Question about Pioneer PD-RW839 4-Disc CD Recorder
Pioneer PDR-W839 Disc Changer Jammed
Have a Pioneer PDR-W839 home cd player/recorder with jammed 3-disc tray-type changer. Won't open no matter what I do and just keeps clattering away while trying to open with no success until display finally shows an "E2" error code. Has anyone out there had experience with this specific problem and if not then do you think it's a self-fixable mechanical problem by someone decent with his hands but with no prior home audio component repair experience? Or alternatively do you think it's an electronic problem that would be better handled by a professional? Any advice and/or thoughts would be greatly appreciated. Thanks for your assistance!
  • 1 more comment
  • Karl Nakagawa May 26, 2007
    Problem update as of May 25:
    Contrary to the thought that this is a purely mechanical problem,
    I'm now thinking it could be an electronic malfunction. When unit
    is powered-on, disc changer automatically activates and then goes
    through aforementioned malfunction, all without pressing any other
    control buttons except for "power". Additionally, I was eventually
    successful in cleanly opening/closing all 3 trays in sequence for
    2-3 cycles on 2 or 3 separate occasions, further leading me to
    believe the problem might not be mechanical. So again, any advice
    and/or thoughts before I seek professional help locally, would be
    greatly appreciated. Thanks again to all for listening!!!
  • Karl Nakagawa May 28, 2007
    Wow, would've thought it'd be that simple, but
    I don't see any pinhole on the exterior of the
    unit. Should I remove the cover and look for it
    inside, and if so then in what area of the
    interior would it most likely be located?
    Thanks for taking the time to address my
    problem; I'll wait for further instructions.
  • Anonymous Mar 23, 2014
    100 discs
  • 883 Answers
Look for a small pinhole and insert a pin while powered up to reset the device
Posted on May 26, 2007
CD changer!! I have CD disc's in there and know it wont play them, its says disc error after awhile after I try to play all discs.
If one of the discs slipped off its tray and got jammed, you will have to take the cd changer out of the car and dislodge the jammed cd.
I had this happen a few years back and the guys at the auto parts store helped me remove it for free.
Feb 12, 2015 | 2006 Cadillac Escalade AWD
Hi,I have had this Pioneer CDX FM67 mounted on my bike for 5 yrs and it always played good and showed no problems.This year every time I load some cds in the player nothing happens and then I get an error...
It relates to the failure of the loading section. So check on the linking wires/flexible strip to the load motor- this is a ccommon fault and is seen most of the time.
Secondly the tray with CD can get strck due to a faulty disc- being warped. if so manually retrieve and reset.
finally there is a tiny hole near to the eject which can reset the changer if this has hung up or is jammed.
Open the covers and probe.
Jul 17, 2011 | Pioneer CDX-FM687 6-Disc CD Changer
Cd was still player and I found the player with drawer half open and jammed. I can't get it to sync with correct rotation, enough rotation or fully close or fully open. I can force it and hear the gears...
Rea alligning cds is not hard, but not too easy,the best way is to remove the whole cd changer mechanism and allign it to either one point,while totally disconnected, fully open or fully closed. I mean, the rubber or gear mechanism.
The main point of reference is the nearest part driven by the main motor. For example decide to do it when fully open, arrange everything so as to allow the tray to be fully open.If you get everything right, rotate the motor manually and see if it closes the tray without jamming..If it gets fully in keep rotating the motor and see if it loads the disc.if it does, return the assembkly, the sensors and the cd computer will take over from there ...
Apr 12, 2017 | Sony CDP-C445 5-Disc CD Changer
Jammed cds in a 6 cd changer ford ranger 2002
sounds like the tray inside was misaligned when the cd went in. and it probally sent the disc into a occupied slot. you will have to remove radio and disassemble to repair. also try just unpluging radio and plug back in. sometimes it resets the radio and will start ejecting the cds
Feb 05, 2010 | OEM Systems Car Audio & Video
Jvc xl-f254 cd changer for home. 5 disc changer. Carousel will not slide out. makes humming noise, possibly trying to open.
Take the cover off and inspect for a jammed disc.
If there are no jammed discs you either have a broken belt or stripped gear.
You will have to take the unit apart and inspect, belts are commercially available from electronic stores and are a cheap easy fix!
Let me know if you need more details or guidance.
Cheers!
Kevin
Jan 29, 2010 | JVC XL-F254BK 5-Disc CD Changer
5 cd changer tray wont open
just opened the dvd player..took out the jammed cd and it's working properly now...saved me 55$ for a check or was advised to buy a new one costing 400 odd $!
Jan 21, 2009 | Philips CDC775 5-Disc CD Changer
Cd changer is jammed in denon dcm 360 5 cd changer
Simply remove the outer casing and remove the jammed disc
Nov 28, 2008 | Denon DCM-360 5-Disc CD Changer
Jammed cd player
You can fixed the alignment of the disk tray of the CD player. But its pretty cool if the repairman in your nearest location would you let do the job.
Jan 06, 2008 | Audio Players & Recorders
Pioneer PDR-W839 Jammed Disc Changer (previously posted)
hello poopig1, after further review, I meant to describe this: look for a pinhole in the area of the CD tray to insert a pin...similar to the same pinhole you see on a PC's cd player to eject the tray manually. If there is none, then try this: Open the cover and find the motor that, when turning, performs the tray ejection. Then, turn that motor by hand until the entire tray (or cartridge) is ejected. Then power up and observe the events.
May 31, 2007 | Pioneer PD-RW839 4-Disc CD Recorder
Pioneer PD-RW839 4-Disc CD Recorder Logo
652 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
