Question about Ricoh Aficio SP C411DN Laser Printer
Load paper in bypass tray - Ricoh Aficio SP C411DN Laser Printer
2 Suggested Answers
SOURCE: trying to print but it ask me to load paper or form feed. also got a bypass tray message.
the problem is in the printer settings of the file you are printing, if it is set to print from bypass tray. You can load paper into the bypass tray and it will fix it. If you have a Multi Function Product (MFP) commercial grade with multiple paper sources, this message may come up again. How to fix? In the file/documents properties (word, excell. PDF,etc.) go to the File menu OF THAT document and change the "paper set up/page settiings/paer source" from bypass TO Automatic or Auto Paper. Re save the file/document and it will save your new paper source settings. If someone sends you a file, or you upgraded to a bigger machine, this message may come up and you will have to make these cahnges due to the fact that the document was created with smaller product printer/page settings. The default auto paper on business MFP's is set for a tray, not a bypass tray.
Posted on Aug 28, 2009
Sharp mx3110n printer won't use bypass tray? Trying to print on glossy paper using that tray and it won't, it automatically switches to tray 1. Or can I just put glossy paper in tray 1?
Hello Laura,
Here is the pdf that explains how to set up th bypass tray; http://support.appstate.edu/sites/support.appstate.edu/files/MX3110%20USE%20SPECIAL%20PAPER%20IN%20THE%20BYPASS.pdf
The text of it is as follows;
TO USE SPECIAL PAPER IN THE BYPASS
? Press either the picture of the copier or press
paper select
? Load paper in the bypass
? Make sure the correct size shows up under
bypass tray
? If paper is not just plain paper press type and
size
? Choose paper type
? If you are printing to the bypass from your
computer you must also tell the print driver
under the paper tab what type of paper is in
the bypass if its not just plain paper
? The copier and the PC must match paper
types
? Press the X button to Accept
Good Luck!
Rich Lilja
Feb 21, 2015 | Sharp Office Equipment & Supplies
How do i print on cardboard (heavy paper card)
The mx2300n only supports up to 209gsm heavy card. You must make sure that your heavy card is not over this rating.
Set the bypass tray as 'Heavy' by clicking on the trays on the main copy mode screen, select type & size for bypass. Select heavy, and Auto AB as this will allow the tray guides to detect the size of your paper. Load the tray with up to 20 sheets of Heavy paper.
Open your document, select Print, then properties. Under the 'paper' tab, select paper source as bypass tray, and paper type as heavy (if you miss one of these steps, the ,machine will ask to load paper due to size or type mismatch).
That's pretty much it.
Oct 16, 2013 | Sharp MX-2300N Color Copier
Can I print envelopes on my Bizhub 250
BYPASS TRAY is sed when printing onto paper with a size not loaded into a paper tray or onto thick paper, overhead projector transparencies, postcards, envelopes or label sheets Can be loaded with up to 150 sheets of plain paper, 50 overhead projector transparencies, postcards, label sheets or sheets of thick paper, or 10 envelopes referred to as the "bypass tray" throughout the manual. (See page 2-60....ATTACHED )
ftp://207.18.56.26/software/BPG/Userbizhub200250350CopyOperPh2_5.pdf
Feb 15, 2011 | Konica Minolta bizhub 250 All-In-One Laser...
Tray1 Load LTR
Hope this helps. Please check the printer properties before clicking Ok at print menu command. Now check the available paper tray handler. Try bypass, tray1 or MP tray.
Check also the default paper on Printer Menu command by pressing appropriate setup button. You can try also placing the paper on bypass try if available. The load LTR message means the machine waits a short bond paper on MP tray or on bypass tray.
Jun 16, 2010 | Office Equipment & Supplies
How do you load standard sized envelopes into a Sharp MX-2300 copier?
Use the Bypass tray to load it. But first try the paper tray and try to load it there and see if the paper tabs have a size adjustment for envelopes. If not try the by pass
Apr 10, 2010 | Sharp MX-2300N Color Copier
H2 error when printing from pdf to A3 in multipurpose tray
H2 error code means that the paper size you are feeding into the machine does not match the paper size programmed into the machine. Minolta's are picky about these 2 size matching. So if you trying to print onto A3 then when you select the multipurpose tray it must read as A3.
Here is the info from the factory service manual:
H2 The length of the paper set does not
match that of the paper actually taken
up and fed in.
• Load paper of the correct size again
according to the set paper size.
• Turn OFF and ON the Power Switch.
• For copier tray: Slide out and in the
paper tray in which the size error has
occurred.
• For Manual Bypass Tray: Place paper
in the Manual Bypass Tray.
• For Multiple Bypass Tray: Unload
paper from the Multiple Bypass Tray,
then reload it back again.
Nov 23, 2009 | Minolta Di152 Laser Printer
Misfeed detected. Correctly position the bypass tray. I have a BizhubC451 printer, and it makes a loud awful sound when I try to load paper into what I think is the bypass tray. HELP!
When you install paper in bypass tray you must touch the bypass button and tell it what size paper and type of paper you are using or it will jam everytime, let me know if this helps, e-mail me at dave.herron@att.net
Nov 18, 2009 | Konica Minolta Office Equipment & Supplies
Can I print onto 5-1/2 x 14" paper
minumum size for the bypass is 3.5x5.5 and max is 11x17
minimum, for the paper trays is 5.75x8.25 and the max is11.5x16.5
so it should run 5.5x14 in the bypass tray
1 load the paper in the bypass tray
2 in the basics screen touch paper
3 select the button for the bypass tray
4 touch change setting
5 select custom size and program the size
Nov 17, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Trying to print but it ask me to load paper or form feed. also got a bypass tray message.
Sound like the computer printer preferences "paper source" is set to bypass if set to "auto select" select the tray you want. Also make sure type of paper matches what is in printer.
-Carl
Apr 23, 2009 | Ricoh Aficio CL3500N Laser Printer
Tray 1 - load ltr (WHAT DOES THIS MEAN!!!)
Best regards,
Rosener
Feb 08, 2008 | Tally T8006 Laser Printer
Ricoh Aficio  SP C411DN Laser Printer Logo
126 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
