Kyocera paperjam we got a kyocera fs-5015n used. it says paperjam. I have followed all the steps in the manual to remove a paperjam and haven't found any paper, it still says paperjam
    President:
  • 8,637 Answers
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Posted on Jan 26, 2009
Error 0954 kiosera fs c 5015n
error code 0954 is for led print head 3 error (yellow Drum Unit)
may need new print head. or try cleaning print head with soft cloth.
May 08, 2014 | Kyocera FS-C5015N Laser Printer
My Kyocera FS 2020d needs to print from my ipad. I can't figure out how to hook it up to my linksys wifi router.
Go to Kyocera Support and follow these steps:
Under Choose a Product Category choose Printer ' Black and white printers. Then select ECOSYS 2020D under Product Model, then select Manuals under Select Sub- Category (see screenshot below)
Find the operation guide to set the unit up on the network. Then go to the app store and find Kyocera Mobile Print. it's a free app and it supports Kyocera Products specifically.
Aug 26, 2013 | Kyocera FS-1030DN Printers
How do I install driver for Kyocera CS 5035 on MAC
Kyocera and Copystar models are the same just replace KM with CS.
The following instructions should help you. TO download the current driver use this link to th emanufacture website; http://usa.kyoceramita.com/americas/jsp/Kyocera/resource_details.jsp?rid=18657.
Kyocera Printer Drivers and Mac OS® X 10.5 Leopard FAQ:
Is the installation for Mac OS X 10.5 the same as for Mac OS X 10.4 and earlier? Mac OS X 10.5 introduced a new printing architecture that requires changes to the installer and installation process. For this reason, Mac OS X 10.5 requires a new printer driver installer.
I cannot see my Kyocera AppleTalk® printer. How can I make it visible to OS X 10.5? AppleTalk is disabled by default in Mac OS X 10.5. Enable AppleTalk to discover your Kyocera printer.If you use the Kyocera installer, a message will appear, asking you to enable AppleTalk. Click Yes to continue the installation.
I cannot find Printer Setup Utility on Mac OS X 10.5. Is it still supported? Apple has removed Printer Setup Utility from Mac OS X 10.5. To install a printer, open System Preferences and click Print & Fax.
When I manually install a printer, multiple PPD files are listed for the same Kyocera model. Which should I choose? When manually installing a printer or changing a PPD for a installed printer, both Linux and Mac OS X PPDs are listed for some older Kyocera models due to a change in PPD handling in Mac OS X 10.5. Linux PPDs can be identified by the word Gutenprint in the PPD filenames.
Supported Multifunction Printers: KM-1650, KM-1815, KM-1820, KM-2050 ,KM-2530 ,KM-2550, KM-3035, KM-3050, KM-3530, KM-4030, KM-4035, KM-4050, KM-4530, KM-5035, KM-5050, KM-5530, KM-6030, KM-6330, KM-7530, KM-8030, KM-C830, KM-C830D, KM-C850, KM-C850D, KM-C2520, KMC2525E, KM-C2630, KM-C3225, KM-C3225E, KM-C3232, KM-C3232E, KM-C4008, KM-C4035E, CS-1650, CS-1815, CS-1820, CS-2050,CS-C2525E, CS-2550, CS-6030, or newer. Supported Printers: FS-820, FS-920, FS-1018MFP, FS-1020D, FS-1030, FS-1100, FS-1118MFP, FS-1300D, FS-1800, FS-1800+, FS-1900, FS-1920, FS-3800, FS-3820N, FS-3830N, FS-6020, FS-6026, FS-9100DN, FS-9120DN, FS-9500DN, FS-9520DN, FS-C5016N, FS-C5020N, FS-C5030N, FS-C8008N, FS-C8026N, FS-C8100DN, or newer.
I hope this is helpful,
Shawn
Mar 08, 2011 | Kyocera Copystar CS-5035 Copier
I am looking for free driver of Kyocera FS-5015N Printer for xp Thanks
Hello, i would reccomen the KX Driver, it has the most functionality.
The driver can be downloaded from the posted link.
KyoDrivers
Take Cae
Feb 04, 2011 | Office Equipment & Supplies
Can you please supply me with a user manual for a kyocera fs 3500 printer please? I need to change the toner and I dont know where to start.
Are you sure it's not an fs-3600?
I found the manual for the fs-3600 at http://usa.kyoceramita.com/americas/jsp/Kyocera/download_center.jsp
Select legacy printers / FS-3600 model, technical resources, and finally manuals in the subcategory.
Apr 19, 2010 | Office Equipment & Supplies
HOW CAN I RESOLVE ERROR c6000 in fs 1118
This might take some doing reseting the fs 1118 but it can be done if the fuser only got hit by a powersurge or overheated due to paperjam by the fuser...
press system menu/counter
select service settings via up and down cursor keys
now while pressing start key and # key press enter
then select maintenance mode by using the up down cursor key
press enter
enter 163 and then restart the copier...
sometimes you wont even be able to get to the service mode...
open the front of the copier and then execute the steps... the front meaning the area where you the toner is located...
trying keeping it open and do the steps...
if that fails then open it take out the toner drum cartridge and then put it back in...
then do the steps...
if it still doesn't take try it a couple more times...
if it still doesn't take.. buy a new fuser...
but it should take... it just takes a little experimentation...
Jun 22, 2009 | Kyocera FS-1118 Printer
Kyocera FS 1030D Flashing Lights
you are out of toner and you have a paperjam
Jun 16, 2009 | Kyocera Mita FS-1030D Laser Printer
We got a kyocera fs-5015n used. It won't print just says paperjam. i have followed all the steps in the manual to remove a paperjam and haven't found any paper in the machine.
Jan 02, 2009 | Office Equipment & Supplies
Paper jam
Did you try the door in the back of the printer?
Pull the paper cassette out then pull on the green handle to pull out the feed unit.
Jan 02, 2009 | Kyocera FS-C5015N Laser Printer
Looking for Kyocera Mita Ecosy FS-1010 Instruction Manual
A downloadable copy of the Kyocera Mita FS-1010 user manual is available here.
Good luck and kind regards.
Thank you for using FIXYA.
Feb 12, 2008 | Kyocera Mita FS 1010 Laser Printer
185 people viewed this question
k24674
