Question about ASUS Air Notebook
Hi i have an asus laptop F3Jseries 3years old. when starting up, nothing appears on the display jiva
  • jiva1 Jan 03, 2009
    hi rylee
    thanks for your reply
    just the normal sounds of start up. but nothing on screen
    has happened afew times before, but after repeated trys the screen lit up
    this time no such luck
    jiva
  • Rylee Smith
    Rylee Smith May 11, 2010
    Hi! Jiva can you hear a beep sound or any sound pattern when your asus powers up?
Asus as cm1630 cp ws 830/18g has no video
This could be a number of issues. When starting the laptop, do you get any image at any point? Such as the ASUS splash screen? Does it only lose display once you boot into your OS?
If you see nothing at any point, the first thing I would try (providing you are certain your laptop is booting in the background and just has no display) is connecting an external monitor. If you get a display you can be fairly sure your LCD cable or screen are to blame. If not, you could have an issue with your graphics chip or mainboard.
Jan 28, 2014 | ASUS Computers & Internet
Nothing appears on the monitor
Press the Fn-key + F7 to switch the display on/off.
Aug 11, 2013 | ASUS S200E-RHI3T73 11.6" Multitouch Laptop
How do u operate the webcam on my asus laptop? I have a webcam oin my laptop. Do I need a driver or what? I know nothing.
start>then type "webcam" /"web cam"/"camera"(without " ") try either of those key words.if nothing appears, try downloading youcam.
Sep 03, 2011 | ASUS Laptop / AMD Turion II Processor /...
Is scratching of hard disk normal? my ASUS laptop does not start ( no display ) and the indicator of hard disk reading is off
The scratching noise is not normal. This hard disk appears to be faulty especially if the hard disk LED does not light up.
Apr 16, 2011 | ASUS K52JKA1 156Inch Versatile...
This message appears on the screen after the ASUS screen. Then nothing. Help
In Most cases if a screen can display and shows signs that your laptop was loading then shows nothing later many times your windows may be corrupt or damaged so you will need to re-install windows on your laptop....i would recommend windows xp 2 and just after installing please try installing an anti virus immediately before any other program is added and don't forget to update the anti virus first. Please also give more information on what kind of message appears before the screen goes blank.
Apr 13, 2011 | Computers & Internet
Hi - I have an Asus Eee PC and when i turn it on, the screen is black, the lights are on and its fully charged but nothing else happens...
The issue might be corrupted display drivers, I recommend you to boot the laptop in safe mode by using F8 key and if you are able to get into safe mode, update your display drivers and update BIOS.
Visit the below link for more information:
http://notebook-solutions.blogspot.com/2009/05/notebook-solutions-notebook-solutions.html
Aug 22, 2010 | Asus Eee 701Sd Notebook
Asus 1000he red vertical line in monitor will not
Hi
If you have External Monitor check by connecting it
if you get display on external monitor without line it means Display screen is Bad, if Line appears on external display as well then there is either Display driver issue or motherboard problem.
Jul 19, 2009 | ASUS Eee PC 1000H Laptop
Compaq Presario Laptop lost power
the battery charger board, is what I would swap first.
Good luck, keep us posted.
Nov 15, 2007 | Computers & Internet
ASUS Air Notebook Logo
106 people viewed this question
Top ASUS Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
