Question about DCS RDS-364GD-SS Dual Fuel Kitchen Range
DCS Range constant sparking at all burners even when lighting one
DCS RDS-364-GDL LP, 4 cook top gas burners, electric oven, when trying to turn on one burner (any combination) the other 3 ignitors spark continually.
This happens to mine if there is anything on any of the burners, such as food residue or moisture. Check all the burners to see that nothing is touching the burner area where the gas jets are. Even a little water can make this happen.
Posted on Aug 10, 2009
I have a whirlpool range rf263lxtq the oven stays consent on what is wrong with it
Oven clicks as if it is relighting almost constantly.
· Old electric range ovens use a coil heating element called a resistive coil.
This is nothing more than an electrical wire encased in a sheath. They have flat black coils over rounded burner drip bowls that catch your drips and spills.
· The newer glass-ceramic cook top style element produces heat that radiates through the glass top to the cookware above.
· Gas ovens / stovetop that use gas and not electricity. These work by igniting gas and use actual flame on the the stovetop.
· Newest cook top styles, such as the induction or halogen cook tops combine the same style to produce more even heating. Some of these ovens feature thermal limiters or thermostats that regulate the burner system. GAS OVENS 1)The spark igniter tip is dirty (can clean it with either a little wire brush or a piece of fine sandpaper).
2) The Pilot flame is too low, and the tip of the igniter is not in the flame good enough. (the flame acts as a circuit when it touches the tip & completes the circuit).
3) The spark module is no good and needs to be replaced.(But 1 & 2 are your best bet).
spark module does not sense the flame when it's on. The spark igniter is also the flame sensor which provides feedback to the spark module.
Make sure the igniter is properly aligned with the burner lighting holes and it is clean. All lighting holes must be clean too. You can enlarge them using a drill bit one size bigger.
If it would not fix the problem, replace the bake burner and the igniter.
There is a small chance for the spark module itself to be bad as well.
ELECTRIC OVENS:
CHECK THE OVEN RELAY CONTROL BOARD Aclicking sound could be something wrong with a relay. Check for any loose connections around the main control board on your oven. The click you hear is a relay losing power and switching back on. If the clock resets then something is causing power interruptions to the board.
Feb 15, 2015 | Whirlpool 30" Self-Cleaning Freestanding...
Why won't my gas grill stay lit?
GAS OVENS
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
ELECTRIC OVENS:
Jul 04, 2014 | Zanussi Ovens
Ignitors still click even after burners are lit.
you have to adjust the knob after the burner lights to stop the clicking. there is no sensor to tell the oven when the burner is lit strictly manual
Aug 10, 2010 | DCS RDS-364GD-SS Dual Fuel Kitchen Range
All 6 ranges and the large oven work well.the small oven won't li
My gas oven stopped working properly - called in the repair man and he replaced two of the three ceramic ignitors. (I have a two oven model). Apparently they only last / work well for 3-5 years. Kinda sounded crazy to me - but verified on the internet they are required to be replaced. Not sure I'd call the repair man next time - get the part yourself, one screw & two wires to replace. I'm no expert - but that solved my problem.
May 22, 2010 | DCS RDS-486GD Stainless Steel Dual Fuel...
My DCS range burners with electric start.
Very likely the spark module. All four are supposed to click when one is turned on, however they are supposed to stop when the burner ignites. Replace the module and test. Good Luck, Appliance Specialists
Jan 03, 2010 | DCS 36-6-1 Gas Kitchen Range
OVEN WON'T STAY LITE MOST OF TIME & DOESN'T HEAT WELL:
Most problems with gas ranges have to do with the flame—either it isn't quite right or it's nonexistent. Many new gas ranges have "electronic ignition," a spark igniter that starts the flame as gas flows through the burners f, when you turn on a burner, it fails to spark but you hear sparking at other burners, the igniter or the burner switch probably needs replacement by an appliance repairperson. If your range has a pilot light, be sure the pilot light is lit.
have nice time..!! arte the solution!!
Apr 17, 2009 | DCS 24-24G-1 Gas Kitchen Range
DCS 4 burner plus griddle Range..oven doesn't heat
This happened to my DCS when the Hot Wire Relay went out. It isn't an expensive part, but finding someone that knows what needs to be replaced, and then can replace it is hard. My oven also did the opposite and continued to heat without shutting off, and it was once again the hot wire relay.
Jan 11, 2009 | DCS RDS-364GD-SS Dual Fuel Kitchen Range
Dcs gas oven/range, ignitor won't go off after burner or burners are lit
They probably cleaned the stove and in replacing the parts of the burner switched the rings on top of the burner. This happened to me. While they look alike, the round rings, not the flat disks, have to be on the right burner in order for the electron spark to ignite the gas. Good luck.
Oct 29, 2008 | DCS 24-24G-1 Gas Kitchen Range
No spark on all burners, oven doesn't work either
Give me the complete model # from the sticker on the oven and I will try to help.
Nov 07, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
DCS RDS-364GD-SS Dual Fuel Kitchen Range Logo
482 people viewed this question
Top DCS Kitchen Ranges Experts
John Tripp
John Tripp
Paul Carew
Sal De
Are you a DCS Kitchen Range Expert? Answer questions, earn points and help others
