Question about General Electric 28821FE2 Phone
How do I delete or change the stored numbers on my Model 28821fe2-a
Firstly you should go on menu then contacts then delete items.
Posted on Jan 02, 2009
How many amps for GE 28821fe2? I lost the ac adapter
You need to match the voltage of the transformer. Your phone base will be labeled as to the required voltage, next to where the trans. plugs in. murf427
Aug 01, 2012 | General Electric 28821FE2 Phone
I have a GE twin phone, one is cordless they are a set. Model number is 28821fe2a and it is a DECT 6.0. I need a manual so I can put my own voice mail message on the thing
You can download and print the instruction manual in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this helps. Kindly let me know if you have any difficulty in downloading the manual.
Thanks for using FixYa.
Apr 07, 2011 | General Electric 28821FE2 Phone
How do I delete speed dial numbers on the Intellifax 2820?
Changing One Touch (For FAX Models Only) and Speed Dial Numbers
If you try to store a One Touch (FAX models only) or Speed Dial number in a
location where a number is already stored, the LCD shows the current name stored there, and then prompts you to either:
1 Press 1 to change the stored number-OR- press 2 to exit without making a change.
2 Enter a new number, and then press Menu/Set.
• If you want to erase the whole number, press Stop/Exit when the cursor
is to the left of the digits. The letters above and to the right of the cursor will be deleted.
• If you want to change a digit, use or to position the cursor under the digit you want to change, and then type over it.
3 Follow the directions beginning at Step 4 in Storing One Touch Numbers
(For FAX Models Only) and Storing Speed Dial Numbers.
Dec 03, 2010 | Brother IntelliFax-2820 Laser Fax
I need to know how to program the numbers into the speed dial option. My mother's phone is a table set with large numbers #29267A ... close enough?
Before you store a telephone number in memory, make sure the dialing mode is
correctly set for the type of service you have. The default dialing mode is tone
(touch-tone), so if you have pulse (rotary) service, you must first change the dialing
mode. See “To Set the Dial Mode.” The following buttons can be stored into any
memory location: 0-9.
STORING FREQUENTLY CALLED NUMBERS
1. Pick up the handset.
2.Press the store button.
3. Push the desired memory location button.
4. Press the store button.
5.Use the handset number keys to enter the telephone number (up to 16-digits)
and press the store button.
6.Hang up the handset.
NOTE: If you make a mistake, use the delete button to delete wrong digits.
CHANGING A STORED NUMBER
Repeat the storage sequence above. The new number replaces the old number at
the memory location.
ERASING A STORED NUMBER
3.Press the memory location (0-9) to be erased.
4.Press delete for three seconds until the number in the display is erased.
5.Hang up the handset.
DIALING FREQUENTLY CALLED NUMBERS
1. Pick up the handset and press the mem button.
2. Press 0-9 for the memory location. The number dials automatically.
OR
1. Pick up the handset and press the dial button.
2. Press the review button for the desired memory location.
3. Press the dial button to dial the number.
OR
1. Press dial button while the handset is still in the cradle.
2. Press the review button for the desired memory location, lift the handset and the
Download User Manual
If this information was helpful, please give me a big thumbs-up when you rate my answer. Thank you.
Feb 02, 2010 | GE 29267GE3 Corded Phone
I HAVE A GE MODEL NO 28821FE2-A AND I LOST THE MANUAL I DO NOT KNOW HOW I CAN SE THE ANSWERING MACHINE ON
You can download the manual at
http://www.home-electronics.net/USER-GUIDES/28821_CAN_EN_CL_IB.pdf
Dec 16, 2009 | General Electric 28821FE2 Phone
How do I delete stored faxed numbers (speed keys)of the fax machine? How do you change a speed key title?(let say I fax documents to this fax number everyday: I stored the fax number under the name "Team...
From Ricoh Aficio MP2550 manual:
Delete destinations registered in the LAN-Fax Address Book:
numb01.gifOn the [Start] menu, point to [All Programs], [LAN-Fax Utilities], and then click [Address Book].
The [Address Book] dialog box appears.
If LAN-Fax Driver has already started up, click [Edit Address Book...].
numb02.gifClick [New/Browse...], and then select the CSV file containing the address list to be edited.
numb03.gifSelect the destination you want to delete so it is highlighted in the list.
numb04.gifClick [Delete].
numb05.gifClick [Yes].
numb06.gifClick [Close].
numb07.gifIf you made changes to a destination, a confirmation message appears. To save the changes, click [Yes].
If you do not want to save the changes and want to quit editing, click [No].
To return to the editing display, click [Cancel].
The confirmation dialog box does not appear when you have not made any changes after starting Address Book.
You can download the manual (HTML or PDF/ZIP versions) from here:
http://support.ricoh.com/bb_v1oi/html/oi/rc2/model/mp33/mp33en.htm
Jul 29, 2009 | Ricoh Aficio GX5050 GelSprinter InkJet
How do you change the message on my GE 28821FE2-A cordless phone?
1. Make sure the answering system is ON. 2 . Press and hold the announce button until the speaker announces “RECORD ANNOUNCEMENT AFTER TONE“. 3 . Begin speaking after you hear the beep. 4 . Release the button when you finish your announcement. NOTE: If you choose not to record an outgoing announcement, a default announcement plays instead. To return to the default announcement after you have recorded your own outgoing announcement, press the announce button and release it when you hear the beep. Or, press the delete button while the announcement is reviewing. Sample Outgoing Announcement Hi, this is (use your name here), I can’t answer the phone right now, so please leave your name, number and a brief message after the tone, and I’ll get back to you. Thanks. NOTE: The maximum recording time for the outgoing announcement is 2 minutes. Reviewing and Choosing the Announcement Press and release the announce button to review and select this one as your outgoing announcement. NOTE: Press the PLAY/STOP button at any time to stop playing the announcemet
Mar 25, 2009 | General Electric 28821FE2 Phone
Panasonic Digital Super Hybrid System KX-TDA
use the same procedure. when you get to the number you want to delete, press transfer and store.
Apr 11, 2008 | Panasonic (KX-TDA0104) (KXTDA0104) Power...
Change/add #'s in Memory
Find your model number and then click this link to download the manual
Manual page
Jan 18, 2008 | Uniden Cordless Phone
General Electric 28821FE2 Phone Logo
65 people viewed this question
Top General Lands Phones Experts
Are you a General Lands Phone Expert? Answer questions, earn points and help others
