Question about Whirlpool Duet 7.0 Cu. Ft. Super Capacity Plus Gas Dryer
Problem with Whirlpool Duet gas dryer
Model is WGD9600TW, Gas dryer, brand new only 6 months ago. This dryer has never worked properly. We've had two service companies out 4 different times. First some sensors replaced, no difference. Then the first guy said the vent system is too restrictive. (It was just fine on the old dryer). We didn't believe him. so we called another service company, he said the same thing. when the dryer is disconnected from the vent, it works normally. He removed front panel, we can see the flame. When connected to vent, the flame is "fat" and short, it contacts the "high-limit" switch, so the flame cycles on for 5 seconds, then shuts off. this repeats endlessly, so the dryer never warms up. When exhaust is disconnected (dryer vents into the room with no restriction), the flame is "skinny" and long, so it remains lit. Of course, you'll die if you breathe the fumes!
So I replaced a restrictive periscope in the exhaust vent with a nice new elbow (Whirlpool brand exhaust system, Whirlpool part number 4396028), made sure the vent run is clean (brushed it out with a rotary brush and drill motor), and tried it again. BTW, the exhaust run is about 12 feet, I use the heavy-duty metal flex tubing (exactly what's on that part number above) for the entire run, only a couple of bends, all bends are very gradual, no kinks, etc. I even removed the louvers on the outside vent. There is a nice strong breeze coming from the vent now. It is NOT restrictive.
The dryer is still not working. No difference. the flame kicks on and off.
The tech said the new dryers are sensitive to exhaust vent backpressure, because they blow much more air through than the older ones. Fine, but if it's so damn sensitive that it cannot withstand 12 feet of non-restrictive vent tubing, something is wrong with the design.
So, if you have a gas dryver that's cycling the flame on and off rapidly (5 seconds on for about every minute or so of running), try disconnecting and see what happens.
I am going to call Whirlpool and demand to speak with someone who can deal with this issue. Either they get me another machine, or I'll demand a refund and buy another brand. This is ridiculous.
  • lacruiser Mar 31, 2009
    here's an update. I spoke with whirlpool customer service, they
    refused to hook me up with their tech people. I found a specification
    on the web, published by whirlpool corp, describing how to measure the
    backpressure of the vent system.. the spec is "less than .6 water
    column inches as measured by an inclined manometer". So I bought one
    (cost about $25 on ebay) and my vent backpressure was in spec. I
    called whirlpool, very carefully explained all this, and when I did,
    they stopped me mid-sentence and said they would replace the machine.
    They did, and the new one works perfectly. the old dryer was defective
    all along.
    I'm on another computer, don't have the doc, but if you search for
    "dryer vent backpressure" or similiar on google, you'll find it. it's
    got a 2008 copyright date.
    the new machine works as well as we'd hoped. It's amazing. However,
    after being stonewalled by whirlpool originally, and being treated like
    an imbecile by them, and hearing about all the problems these machines
    have, I'll never buy another whirlpool product again. I think they're
    built like ****, and for they cost, that's a travesty.
  • Anonymous Apr 10, 2009
    We just bought a Duet gas dryer and on the first use there is no heat. The gas is turned on and the vent pipe is unrestricted.
Hi I have the same problem
Bypassed the hi limit switch and it runs fine
service teck replaced board,thermistor, all vents,gas coils , flame sensor and glo coil andf all with no luck. Unless it is bypassed thed ryer will only stay on 5 to 6 seconds on gas cycle
If i plug my old dryer in and hock up to gas and vent it works fine
So im using my old dryer and this peice of **** is sitting beside it as Im not going to run this without the safety thermostat
If you find out please let me know
Posted on Mar 31, 2009
Whirlpool duet electric dryer turns on but doesn't
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 01, 2011 | Whirlpool Dryers
Whirlpool Duet dryer is making a high pitched screeching noise. Model gew9250pw1.
heatman101
Aug 10, 2011 | Whirlpool Dryers
We have a whirlpool duet dryer and it will not heat up. I've checked for blockages and there doesn't seem to be any. It does spin but no heat
heatman101
Jun 29, 2011 | Whirlpool Dryers
My whirlpool duet gas dryer will not heat
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 23, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Smell gas coming from whirlpool duet gas dryer. Its not the gas line.
Hi, Often times that is because it is not lighting right...
If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Nov 04, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Gas dryer heating element won't come on.
There is a controller problem to turn on the gas manifold to produce heat. Since you have it only one week old, let's take the advantage of the warranty to have a new controller unit replaced.
Jan 03, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Brand new Gas whirlpool duet sport drier will not heat up. Gas line hooked up correctly HELP
Good day,
If it's new, and your sure there is gas in the line to the dryer, then you are entitled to a service call under warranty.
Whirlpool warranties it's dryers for one year from date of purchase.
Call your selling dealer. New one's won't work sometimes.
Dec 31, 2009 | Whirlpool Dryers
New Whirlpool Duet gas dryer (wgd9300vu) won't heat.
if its brand new,
anmd its gas, well then more than likely it was dropped, when it was dropped the graphite ignitor craked or broke due to shock impact,
i delivered units for 5 years and saw this numerous times.
I would tell you to fix it your self, but its brand new, if the company you bought it from has service they should give you a free service call and part
Oct 21, 2009 | Dryers
Brand New Whirlpool Duet 9450 Error Code PF
This is a problem I've seen before, or something similar. I think you've got a bad connection on the neutral wire. Either in the plug or at the panel. Have electrician check the neutral wire back to the panel from the plug.
Jul 25, 2009 | Dryers
Whirlpool Duet Dryer WED9600 Beeping during drying
Dear Customer
Please perform the following
please rate this,thank u
Dec 16, 2008 | Whirlpool GEW9250 Electric Dryer
Open Questions:
See all Whirlpool Duet 7.0 Cu. Ft. Super Capacity Plus Gas Questions
Whirlpool Duet 7.0 Cu. Ft. Super Capacity Plus Gas Dryer Logo
935 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
