COUNTER SO I CAN CONTINUE TO USE THESE OLD DRUMS. PRINTER QUALITY IS NOT IMPORTANT.
SOURCE: how to reset drum counter for brother hl4070cdw laser printer
When you replace the drum unit with a new one, you need to reset the drum counter by completing the following steps:
  1. Turn the printer power switch back on.
  2. Press the + or - button to choose "Machine Info".
  3. Press OK to proceed to the next menu level, and then press the + or - button to choose
    "Reset Parts Life".
  4. Press OK, and then press the + button to choose "Drum Unit".
  5. Press OK two times.
Posted on Aug 29, 2009
  • 628 Answers
SOURCE: OKI c5600 drum reset
It usually resets automatically when you replace the drum/toner units. Are you trying to get it to reset before it's supposed to? I don't know of any way you can do that.
Posted on Apr 20, 2009
HobbesVT
  • 3 Answers
SOURCE: drum reset for Panasonic kx-mb781
There is a little special (white) gear on the outer left side of the drumkit - a little bit below where the toner sits. That gear joins with toner mixing assy - and you can rotate it in counterclockwise all the way back. This should reset the drum counter - worked for me - I hope it also does the trick for you ;-)
Posted on May 03, 2009
Shah_Sheh
  • 81 Answers
SOURCE: how to reset black drum counter OKI C3300
The consumable counters are aotomatically reset on the OKI C3300n models.
If the printer has a message displayed or you need more assistance leave a comment
Posted on Sep 15, 2009
shawn38
  • 200 Answers
SOURCE: I have an OKI C3400 color laser printer. Can the
The counters reset when you install the new drums. Did you purchase Oki drums or were they after market drums..that could be the problem.
Posted on Feb 19, 2010
How to reset drums on oki c5950
Amber's solution worked on an oki c5150 as well as on her 5500.
At first, I got into other menus and did not see what she'd described. I cancelled out, then re-ran her procedure following its steps EXACTLY... At the very end, I may have seen one additional message - "EXECUTE" - which I "entered" to launch the process. Printer now works while I find instructions on how to replace "just the drum".
The OEM drum assembly is very easy to change but costs about $125. I found (on Universal Ink & Toner) a drum-only replacement for $30, but there was no instruction sheet with it. This solution has allowed me to keep working while I figure out how to install the new drum. Print quality was excellent right up until the manufacturer's internal counter shut printing down. Quality remains excellent after applying the above solution.
THANK YOU AMBER
Dave
May 08, 2014 | OKI C Office Equipment & Supplies
Problem 391 on OKI C5200 printer but no paper jam was found.
Open the top. Pull on the top of the toner cartridge (don't release the latch, just pull it up). It will come up with the toner drum assembly attached. You will probably see another paper stuck there which can't be seen when the drums are installed. Also, open the back door and look for paper that might be stuck. But usually, when you've checked everywhere else, the remaining paper is flat under the toner drums. Once you get it out, just click the drum/toner assemblies back in place (careful not to let the green drum touch anything while it's out of the printer.
Mar 06, 2012 | OKI C5200n Laser Printer
How do I reset the drum counter on the a Brother MFC-7840W???
open the front cover of the machine then press clear back it will say replace drum? press ok
the quality will probably start getting pretty bad as you will be using the drum passed it's life
Mar 22, 2010 | Brother MFC 7840W Printer
How do you rest an OKI c3530 image drum
Turn off the printer
Turn the printer on whilst holding down Menu button. (Display says user maintenance.)
Press the menu button three times. (The display will say drum counter reset.)
Press enter key. The system should go back on line, if not press on-line key.
You can just put a new fuse on the drum.
When you insert the drum the machine resets the counter and then blows the fuse. So if the unit is ok and you just wish to run it through another cycle just change the fuse.
This means you cannot just put a full unit in from another machine as it will not reset the counter until you put a new fuse in it as you found out.
This applies to drums transfer belt etc.
Note with regard to refilling the toner, some printers have 2 sections. 1 where you put the fresh toner and an after collection section in the same unit. You must empty the 2nd section if you refill it more than 2 or 3 times
Oct 07, 2009 | OKI C3400n Laser Printer
How to reset black drum counter OKI C3300 ?
Buy a pack of 10 x .062A (1/16A) pico fuse RS part No 738-3062. Switch off printer. Remove the drum and toner together from the drum slot to be reset. Carefully crimp the legs of the fuse around the contact wires on the right side of the drum slot. Make sure fuse legs are making a good connection to the wires and aren't touching the frame. switch on printer and allow it to detect the absence of the drum. Switch off printer and carefully remove the now blown fuse. Re-install the toner and drum assemnbly. Drum life is now reset. see pic:
Sep 15, 2009 | OKI C3400n Laser Printer
Drum reset procedure for all three colors
There are fuses in drums that needs to be replaced in order to keep working with these drums. It's 1/16A fuses and NO MORE!!! Drum disassembly required to find a place where fuse is.
May 21, 2009 | OKI C5200n Laser Printer
How can I reset my Drum Life Counter on my Printer?
http://my.okidata.com/PP-B4250.nsf?opendatabase
Guide Users: B4250 download user manual
American English
May 06, 2009 | OKI B4250n Laser Printer
K image drum
Go to
menu>Configure Device>Print Quality>select Full calibrate now
once it's completed then run following action:
Menu>Configure Device>Reset>Reset Supplies>New transfer kit>yes
you are done but it works if there still remaining bit transfer kit if its run out then not gonna work.
Good luck and rate all answers.
Mar 31, 2009 | OKI B4600 Printer
Oki c5500n drum reset
To get the OKI C5500 to keep going (without opening and closing the lid constantly) in spite of toner cartridge & drum life messages:
1) Turn off printer.
2) Hold down "+" and "-" buttons at the same time, and keep them held down while turning printer back on... continue to hold until the word "OKIUSER" appears.
3) Use "-" button to scroll down to "FUSE KEEP MODE".
4) Press "Enter" button, hold for approx. 10 seconds, then release.
5) Press "Enter" button again, followed by rapid release and repress with hold for approx. 10 seconds.
6) Release "Enter" button, then press and let up one more time quickly.
7) You will see "INITIALING" and then "ONLINE" messages.
If you currently have an error message for toner cartridge life, the message will continue to be shown until after you've sent one print job, and then it will usually disappear for awhile. It will stay gone for longer if you have your printer set up so the toner sensor is turned off.
If you currently have a error message for drum life, it will continue to appear, but you will still be able to print.
Beware that you will have to keep a closer eye on print quality (since you are no longer relying on error message to tell you when your toner cartridges are in need of a replacement or refill, or the drum truly needs to be changed or refurbished).
Please note that anytime you turn the printer off, you will have to go through the whole process again when you turn it back on. It doesn't take long though, and will quickly become habit whenever turning on your printer for the day!
Good Luck.
Apr 08, 2008 | OKI C5500n Printer
696 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
